3 Replies Latest reply on May 30, 2010 9:29 PM by kglad
    Placing an array of objects onto stage
    HandofNerds
      I am trying to place an array of objects onto a stage where they drop vertically. I have been able to do it by placing the array objects into an object called "bag" but have found that the bag object only contains the last array object id so I can not apply actions to various array objects.
      Also my objects do not loop and only appear once.
      Below is the code so far.
      var tempArray:Array = new Array(); // Stores randomised values
      var bagArray:Array = new Array("gslow_id","gshigh_id","glow_id","ghigh_id","gdiv_id",
        "gcall_id","gbust_id","gbull_id","gboom_id","gbear_id"); // List of bag names
      function createBags() {
      if (tempArray.length == 0) { // check if array is empty
           for (var i:Number = 0; i < targets; i++) { // for loop - creat variable bagName to the value of targets
           var bagName: String = bagArray[i];
           var depthLevel:Number = this.getNextHighestDepth();
           // attach movies to time line
           this.attachMovie(bagName, bagName, depthLevel, {_x:random(350) + 100, _y:random(0) + spacing});
           spacing += 45;
           tempArray.push(bagName);
           //trace(tempArray);
           bag = _root[bagName]; // create a bag object contain the bagName variable
           //trace (bag);
           bag.onEnterFrame = function() {
                if (this._x < 570 && this._y > 0) {
                this._y += speed * random(8);
                } else {
                this._x = random(500);
                } // end if (this._x < 570 && this._y > 0)
           } // end bag.onEnterFrame ()
      bag.onPress = function() {
      // if bag is pressed select action
      //trace (bag);
      xPos = this._x
      yPos = this._y
      unloadMovie(this);
      score += 1000
      scoreText_txt.text = score;
      //trace(score);
      checkScore();
      } // end bag.onPress ()
      //trace(targets);
      //trace(bagName);
      } // end for (var i:Number = 0; i < targets; i++)
      } // end if (tempArray.length == 0)
      } // End createBags()
        • 1. Re: Placing an array of objects onto stage
          try:
          var bagA:Array=[];
               var bag:MovieClip = this.attachMovie(bagName, bagName, depthLevel, {_x:random(350) + 100, _y:random(0) + spacing});
            bagA.push(bag);
               spacing += 45;
               //trace (bag);
                    } else {
          //trace (bag);
          xPos = this._x
          yPos = this._y
          unloadMovie(this);
          score += 1000
          //trace(score);
          checkScore();
          //trace(targets);
          //trace(bagName);
          • 2. Re: Placing an array of objects onto stage
            HandofNerds Level 1
            Thanks but it did not work
            I decided to create a movie clip call bag with an identifier bag_mc in my library and added the 10 different movie clips to on each frame.
            and have changed my code to this but now I only get the same movie clip each time. Plus it only rotates once
            var counter:Number = 0;
            var bagName: String = "bag_mc" + (String)(counter);
            //trace(bagName);
            this.attachMovie("bag_mc", bagName, depthLevel, {_x:random(350) + 100, _y:random(0) + spacing});
            spacing += 45;
            _root[bagName].bagNbr = counter;
            counter++;
            _root[bagName].gotoAndStop(1);
            //trace (bag);
            } else {
            //trace (bag);
            xPos = this._x
            yPos = this._y
            unloadMovie(this);
            score += 1000
            //trace(score);
            checkScore();
            //trace(targets);
            //trace(bagName);
            • 3. Re: Placing an array of objects onto stage
              the code i gave works.
              but, you're welcome.
