1 Reply Latest reply on Mar 17, 2008 6:56 PM by akiva.kent
    Dynamically populating quiz components
      Is there a way to coordinate PHP and ActionScript to populate the text fields of the quiz templates included with Flash, rather than manually typing in each piece of information?
        • 1. Dynamically populating quiz components
          akiva.kent Level 1
          Did you ever get an answer to your question?
          As a caveat, I don't need to php, just Actionscript 2.0 variables to replace the text that you type into the component. I don't see anything in bindings or parameters in the component. I will try to search out the embedded AS code of the broken apart component to see what the component may use, but it would be helpful if someone has done that already.
