1 Reply Latest reply on May 29, 2010 9:43 AM by redtopia
    CFB won't load after update 1
    redtopia Level 1
      I'm running CFB plugin on Eclipse 3.5.1 on Win 7 x64. I purchased CFB right after update 1 came out, restarted eclipse, entered my key, updated the software, restarted eclipse using the -clean option, and everything worked great. I've been using it for the past week. However, I just restarted eclipse for the first time since I've updated, and it won't load CFB. I get the following error:
      Could not open the editor: No editor descriptor for id com.adobe.ide.editor.CFMLEditor
      org.eclipse.ui.PartInitException: No editor descriptor for id com.adobe.ide.editor.CFMLEditor
          at org.eclipse.ui.internal.EditorReference.createPartHelper(EditorReference.java:598)
          at org.eclipse.ui.internal.EditorReference.createPart(EditorReference.java:462)
          at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:595)
          at org.eclipse.ui.internal.EditorAreaHelper.setVisibleEditor(EditorAreaHelper.java:271)
          at org.eclipse.ui.internal.EditorManager.setVisibleEditor(EditorManager.java:1417)
          at org.eclipse.ui.internal.EditorManager$5.runWithException(EditorManager.java:942)
          at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run(StartupThreading.java:31)
          at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
          at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:134)
          at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:3855)
          at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3476)
          at org.eclipse.ui.application.WorkbenchAdvisor.openWindows(WorkbenchAdvisor.java:803)
          at org.eclipse.ui.internal.Workbench$28.runWithException(Workbench.java:1384)
          at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2316)
          at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2221)
          at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
          at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
          at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:493)
          at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
          at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:113)
          at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:194)
          at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLau ncher.java:110)
          at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.jav a:79)
          at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:368)
          at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
          at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
          at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
          at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
          at java.lang.reflect.Method.invoke(Unknown Source)
          at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:559)
          at org.eclipse.equinox.launcher.Main.basicRun(Main.java:514)
          at org.eclipse.equinox.launcher.Main.run(Main.java:1311)
      Please help!!!
        • 1. Re: CFB won't load after update 1
          redtopia Level 1
          To fix this, I launched eclipse again with the -clean option. CFB asked me to enter a key (which I already had done before I applied update 1). I entered the key again and CFB loaded.
          I had already run eclipse with the -clean option after installing CFB update 1. I double checked to make sure I didn't have to do this each time I restarted eclipse - I quit eclipse and launched it again, and CFB loaded. Everything seems to be working okay now.
