0 Replies Latest reply on May 28, 2010 1:19 PM by GeorgeWS
    Uploading
    GeorgeWS Level 1
      I have this:
      <mx:Script>
      <![CDATA[
      import flash.net.navigateToURL;
      import com.adobe.images.JPGEncoder; // JPGEncoder class from the ActionScript 3.0 corelib project
      import com.adobe.net.Uploader; // Class used to upload files to a URL
      import flash.filesystem.*;
      import flash.events.*;
      private var file:File; // Used for referencing stored image files
      private var stream:FileStream; // Used for writing JPEG data to an image file
      private var bmd:BitmapData; // Used to store pixels from the Video object
      private var camera:Camera; // Used to referemce a camera
      private const UPLOAD_URL:String = "http://www.mysite.com/programs/ymcochains/ymcochains/bin-debug";
      * Initialization. Checks to see if there is an active camera.
      private function init():void
      if (Camera.getCamera())
      setCamera();
      else
      trace("No cameras are available.");
      * Sets the camera object to reference the default camera. Then
      * uses that camera for the video object's image.
      private function setCamera():void
      camera = Camera.getCamera();
      video.attachCamera(camera);
      camera.addEventListener(ActivityEvent.ACTIVITY, setSize);
      * Sets the size of the video object, based on the size of the camera.
      private function setSize(...args):void
      camera.removeEventListener(ActivityEvent.ACTIVITY, setSize);
      video.width = camera.width;
      video.height = camera.height;
      * Saves the current image in the video object to the preview (bmp) bitmap.
      private function shoot():void
      flasher();
      saveBtn.enabled =
      true;
      bmd =
      new BitmapData(video.width, video.height);
      bmd.draw(video);
      var bmp:Bitmap = new Bitmap(bmd);
      bmp.x = (stage.stageWidth - bmp.width)/2
      shot.source = bmp;
      * Emulates a camera flash effect by filling the screen with white
      * by quickly displaying a full-screen NativeWindow object.
      private function flasher():void
      var windowInitOpts:NativeWindowInitOptions = new NativeWindowInitOptions();
      windowInitOpts.systemChrome = NativeWindowSystemChrome.NONE;
      windowInitOpts.type = NativeWindowType.LIGHTWEIGHT;
      var flashCube:NativeWindow = new NativeWindow(windowInitOpts);
      flashCube.x = 0;
      flashCube.y = 0;
      flashCube.width = Capabilities.screenResolutionX;
      flashCube.height = Capabilities.screenResolutionY;
      flashCube.visible =
      true;
      setTimeout(closeFlash, 100, flashCube);
      * Closes the camera flash NativeWindow.
      private function closeFlash(flashCube:NativeWindow):void {
      flashCube.close()
      * Called when the user clicks the Save button. This method saves the current
      * preview image to a file in the images subdirectory of the application storage directory
      private function save():void {
      file = File.applicationStorageDirectory;
      file = file.resolvePath(
      "images/" + new Date().time.toString() + ".jpg");
      trace(file.nativePath);
      stream =
      new FileStream;
      stream.open(file, FileMode.WRITE);
      var data:ByteArray = getJPEG(bmd);
      stream.writeBytes(data, 0, data.length);
      stream.close();
      * Converts a BitmapData object into JPEG data.
      private function getJPEG(bmd:BitmapData):ByteArray {
      var jpg:JPGEncoder = new JPGEncoder();
      return jpg.encode(bmd);
      * Called when the user clicks the Upload button. Creates an array of the saved files,
      * creates an Uploader object, adds the files to the Uploader object's file list, and then
      * starts the upload.
      private function upload():void
      var uploader:Uploader = new Uploader();
      var dir:File = File.applicationStorageDirectory.resolvePath("images");
      var files:Array = dir.getDirectoryListing();
      for (var i:uint = 0; i < files.length; i++)
      file = files[i];
      if (!file.isDirectory)
      uploader.addFile(file);
      uploader.addEventListener(Event.COMPLETE, uploadCompleteHandler);
      uploader.addEventListener(ProgressEvent.PROGRESS, progressHandler);
      uploader.start(UPLOAD_URL +
      "/upload.cfm");
      * Upload progress handler.
      private function progressHandler(event:ProgressEvent):void
      trace("Progress", event.bytesLoaded, event.bytesTotal);
      * Upload complete handler.
      private function uploadCompleteHandler(event:Event):void
      trace("complete");
      * Called when the user clicks the 'View in browser' button.
      * Displays the web directory containing the uploaded images
      * in the default system web browser.
      private function viewHTML():void
      var urlReq:URLRequest = new URLRequest(UPLOAD_URL + "/uploaded");
      navigateToURL(urlReq);
      </mx:Script>
      Every part works except the upload I get an error:
      Error #2044: Unhandled ioError:. text=Error #2038: File I/O Error. URL: http://www.mysite.comt/programs/ymcochains/ymcochains/bin-debug/upload.cfm
      The upload.cfm is like this:
      <cflile action="upload" filefield="filedate" destoination="c://inetpub/wwwroot/mysite/files/" namecoflict="overwrite" accept="application/octet-stream"/>
      I think its a path issue but am baffled. I see lots of posts but no go..
      Any thoughts would be great
      Im using Air 1.5 and CF 8 I have done this before just forgot what I did to ovecome this error.
      George
