4 Replies Latest reply on Jun 14, 2010 2:51 PM by grumpytaco1
    Button label property changes
    grumpytaco1
      The buttons I have built work fine when I test them in flash catalyst but once I deploy it to the server they do funny things. In some browsers the font on the button changes when rolled over or clicked on. In other browsers the bold property changes.
      The buttons were created with the button component in flash catalyst. The text has been identified as a label. The label properties of font are set as handwriting dakota, regular, black for the up and over state. The label properties are set as arial regular white on the down and disabled states. When I published the swf for webserver, I chose to embed the fonts.
      However when viewing the deployed version on some computers the text on some of the buttons change to bold when rolled over or after they become enabled after being disabled. In some computers it is the font that changes in this way.
      Thanks for any suggestions or help.
        • 1. Re: Button label property changes
          Peter Flynn (Adobe) Adobe Employee
          It sounds like you may have hit a bug in the font embedding features of Flash Catalyst.  Would you be willing to share your project with us to take a look at it?
          The best way to do this is to log on to Acrobat.com (your forum login should work there) and upload your .fxp file, then share the file with me -- pflynn at adobe.com.
          - Peter
          • 2. Re: Button label property changes
            Thanks for passing along the file!  I can see the problem you're talking about on at least one of my computers, too.  I'll have one of our text-rendering experts look at this and then get back to you as soon as we know more.
            - Peter
            • 3. Re: Button label property changes
              Back with results!
              We've identified a bug in the Flex SDK that is causing this text rendering problem.  The upshot: you should be able to avoid this issue by replacing Arial with a similar-looking font like Helvetica (though not Verdana, unfortunately).
              The details: this bug occurs when the same text object transitions between an embedded font (the handwriting font you're using in the Up/Over states) and a non-embedded font (Arial in your Down/Disabled states).  We're planning to fix this for the next release.  To avoid the bug in the meantime, you'd want to have the text object always use embedded fonts, or always use non-embedded fonts.  Most fonts are embedded, since that's the only way to be sure everyone who views your site will see the correct font.  But a few fonts (like Arial and Verdana) are not embedded, since they're essentially guaranteed to be on any computer that has Flash.
              Just to be clear, it's perfectly fine to mix the two types of fonts in the same Catalyst project.  You just don't want to have a single text object that switches between the two types during a transition -- in Catalyst 1.0, that will risk hitting this bug.
              I hope that helps, and sorry for the trouble this caused you!  Let me know if you have any questions or are having trouble with the workaround.
              - Peter
              • 4. Re: Button label property changes
                grumpytaco1 Level 1
                Great! Sounds like an easy fix. Thanks so much for all the info and help!
                Sarah
