18 Replies Latest reply on Jun 19, 2010 1:01 AM by benjy L.
    problem with serial key HELP
    benjy L.
      Hi, today I'm installing Dreamweaver, but my serial do not work so I search for that and then I see why, maybe because I'm in asia pacific and I ask a US serial number,
      but at the start, of the setup they don't ask me the language, why?
      or I maybe need to ask again a serial number for asia pacific or english(international)
        • 1. Re: problem with serial key HELP
          John Waller Adobe Community Professional & MVP
          Are you installing a full version of Dreamweaver or an upgrade version?
          If an upgrade, are you upgrading from a suite?
          • 2. Re: problem with serial key HELP
            benjy L. Level 1
            I'm installing a full version Dreamweaver CS4 student edition,
            • 3. Re: problem with serial key HELP
              hans-g. Adobe Community Professional & MVP
              Hi benjy,
              just to see clearly a question (technical terms tranlated from German DW): Was your registration-number generated by entering the authorization-number in a Adobe-form?
              Hans-G.
              • 4. Re: problem with serial key HELP
                benjy L. Level 1
                I buy it in australia and I live in New caledonia,(french country) then I got a french(sorry it's not a US key) key ( I get the key coupon and other things in the serial number form ) and I didn't see I need a asia pacific key
                • 5. Re: problem with serial key HELP
                  Hi benjy,
                  cause you couldn't manage the registration, I forwarded this message to the (German) Support:
                  Guten Tag,
                  als eifriger Nutzer des DW-Forums bin ich auf die o.g. Frage gestossen. Weil ich nicht glauben kann, dass der Fragesteller meine Antwort verstehen kann, bitte ich Sie dies für mich zu tun. Hier der Link zum thread: http://forums.adobe.com/thread/649658?ts. In der Hoffnung keine Fehlbitte getan zu haben verbleibe ich mit freundlichen Grüssen ...
                  The answer was till now: Ihrer Anfrage wurde die Vorgangsnummer 0181616702 zugeteilt.
                  I am sure ADOBE will contact me by email, or will give an answer here in the forum.
                  Hans-G.
                  • 6. Re: problem with serial key HELP
                    benjy L. Level 1
                    thanx, I used a translator, and then I was able to read your message, and then THANX you, I'm waiting the answer
                    • 7. Re: problem with serial key HELP
                      I've got this answer. I'll try to tranlate the most importent sentences:
                      Header 1Header 2
                      Grundsätzlich gibt es noch einige Fragen.
                      Wenn bei der Installation die Seriennummer
                      nicht funktioniert kann es verschiedene
                      Faktoren haben.
                      Wo hat er das Produkt gekauft?
                      Welche Sprache hat er gekauft und welche Installiert?
                      Gibt es schon eine Version auf seinem PC?
                      Welches Betriebssystem nutzt er?
                      Der Kunde sollte auf jeden Fall den US Support kontaktieren.
                      Hier werden die Kollegen die Seriennummer prüfen und
                      ihm natürlich auch bei der Installation behilflich ein.
                      Basically, there are still some questions.
                      There are different factors if by installing
                      the Serial number does not work.
                      Where did he buy the product?
                      What language he has bought and which has he installed?
                      Is there already a version on his PC?
                      What operating system uses he?
                      The customer should in any case contact the U.S. support.
                      Here the colleagues will check the serial number and
                      will assist him of course, in installing.
                      and:
                      Sehr geehrter Hans-G.
                      vielen Dank für Ihre Anfrage. Wir freuen uns das Sie mit soviel Interesse zur Lösung vieler Fragen beitragen. B
                      itte beachten Sie unsere unten stehende Antwort auf Ihre Anfrage. Um Ihren gesamten aktuellen Bearbeitungsverlauf einsehen zu können, besuchen Sie unser Web Support Portal unter
                      http://www.adobe.com/go/de_supportportal/
                      Falls Sie beim Login Schwierigkeiten haben, klicken Sie bitte auf
                      http://www.adobe.com/go/tn_16721
                      Dort finden Sie Servicehinweise zur Adobe ID und häufig gestellte Fragen der Adobe Mitglieder.
                      Vielen Dank für Ihre Anfrage
                      Adobe Technischer Support
                      Bearbeitungsverlauf: 181616702
                      HCH a little bit
                      Hans-G.
                      • 8. Re: problem with serial key HELP
                        benjy L. Level 1
                        thanx a lot:
                        I buy the product in australia,
                        I install the program as french,
                        no I don't have a version of Dreamweaver,
                        I use Windows vista,
                        and then the key i need is a asia pacific one
                        and I got a french one so if they say "contact the US support"
                        I need the contact the French support
                        (cause I did a mistake it's not a US key but a French one)
                        thanx
                        • 9. Re: problem with serial key HELP
                          Bonjour benjy L.,
                          pour procéder à cette question (je suis en vacances bientôt), je propose de contacter le service de support française. Parce que vous avez accès au forum, il doit être possible également et ici:
                          Les liens Internet sont:
                          http://www.adobe.com/fr/ --> Support --> Contacter le support Adobe -->
                          https://www.adobe.com/cfusion/support/index.cfm?event=portal&loc=fr
                          Vous pouvez se référer à le nombre de ma question "181616702" et notre débat ici: http://forums.adobe.com/message/2865866#2865866.
                          Bonne chance!Hans-G.
                          • 10. Re: problem with serial key HELP
                            benjy L. Level 1
                            thanx you! (you speak french?)
                            I gonna ask them =>
                            • 11. Re: problem with serial key HELP
                              had you been successful? And for the French: we have many French friends and we maintain a jumelage, therefore. But, do you prefer the English language?
                              Hans-G.
                              • 12. Re: problem with serial key HELP
                                benjy L. Level 1
                                Oh sorry... humm,
                                my problem is not finish yet... I can't find Emails or things to contact the french support
                                how can i?
                                • 13. Re: problem with serial key HELP
                                  Hi benjy,
                                  quote: "I can't find Emails or things to contact the french support".You only need to click on my links above one after the other and fill in the appropriate fields. In the large text box where you have to describe your problem, you can also specify my thread number.
                                  Ok,
                                  1. http://www.adobe.com/fr/ --> Support --> Contacter le support Adobe -->
                                  2. from here it's your turn: http://www.adobe.com/fr/aboutadobe/contact.html
                                  3.https://www.adobe.com/cfusion/support/index.cfm?event=membership&returnURL=/cfusion/suppor t/index.cfm?event=portal&loc=fr_fr
                                  Here you have to log in, after that you can
                                  4. fill in the form
                                  5. You can give a reference to the ADOBE-people with my correspondence.thread number:
                                  That should work at last.
                                  Hans-G.
                                  • 14. Re: problem with serial key HELP
                                    Hi benjy,
                                    I modified my answer.
                                    Hans-G.
                                    • 15. Re: problem with serial key HELP
                                      benjy L. Level 1
                                      Hi Hans,
                                      are you talking about here?:
                                      • 16. Re: problem with serial key HELP
                                        you disturb me a little. Do you need help for a Frech or a English version?
                                        But to show you what's possible:
                                        1.step:
                                        2. You can use this form, or you can try a chat, that what I did for you in this way:
                                        3. I sent this message in the chat:
                                        I'll try to help a customer in your forum but it seems he doesn't understand me. Could you answer in this thread?
                                        http://forums.adobe.com/message/2906235#2906235
                                        I'll give this activity of mine to him, ok?
                                        Best regards
                                        Hans-G.
                                        Now I hope it will help!
                                        Hans-G.
                                        • 17. Re: problem with serial key HELP
                                          Hi Benjy,
                                          here my chat with ADOBE Help:
                                          Thank you for choosing Adobe. A representative will be with you shortly.
                                          Your estimated wait time is 0 minute(s) and 3 second(s) or longer as there are 1 customer(s) in line ahead of you.
                                          You are now chatting with Balaji.
                                          Hello! Welcome to Adobe Customer Service.
                                          Balaji: Please allow me a moment to review your request.
                                          Hello Hans-G.
                                          hans-g.: Hello Balaji!
                                          Balaji: I understand that you need to help with the our adobe customer for his query in our forum. Is that right?
                                          hans-g.: Yes.
                                          Balaji: May I have your full name and email address that is registered with Adobe?
                                          hans-g.: Hans-G. xxxxx and xxxxxxxx
                                          Balaji: Thank you for the information Hans-G.
                                          Balaji: Please wait while I check with your email address.
                                          Balaji: I see that it's a technical issue Hans-G.
                                          Balaji: I will escalate this call to my technical support team. So that you will get a resolution for that.
                                          harts-g.: Ok, but my wish is YOU wil give a helpful answer to benjy, would you please do it?
                                          hans-g.: "I will escalate this call to my technical support team. So that you will get a resolution for that."
                                          Balaji: I understand that Hans-G.
                                          Balaji: Is there anything else I can help you with?
                                          hans-g.: Oops, as I said before "hold me out" please give your answer to benjy, ok.
                                          hans-g.: No, that's all, thank you very much, and my best regards to you and your team, I am a dreamwaever, :-)))
                                          Balaji: Please ask him to contact us through our live support.
                                          · You are welcome.
                                          Balaji: We'd like to hear your feedback! Please dick on the 'Close' button on the upper right to complete a • short survey. Use the 'Email' button to send yourself this chat transcript if you'd like.
                                          Balaji: Thank you for contacting Adobe. Goodbye!
                                          hans-g.: Did you see my thread here:
                                          http://forums.adobe.com/message/2906471#2906471
                                          Balaji; yes, I understand that the customer is having issues with the serial number. Is that right?
                                          hans-g.: I fear he doesn't know whether he is French or Endlish/American. ;-)
                                          hans-g.: Ok, send him our talk. Goodbye!
                                          Balaji: You are welcome.
                                          · We'd like to hear your feedback! Please dick on the 'Close' button an the upper right to complete a short survey. Use the 'Email' button to send yourself this chat transcript if you'd like.
                                          .Thank you for chatting with us. Please click the "Close" button on the top right of the chat window to teil us how we didtoday.
                                          All the best Hans-G.
                                          • 18. Re: problem with serial key HELP
                                            benjy L. Level 1
                                            I just send a question to adobe then now I'm waiting an answer...
                                            thanx a lot!
