3 Replies Latest reply on May 31, 2010 2:32 PM by 370H55V
    Long pause before a .pdf opens when right-clicking
    JD Best
      When opening a .pdf with Adobe Reader 9.3.2 in Windows XP Explorer by double-clicking it or by right-clicking then selecting Open with Adobe Reader 9, there is a long pause (22 seconds) before it opens.  If I disable then re-enable my local area network connection, these symptoms disappear for a while and the .pdf files seem to open normally (within a second or two). What could be causing this?  When opening a .pdf from within the Adobe Reader program itself, the .pdf files seem to open normally whether the local network connection is enabled or disabled.
        • 1. Re: Long pause before a .pdf opens when right-clicking
          370H55V Level 4
          Do other file types do this? JPG, DOC, XLS, etc.
          I ask because usually what you describe is a Windows Explorer issue, since the right click is fully a windows Graphical User Interface function, and until the Open with... and Reader is selected, the file isn't "handed off" to Adobe.
          Usually when GIU functions slow down this way, it's either something tying up the processor, or a disk fragmentation slowing everything down.
          • 2. Re: Long pause before a .pdf opens when right-clicking
            JD Best Level 1
            Sometimes after a Microsoft Update, doc and xls files open slowly.  Apparently, Microsoft Update keeps resetting the DDE (Dynamic Data Exchange) in the doc and xls file types.  To fix this, I follow the instructions at the following Website:
            Here are the instructions I follow for doc and xls.
            If the problem is ONLY when you double-click on a file to open it. the
            problem is likely due to DDE. It can be fixed by reinstalling, OR this
            Go to Control Panel, Folder Options, File Types, scroll down to and
            select XLS, click Advanced, select Open entry, click the edit Button.
            Now uncheck "Use DDE" and then put your cursor in the Application box,
            arrow all the way to the right and put in "%1" (include the quote
            marks), IF there is /dde remove it. Then OK you way out. Things should
            work quickly again.
            After doing this, doc and xls files open normally again.  But this does not work with pdf files, it has to be something else I haven’t figured out yet.  The Disk Defragmanter Analysis says I don’t have to defrag my C: drive, and the system idle process is at 98% when the file is being opened.
            • 3. Re: Long pause before a .pdf opens when right-clicking
              370H55V Level 4
              If system idle is at 98% then it's definitely not a Reader issue. That means that ALL OTHER processes are only using 2% of your processor.
              I still think it's something in your GUI causing Windows to "think" when you right click a pdf.
