6 Replies Latest reply on Aug 13, 2007 1:18 PM by Newsgroup_User
    Trouble with intersects
    andy_scot
      When i try to set up code for an interest it will not work correctly.
      I am trying to make it that when sprite 45 intersects sprite 29 that there will be a value removed from a field called pages
      i have tried writing it as
      if sprite 45 intersects sprite 29 THEN
      gvpages = gvpages - 1
      put gvpages into field "pages"
      end if
      can anyone fix that code for me so it will remove 1 from the number of pages when they intersect?
      Thanks, andy
        • 1. Re: Trouble with intersects
          Level 7
          What does the rest of the behavior look like? Or is this a movie script?
          Are you declaring gvpages as a property or a global variable?
          Rob
          ___________
          Rob Dillon
          Adobe Community Expert
          http://www.ddg-designs.com
          412.243.9119
          • 2. Re: Trouble with intersects
            andy_scot Level 1
            ive declared the gvpages as a global at the top of the behaviour, i then set the boundaries for the sprite and then added the code previously posted
            • 3. Re: Trouble with intersects
              Level 7
              What is happening now? Does the field "pages" contain anything? Do you
              get an error message? Is this "if" statement in an on enterFrame me
              function?
              I need more to go on before I can suggest a solution.
              Rob
              ___________
              Rob Dillon
              412.243.9119
              • 4. Trouble with intersects
                andy_scot Level 1
                global gvnumbers, gvpages
                on beginSprite me
                pSprite = sprite(me.spritenum)
                pleftBound = 183
                prightBound = 1340
                ptopBound = 100
                pbottomBound = 850
                pMove = 5
                end
                on exitframe me
                pSprite.loch=pSprite.loch+pMove
                if pSprite.loch > prightBound then
                pMove=pMove*-1
                end if
                if pSprite.loch < pleftBound then
                pMove=pMove*-1
                end if
                on mousedown me
                if sprite 45 intersects 29 then
                put gvlives into field "pages"
                end if
                end
                • 5. Re: Trouble with intersects
                  andy_scot Level 1
                  also yes the field pages contains the value 14 at the start so, i just want it so that when the sprite intersects the other one then the number of pages is decreased by one, thanks
                  • 6. Re: Trouble with intersects
                    Level 7
                    Try something like the behavior below. You need to declare property
                    variables for each of the variables that you are defining in the
                    beginSprite function. If you don't do this, then the values won't exist
                    outside that function.
                    I also added another property variable, "movingLeft", this is a boolean
                    variable that you'll need to get your sprite to move properly.
                    property
                    pSprite,pleftBound,prightBound,ptopBound,pbottomBound,pMove,movingLeft
                    on beginSprite me
                    pleftBound = 100
                    prightBound = 700
                    ptopBound = 100
                    pbottomBound = 550
                    pMove = 5
                    movingLeft = false
                    end
                    on exitframe me
                    if pSprite.loch > prightBound AND movingLeft = false then
                    movingLeft = true
                    pMove=pMove*-1
                    end if
                    if pSprite.loch < pleftBound AND movingLeft then
                    movingLeft = false
                    pMove=pMove*-1
                    end if
                    end
                    Rob
                    ___________
                    Rob Dillon
                    412.243.9119
