4 Replies Latest reply on Nov 4, 2010 11:55 AM by harry_lai84
    Flex Date Time Axis Not showing Correct Values
    V Katkar
         xmlns:mx="library://ns.adobe.com/flex/halo" width="700" height="500">
      <fx:Declarations>
      <!-- Place non-visual elements (e.g., services, value objects) here -->
      </fx:Declarations>
      <fx:Script>
      <![CDATA[
      import mx.collections.ArrayCollection;
      [Bindable]
      public var stockDataAC:ArrayCollection = new ArrayCollection( [
      {date: "2005, 7, 27", close: 41.71},
      {date: "2005, 7, 28", close: 42.21},
      {date: "2005, 3, 29", close: 42.11},
      {date: "2005, 1, 1", close: 42.71},
      {date: "2005, 10, 2", close: 42.99},
      {date: "2005, 9, 3", close: 44} ]);
      public function myParseFunction(s:String):Date {
      // Get an array of Strings from the comma-separated String passed in.
      var a:Array = s.split(",");
      // Create the new Date object. Subtract one from the month property.
      // The month property is zero-based in the Date constructor.
      var newDate:Date = new Date(a[0],a[1]-1,a[2]);
      return newDate;
      </fx:Script>
      <mx:Panel title="DateTimeAxis Example" height="100%" width="100%">
      <mx:LineChart id="mychart" height="100%" width="100%"
        paddingRight="5" paddingLeft="5"
        showDataTips="true" dataProvider="{stockDataAC}">
      <mx:horizontalAxis>
      <mx:DateTimeAxis dataUnits="days" parseFunction="myParseFunction"/>
      </mx:horizontalAxis>
      <mx:verticalAxis>
      <mx:LinearAxis baseAtZero="false" />
      </mx:verticalAxis>
      <mx:series>
      <mx:LineSeries yField="close" xField="date" displayName="AAPL"/>
      </mx:series>
      </mx:LineChart>
      </mx:Panel>
      </s:Application>
      the above code shows reverse values of date on date axis i.e it should show 01/05 2/05 3/05 4/05 but its showing 10/05 09/05 08/05 07/05 on date axis.
      Please help.
