6 Replies Latest reply on May 29, 2010 6:09 PM by attackrabbit
    extend using both actionscript and mxml
    attackrabbit
      I have a custom component , called contentblade. It lives in dev.components. I want to lay out its children in mxml , but i need to override some methods , ie , measure etc. I dont want to write all of that inside fx:Script tags. I figured ah this would be simple enough , ive done this  before. So in dev.components i created another directory called contentBlade , and create a new class in that package called ContentBladeBase ,  that extends SkinnableContainer , and implements IUIComponent. My problem is the constructor for .as file never gets called unless a instantiate a new instace inside the ContentBlade.mxml file. Do i HAVE to #include the as file into the mxml file ? I assumed ,  xmlns="dev.components.contentBlade.* , namespace declaration would take care of that. Im trying to streamline my dev process.
      Main.mxml
      <mx:Application
                      xmlns:fx="http://ns.adobe.com/mxml/2009"
                      xmlns:mx="library://ns.adobe.com/flex/mx"
                      xmlns:ay="dev.components.*"
                      layout="absolute"
                      width="100%"
                      height="100%"
                      frameRate="30"
                      viewSourceURL="./source/public.txt">
          <mx:Canvas id="base"
                     width="100%"
                     height="100%"
                     autoLayout="false">
              <ay:ContentBlade/>
          </mx:Canvas>
      </mx:Application>
      ContentBlade.mxml
      <s:SkinnableContainer
                          xmlns="dev.components.contentBlade.*"
                          xmlns:mx="library://ns.adobe.com/flex/mx">
      </s:SkinnableContainer>
      ContentBladeBase.as
      package dev.components.contentBlade
          import flash.geom.Vector3D;
          import mx.core.DesignLayer;
          import mx.geom.TransformOffsets;
          import spark.components.SkinnableContainer;
          import flash.geom.Matrix3D;
          import flash.display.DisplayObjectContainer;
          import mx.core.IVisualElement;
          import flash.events.Event;
          import flash.geom.Matrix;
          import mx.core.IUIComponent;
          public class ContentBladeBase extends SkinnableContainer implements IUIComponent
              public function ContentBladeBase()
                  super();
                  trace( "NEW ContentBladeBase" );
        • 1. Re: extend using both actionscript and mxml
          UbuntuPenguin Level 4
          Could you explain better what you are trying to accomplish ?  And you don't need to have "implements IUIComponent" , the SkinnableComponent class extends UIComponent which implements IUIComponent.
          • 2. Re: extend using both actionscript and mxml
            attackrabbit Level 1
            absolutely. I have a need for a custom component that will contain several child components. The custom component will have a spark skin. The custom component i have create , as you can see , extends SkinnableContainer. From my reading i felt this was a good spark component to extend from as im going to have several , possibly unrelated spark components as children of this component. I want to lay the children out within the mxml , for example
            ContentBlade.mxml
                 <s:Button/>         <-------------------etc
                 <mx:DataGrid/>   <------------------- etc
            I also need to have several of the skinnable containers inherited methods , overriden , for example measure() , draw() , onCreationComplete(). etc.
            I want explicit control over those. Now i have seen and written myself , in the past , custom componets soley in actionscript. and just point the namespace to the actiosncript class. I have also written components , solely , in mxml , using the fx:Script tag to define which methods i want to override. In this case i want have my custom componet use both , the .as i posted above , and the mxml. I want ContentBlade.mxml , and ContentBladeBase.as to be the same thing. I could write the whole component is as , but its so much faster for me to create all of the children in mxml. Does that make sense ?
            • 3. Re: extend using both actionscript and mxml
              I'm not sure the motivation behind making a class in mxml and another in as ?  Just make the class in mxml , and override the methods you want in the fx:Script block.
              • 4. Re: extend using both actionscript and mxml
                because A) its ugly and cumbersome , and B) Im using Flex Builder 3 , and the flex 4 sdk spark libs fx:Script declarations no longer highlight , syntax check , or color. Its just this big grey mass of text. Let me ask you , or if anyone else cares to chime in , this ... if you needed to have a component that contained a drop down , a grid of images , and a text field , and you need to be able to style each one of these child components with it own spark skin , and you need these child components and the parent compents to basic layout in a liquid manner on resize , how would you do it ?
                • 5. Re: extend using both actionscript and mxml
                  Each component would have its own skin class.  You don't need to override anything to do this.  The logic behind setting up the layout and skinning can be seperated.
                  SuperContainer.mxml
                  <SkinnableContainer>
                    <Layout>
                     <VerticalLayout/>
                    </Layout>
                     <DropDown width="20%" height="10%" skinClass="com.ubu.skins.dropDownSkins.SomeSkinClass" />
                     <List dataProvider={dp} height="80%" width="100%" itemRenderer="com.ubu.renderers.AwesomeRenderer">
                       <Layout>
                         <TileLayout />
                       </Layout>
                     </List>
                     <TextInput width="110" skinClass="com.ub.skins.TextSkins.SuperSkin" />
                  </SkinnableContainer>
                  Meanwhile, in another piece of code.
                  <custom:SuperContainer skinClass="com.ubu.containerSkins.SuperContainerSkin" width="100%  height="100%"/>
                  Of course , you could make that your component and THEN create the skin class , but you get the picture.
                  If this post was helpful please mark it as such.
                  • 6. Re: extend using both actionscript and mxml
                    thanks penguin. I suppose what i was looking for was some form of multiple inheritance. But , alas , it appears as though the only way to do it is to use the include directive , and thats just ugly. Thanks for you help !!
