6 Replies Latest reply: Aug 14, 2010 8:46 PM by tunghoy RSS
    Normal Windows Copy/Cut/Paste
    DavidSalahi Community Member
      I wish Bridge would implement copy/cut/paste of image files like a normal  Windows program. I often would like to be able to copy a file in Bridge  and then paste it into another directory within Windows Exlorer. But it doesn't work. Instead,  you can copy/paste only within Bridge. Similarly, you cannot copy a file in Windows Explorer and then paste within Bridge.
      This failure to  support normal Windows copy/paste is especially annoying because of the  inability to open two Bridge instances at the same time. Every time I  try I encounter the dreaded "ReferenceError: Object is invalid." (See my message about this error in the Bridge Windows forum from 10 minutes ago.) Once the error occurs, it continues to recur and Bridge is unusable. You have to exit out of Bridge.
      The lack of normal Windows copy/paste would be less of a problem if this error didn't occur. But because the error does occur, copying/pasting files between directories in Bridge is very tedious.
      David Salahi
