5 Replies Latest reply on Jun 29, 2010 6:23 AM by DB_Shonek
    StyleProtoChain.as Error loading a module
    DB_Shonek
      Hi, im having problems loading a module in flex 4, it previously works fine in flex 3 and other modules are working fine right now.
      This is how im loading the modules (the same for all them):
      MyModuleContainer = new moduleContainer;
      viewstack2.addChild(MyModuleContainer);
      MyModuleContainer.miModuleLoader.url = ThisResource.url;
      MyModuleContainer.miModuleLoader.loadModule();
      MyModuleContainer.name = String(ResourceID);
      This is my moduleContainer component:
      <mx:Canvas xmlns:fx="http://ns.adobe.com/mxml/2009" xmlns:mx="library://ns.adobe.com/flex/mx" xmlns:s="library://ns.adobe.com/flex/spark" width="100%" height="100%" initialize="init()">
           <fx:Script>
                <![CDATA[
                     import mx.controls.ProgressBar;
                     import mx.events.ModuleEvent;
                     private var MyProgressBar:ProgressBar = new ProgressBar;
                     private function init():void{
                          addChild(MyProgressBar);
                          MyProgressBar.source = miModuleLoader;
                          MyProgressBar.percentWidth = 50;
                          MyProgressBar.setStyle("verticalCenter", 0);
                          MyProgressBar.setStyle("horizontalCenter", 0);
                          miModuleLoader.addEventListener(ModuleEvent.READY, onComplete);
                     private function onComplete(event:ModuleEvent):void {
                          removeChild(MyProgressBar);
           </fx:Script>
           <mx:ModuleLoader x="0" y="0" width="100%" height="100%" id="miModuleLoader">
           </mx:ModuleLoader>
      </mx:Canvas>
      The full error:
      TypeError: Error #1009: No se puede acceder a una propiedad o a un método de una referencia a un objeto nulo.
      at mx.styles::StyleProtoChain$/initProtoChainForUIComponentStyleName()[E:\dev\4.0.0\framewor ks\projects\framework\src\mx\styles\StyleProtoChain.as:356]
      at mx.styles::StyleProtoChain$/initProtoChain()[E:\dev\4.0.0\frameworks\projects\framework\s rc\mx\styles\StyleProtoChain.as:171]
      at mx.core::UIComponent/http://www.adobe.com/2006/flex/mx/internal::initProtoChain()[E:\dev\4.0.0\frameworks\proje cts\framework\src\mx\core\UIComponent.as:10186]
      at mx.core::UIComponent/regenerateStyleCache()[E:\dev\4.0.0\frameworks\projects\framework\sr c\mx\core\UIComponent.as:10249]
      at mx.core::UIComponent/http://www.adobe.com/2006/flex/mx/internal::addingChild()[E:\dev\4.0.0\frameworks\projects \framework\src\mx\core\UIComponent.as:7114]
      at mx.core::UIComponent/addChild()[E:\dev\4.0.0\frameworks\projects\framework\src\mx\core\UI Component.as:6811]
      at mx.controls.listClasses::ListBase/createChildren()[E:\dev\4.0.0\frameworks\projects\frame work\src\mx\controls\listClasses\ListBase.as:3774]
      at mx.core::UIComponent/initialize()[E:\dev\4.0.0\frameworks\projects\framework\src\mx\core\ UIComponent.as:7250]
      at modules.reports::reportsTree/initialize()
      at mx.core::UIComponent/http://www.adobe.com/2006/flex/mx/internal::childAdded()[E:\dev\4.0.0\frameworks\projects\ framework\src\mx\core\UIComponent.as:7142]
      at mx.core::Container/http://www.adobe.com/2006/flex/mx/internal::childAdded()[E:\dev\4.0.0\frameworks\projects\ framework\src\mx\core\Container.as:3951]
      at mx.core::Container/addChildAt()[E:\dev\4.0.0\frameworks\projects\framework\src\mx\core\Co ntainer.as:2616]
      at mx.core::Container/addChild()[E:\dev\4.0.0\frameworks\projects\framework\src\mx\core\Cont ainer.as:2534]
      at mx.core::Container/createComponentFromDescriptor()[E:\dev\4.0.0\frameworks\projects\frame work\src\mx\core\Container.as:4371]
      at mx.core::Container/createComponentsFromDescriptors()[E:\dev\4.0.0\frameworks\projects\fra mework\src\mx\core\Container.as:4160]
      at mx.core::Container/createChildren()[E:\dev\4.0.0\frameworks\projects\framework\src\mx\cor e\Container.as:3187]
      at mx.core::Container/initialize()[E:\dev\4.0.0\frameworks\projects\framework\src\mx\core\Co ntainer.as:3129]
      at modules.reports::reports/initialize()
      at mx.modules::ModuleLoader/moduleReadyHandler()[E:\dev\4.0.0\frameworks\projects\framework\ src\mx\modules\ModuleLoader.as:468]
      at flash.events::EventDispatcher/dispatchEventFunction()
      at flash.events::EventDispatcher/dispatchEvent()
      at ModuleInfoProxy/moduleEventHandler()[E:\dev\4.0.0\frameworks\projects\framework\src\mx\mo dules\ModuleManager.as:1168]
      at ModuleInfo/readyHandler()[E:\dev\4.0.0\frameworks\projects\framework\src\mx\modules\Modul eManager.as:812]
      at mx.core::FlexModuleFactory/update()[E:\dev\4.0.0\frameworks\projects\framework\src\mx\cor e\FlexModuleFactory.as:433]
      at mx.core::FlexModuleFactory/docFrameHandler()[E:\dev\4.0.0\frameworks\projects\framework\s rc\mx\core\FlexModuleFactory.as:582]
      at mx.core::FlexModuleFactory/docFrameListener()[E:\dev\4.0.0\frameworks\projects\framework\ src\mx\core\FlexModuleFactory.as:126]
      Any help would be nice, thanks in advance.
