1. Re: ReferenceError: Object is invalid
Curt Y May 28, 2010 6:44 AM (in response to DavidSalahi)I use 2 windows of Bridge all the time and have never had a problem. I am using CS3
Not that I am qualified to intrepret them have you looked at the crash log in the OS to see if it gives you a clue as to what is happening?
My gut feeling is that it is the video card or driver. What are you using?
2. Re: ReferenceError: Object is invalid
DavidSalahi May 28, 2010 7:18 AM (in response to Curt Y)Curt,
Interesting. I get the problem constantly (always? I've been burned so many times I don't try it much any more).
What crash logs are you referring to (I'm on Win 7 x64 but had it on XP and CS4, too; probably CS3 also, don't remember).
Currently running ATI Radeon HD 4800, but I had the problem on my previous PC as well.
David Salahi
3. Re: ReferenceError: Object is invalid
Curt Y May 28, 2010 7:31 AM (in response to DavidSalahi)I am running a low end ATI card (2400 with 128k memory) with 2 monitors. Have "use software rendering" checked in advanced preferences. Seems to work fine. I take it you click on File/New Window?
I have never used a crash log but understand it will keep the log for couple of days. There is lots of technical gibberish there, but look for something you might recognize. Go the the OS help file or do a web inquiry as it has everything.
It is probably not Bridge, but some hardware or software conflict.
Good luck.
