1 Reply Latest reply on May 28, 2010 3:31 PM by Joe ... Ward
    Error #3115: SQL Error.', details:'no such table
    nasiralisher Level 1
      I'm creating my Adobe Air App using Flash CS5 Professional and facing exactly the following error.
      SQLError: 'Error #3115: SQL Error.', details:'no such table: 'categories'', operation:'execute', detailID:'2013'
      My SQLite Db has been created using Firefox extension - SQLite Manager. The db file is placed into the same folder as the .fla and .swf files. The db has three tables namely: categories, period and activity. I don't understand why I'm getting this error. I have even tried copy pasting other source code from AS 3.0 reference guide but same error every time.
      The code below is a modified version of example code in AS 3.0 reference documentation. Can you suggest how the above error can be fixed?
      /you can also reply to me directly at nasiralisher@gmail.com
      /regards
      import flash.data.SQLConnection;
      import flash.data.SQLResult;
      import flash.data.SQLStatement;
      import flash.display.Sprite;
      import flash.events.SQLErrorEvent;
      import flash.events.SQLEvent;
      import flash.filesystem.File;
      var conn:SQLConnection;
      var insertCategory:SQLStatement;
      var dbFile:File;
      databaseConnect();
      function databaseConnect():void
      // define where to find the database file
      var appStorage:File = File.applicationStorageDirectory;
      dbFile = appStorage.resolvePath("MyBudgetCalc.db");
      // open the database connection
      conn = new SQLConnection();
      conn.addEventListener(SQLErrorEvent.ERROR, errorHandler);
      conn.addEventListener(SQLEvent.OPEN, openHandler);
      trace("dbFile.exists:"+ dbFile.exists);
      conn.openAsync(dbFile);
      // Called when the database is connected
      function openHandler(event:SQLEvent):void
      conn.removeEventListener(SQLEvent.OPEN, openHandler);
      // start a transaction
      //Object(this).inputfield.text = "openHandler called.. ";
      conn.addEventListener(SQLEvent.BEGIN, beginHandler);
      conn.begin();
      trace("exiting openHandler..");
      // Called when the transaction begins
      function beginHandler(event:SQLEvent):void
      conn.removeEventListener(SQLEvent.BEGIN, beginHandler);
      //trace("beginHandler - SQLEvent message: "+SQLEvent.message);
      Object(this).inputfield.text = "beginHandler called.. ";
      insertCategory = new SQLStatement();
      insertCategory.sqlConnection = conn;
      insertCategory.text = "INSERT INTO categories(id, name) VALUES (', Auto')";
      insertCategory.execute();
      insertCategory.addEventListener(SQLEvent.RESULT, insertCategoryHandler);
          insertCategory.addEventListener(SQLErrorEvent.ERROR, errorHandler);
      trace("exiting beginHandler..");
      // Called after the phone number record is inserted
      function insertCategoryHandler(event:SQLEvent):void
      insertCategory.removeEventListener(SQLEvent.RESULT, insertCategoryHandler);
      insertCategory.removeEventListener(SQLErrorEvent.ERROR, errorHandler);
      // No errors so far, so commit the transaction
      conn.addEventListener(SQLEvent.COMMIT, commitHandler);
      conn.commit();
      trace("exiting insertCategoryHandler after conn.commit()..");
      // Called after the transaction is committed
      function commitHandler(event:SQLEvent):void
      conn.removeEventListener(SQLEvent.COMMIT, commitHandler);
      trace("exiting commitHandler(): Transaction complete..");
      // Called whenever an error occurs
      function errorHandler(event:SQLErrorEvent):void
      trace("entering errorHandler()..");
      // If a transaction is happening, roll it back
      if (conn.inTransaction)
      conn.addEventListener(SQLEvent.ROLLBACK, rollbackHandler);
      conn.rollback();
      trace(event.error.message);
      trace(event.error.details);
      trace("exiting errorHandler()..");
      // Called when the transaction is rolled back
      function rollbackHandler(event:SQLEvent):void
      conn.removeEventListener(SQLEvent.ROLLBACK, rollbackHandler);
