5 Replies Latest reply on May 31, 2010 8:26 AM by Peter Kahrel
    Select a table
    Xakie
      Can anybody tell to me how to select a table through scripting. InDesign CS3, Javascript
      Thanks.
      Xakie
        • 1. Re: Select a table
          Anil Yadav Level 1
          Hi Xakie,
          Here is the code:
          app.select(app.activeDocument.textFrames[0].tables[0]);
          Regards,
          Anil Yadav
          • 2. Re: Select a table
            Xakie Level 1
            Thanks Yadav,
            but didn't worked, getting this error:
            Am new to scripting, what's wrong here?
            Xackie
            • 3. Re: Select a table
              Peter Kahrel Adobe Community Professional & MVP
              Xakie,
              If the first text frame in your document doesn't contain a table, then Anil's code doesn't work. It depends on where your table is and what state your document is in. Here are some approaches:
              1. If you have an insertion point selected in a table, do this:
              app.selection[0].parent.parent.select();
              2. If you have a text frame selected which has a table in it, then do this:
              app.selection[0].tables[0].select();
              3. To find all tables in the document and select the first one (though "first" is a variable and fluid concept here):
              app.documents[0].stories.everyItem().tables.everyItem().getElements()[0].select();
              But do you really want to select a table? Whenever possible avoid working with selected items. To do something with a table, you could also address it as an object:
              myTable = app.selection[0].tables[0];
              myTable.cells[0].contents = "First cell";
              Peter
              • 4. Re: Select a table
                Xakie Level 1
                Great! Simply superb.
                Me trying to select all tables from a document. Then applying the table styles.
                Once again thanks for the tips.
                Xakie
                • 5. Re: Select a table
                  You can use this one-liner for that:
                  app.activeDocument.stories.everyItem().tables.everyItem().appliedTableStyle = myTableStyle;
                  Peter
