0 Replies Latest reply on May 28, 2010 11:37 PM by athiroy
    run a home page in flex project
    athiroy
      hi
      i have build my flex project using ant task
      my project name is StudentRegistration.
      my mxml file name is StudentRegistation.
      <target name="appcompile" depends="install">
        <mxmlc file="${flexsrc.home}/StudentRegistration.mxml" context-root="/StudentRegistration" keep-generated-actionscript="true" services="${web.home}/WEB-INF/flex/services-config.xml" output="${catalina.home}/webapps/${app.name}/StudentRegistration.swf">
         <compiler.library-path dir="${FLEX_HOME}/frameworks" append="true">
          <include name="${web.home}/WEB-INF/lib/" />
          <include name="${flexsrc.home}/example/" />
         </compiler.library-path>
         <load-config filename="${FLEX_HOME}/frameworks/flex-config.xml" />
         <source-path path-element="${FLEX_HOME}/frameworks" />
        </mxmlc>
      </target>
      <target name="createHtmlWrapper" depends="appcompile">
        <html-wrapper application="${APP_ROOT}/StudentRegistration.mxml" height="1000" width="1000"  output="${catalina.home}/webapps/${app.name}" swf="StudentRegistration" />
      </target>
      i have deploy the Folder StudentRegistration in tomcat.
      just i select the StudentRegistration in tomcat the StudentRegistration page is displays.
      if select StudentRegistration i want to display the homepage.html
      how can i do
      someone help me
      regards
      athi
