1 Reply Latest reply on May 28, 2010 5:19 AM by bemdesign
    DW CS4 does not show CFCs defined in a site
    cheftimo Level 2
      When I used my DW CS4 components panel about 3 weeks ago, everything was working fine, I could see and work with all my CFCs.
      I went back to use that panel 2-3 days ago and now see that it only shows CFCs when you select the “Show all CFCs” option. There, only those under ‘CFIDE.’ and ‘gateway.’ show up, plus one label ‘<none>’, under which 3 CFCs that belong to a configured site appear – I take it ‘<none>’ means those CFCs are not within any site.
      When I select “Show only current site’s CFCs”, I get a window that says “There are no CFCs defined in the current site”, which sucks because there ARE over 100 CFCs in the selected site.
      I have already tried the following:
      • Per instructions in the      DW FAQ forum, deleted the DW configuration folder – which gets re-created      when I re-launch DW.
      • Removed and re-created      the site in question.
      Neither of the above has fixed the problem, so I still get that window that says no CFCs are defined.
      Has anyone had a similar problem?
      Any ideas on how to fix this would be very much appreciated.
      Best regards to all,
      Carlos
