0 Replies Latest reply on May 28, 2010 2:41 AM by Improving_Flex
    flex 4, BlazeDS, ANT task issue
    Improving_Flex
      I want to compile flex 4 application using ANT mxmlc task. My application's front end was developed using flex 3. I am using Java at the back end and BlazeDS as the message broker between front-end (flex) and back-end (java). BlazeDS configuration is defined using spring injection.
      Following was the ANT script which was compiling the application correctly using flex 3.
      <property file="${basedir}/build.properties"/>
      <property name="FLEX_HOME" value="${env.FLEX_HOME}" />
      <property name="flex.src.dir" value="${basedir}/src/main/flex"/>
      <property name="flex.app.file" value="index.mxml"/>
      <property name="flex.output.dir" value="${basedir}/WebContent"/>
      <property name="flex.output.file" value="index.swf"/>
      <property name="flex.config.dir" value="${basedir}/src/main/resources/flex"/>
      <property name="flex.assets.dir" value="${flex.src.dir}" />
      <property name="flex.lib.dir" value="${basedir}/libs" />
      <property name="debug" value="false" />
      <!-- Define the Flex tasks. -->
      <taskdef resource="flexTasks.tasks" classpath="${FLEX_HOME}/ant/lib/flexTasks.jar"  />
      <target name="compile.flex">
      <mxmlc newenvironment="true"
      file="${flex.src.dir}/${flex.app.file}"
      output="${flex.output.dir}/${flex.output.file}"
      optimize="true"
      context-root="/hrms-web"
      debug="${debug}"
      <arg id="services" value="${flex.config.dir}/services-config.xml" />
      <arg id="locale" value="en_US" />
      <arg id="source-path" value="${flex.src.dir}/assets/locale/{locale}" />
      <arg id="allow-source-path-overlap" value="true" />
      <arg id="incremental" value="true" />
      <load-config filename="${FLEX_HOME}/frameworks/flex-config.xml" />
      <!-- List of path elements that form the roots of ActionScript class hierarchies. -->
      <source-path path-element="${flex.src.dir}" />
      <source-path path-element="${flex.src.dir}/assets/locale/{locale}" />
      <source-path path-element="${FLEX_HOME}/frameworks" />
      <compiler.library-path dir="${FLEX_HOME}/frameworks" append="true">
      <include name="libs" />
      <include name="locale/{locale}" />
      <include name="libs/player/10/**" />
      </compiler.library-path>
      <!-- List of SWC files or directories that contain SWC files. -->
      <library-path dir="${flex.lib.dir}" append="true">
      <include name="*.swc" />
      </library-path>
      </mxmlc>
      </target>
      After I installed flex 4 and used some components of flex 4, I installed Flash Builder 4 which compiles the swf correctly. Following are the screen shots of the flex configuration in Flash Builder 4.
      I used the same old ANT script, obviously with new (flex 4) library files (mxmlc.jar, blazeDS jars etc), to compile flex application using flex 4 sdk. It does compile and generate an swf file, but this file's size is less than half of the one generated by flash builder. Also, when I deploy this file in web server, it does load, but is unable to connect to remote destinations.
      Here is the ANT script and error message.
      <mxmlc newenvironment="true" description="Compiles the flex project into an swf fille."
      optimize="true"
      context-root="hrms-web"
      debug="${debug}"
      <arg id="theme" value="${FLEX_HOME}/frameworks/themes/Halo/halo.swc" />
      <arg id="strict" value="true" />
      <arg id="verbose" value="true" />
      <!--arg id="compatibility-version" value="3.0" />
      <arg id="incremental" value="false" />
      <arg id="append" value="true" />
      <arg id="context-root" value="hrms-web" /-->
      <!--classpath>
      <fileset dir="${web.services.config.dir}">
      <include name="*.xml" />
      </fileset>
      </classpath>
      <classpath>
      <fileset dir="${flex.config.dir}">
      </fileset>
      </classpath -->
      </library-path>
      </mxmlc>
      </target>
      Here is services-config.xml
      <?xml version="1.0" encoding="UTF-8"?>
      <services-config>
      <services>
      <service-include file-path="remoting-config.xml" />
      <service-include file-path="proxy-config.xml" />
      <service-include file-path="messaging-config.xml" />
      <default-channels>
      <channel ref="my-amf"/>
      </default-channels>
      </services>
      <channels>
      <channel-definition id="my-amf" class="mx.messaging.channels.AMFChannel">
      <endpoint url="http://{server.name}:{server.port}/{context.root}/messagebroker/amf" class="flex.messaging.endpoints.AMFEndpoint"/>
      <properties>
      <polling-enabled>false</polling-enabled>
      </properties>
      </channel-definition>
      <channel-definition id="my-secure-amf" class="mx.messaging.channels.SecureAMFChannel">
      <endpoint url="https://{server.name}:{server.port}/{context.root}/messagebroker/amfsecure" class="flex.messaging.endpoints.SecureAMFEndpoint"/>
      <properties>
      <add-no-cache-headers>false</add-no-cache-headers>
      </properties>
      </channels>
      <logging>
      <!-- You may also use flex.messaging.log.ServletLogTarget -->
      <target class="flex.messaging.log.ConsoleTarget" level="Warn">
      <properties>
      <prefix>[BlazeDS] </prefix>
      <includeDate>false</includeDate>
      <includeTime>false</includeTime>
      <includeLevel>true</includeLevel>
      <includeCategory>false</includeCategory>
      </properties>
      <filters>
      <pattern>Endpoint.*</pattern>
      <pattern>Service.*</pattern>
      <pattern>Configuration</pattern>
      </filters>
      </target>
      </logging>
      <system>
      <redeploy>
      <enabled>true</enabled>
      <watch-interval>20</watch-interval>
      <watch-file>{context.root}/WEB-INF/flex/services-config.xml</watch-file>
      <watch-file>{context.root}/WEB-INF/flex/remoting-config.xml</watch-file>
      <touch-file>{context.root}/WEB-INF/web.xml</touch-file>
      </redeploy>
      </system>
      </services-config>
      Here is my remoting-config.xml
      <service id="remoting-service"
      class="flex.messaging.services.RemotingService">
      <!-- This is default adaptor for flex/BlazeDS requests -->
      <adapters>
      <adapter-definition id="java-object"
      class="flex.messaging.services.remoting.adapters.JavaAdapter" default="true"/>
      </adapters>
      <!-- This is default channel for flex/BlazeDS requests -->
      <default-channels>
      </default-channels>
      </service>
      My destinations (services) are defined in another spring configuration file. Here are the contents of that file:
      <beans xmlns="http://www.springframework.org/schema/beans"
      xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
      xmlns:flex="http://www.springframework.org/schema/flex"
      xmlns:p="http://www.springframework.org/schema/p"
      xmlns:context="http://www.springframework.org/schema/context"
      xmlns:security="http://www.springframework.org/schema/security"
      xsi:schemaLocation="http://www.springframework.org/schema/beans
      http://www.springframework.org/schema/beans/spring-beans-2.5.xsd
      http://www.springframework.org/schema/context/spring-context-2.5.xsd
      http://www.springframework.org/schema/flex/spring-flex-1.0.xsd
      http://www.springframework.org/schema/security/spring-security-2.0.4.xsd
      <import resource="applicationContext.xml" />
      <bean id="mySpringFlexExceptionTranslator"
      class="net.hrms.web.util.SpringFlexExceptionTranslator"/>
      <flex:message-broker services-config-path="/WEB-INF/flex/services-config.xml">
      <flex:exception-translator ref="mySpringFlexExceptionTranslator"/>
      <flex:remoting-service default-adapter-id="my-default-remoting-adapter"
      default-channels="my-amf, my-secure-amf" />
      <flex:secured />
      </flex:message-broker>
      <flex:remoting-destination ref="mappingService"/>
      <flex:remoting-destination ref="searchUIService"/>
      <flex:remoting-destination ref="lookupUIService"/>
      <flex:remoting-destination ref="documentUIService"/>
      <flex:remoting-destination ref="listUIService"/>
      <flex:remoting-destination ref="activityUIService"/>
      </beans>
      Here are the snap shots of error messages that pop up when I use the generated swf.
      Any one can please help?
