0 Replies Latest reply on May 30, 2010 4:44 PM by Val_007_abc
    video streaming doesnt work((
    Val_007_abc
      Hello all and thank you for your time!
      I am really a newbie with Stratus and Flex so I am really sorry for the code.
      I wanted to create an application that captures&sends video from one computer to another,and display it on the another computer.
      I couldn't make Video Phone application work((.
      This is my program,
      first one user who sends should click on "register button" and receive his ID as text , and copy the ID received to text file, so I manually
      go to another computer that receives the stream and paste it there. This part goes okay, I receive the ID from Stratus,
      and then i click on "start sending". It then publishes "media" channel.
      Then I go to another computer and run the same program,click "register", then insert the ID that I copied into the INPUTTEX field.
      Than I should see the picture- BUT- ALAS- nothing happen!
      And I really don't know why- help very much appreciated!
      [CODE]
      <mx:Application
      xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute">
      <mx:Script>
      <![CDATA[
      import mx.controls.Alert;
      import mx.charts.chartClasses.StackedSeries;
      import mx.formatters.DateFormatter;
      import flash.sampler.Sample;
      import mx.events.SliderEvent;
      import mx.events.FlexEvent;
      import mx.collections.ArrayCollection;
      import mx.events.ItemClickEvent;
      Bindable] private var connectUrl:String = "rtmfp://stratus.adobe.com";
      private const DeveloperKey:String = "58e0cb26b7b7a2188ea8bd14-1ed8f38ca054";
      private const WebServiceUrl:String = "http://109.253.7.170/test.php";
      private var netConnection:NetConnection;
      private var listenerStream:NetStream;
      private var controlStream:NetStream;
      private var outgoingStream:NetStream;
      private var incomingStream:NetStream;
      // private var idManager:AbstractIdManager;
      private var remoteVideo:Video;
      private var sendStream:NetStream;
      private var recvStream:NetStream;
      Bindable] private var loginState:int;
      private const LoginNotConnected:int = 0;
      private const LoginConnecting:int = 1;
      private const LoginConnected:int = 2;
      private const LoginDisconnecting:int = 3;
      var the_id:String = new String("");
      private function test():void {
      /*var camera:Camera = Camera.getCamera();
      if (camera) {
      videoDisplay.attachCamera(camera);
      } else {
      Alert.show("You don't seem to have a camera.");
      public function alert_the_user():void {
      Alert.show(
      "the lilies are blue");
      public function register():void
      netConnection =
      new NetConnection();
      netConnection.addEventListener(NetStatusEvent.NET_STATUS, netConnectionHandler);
      netConnection.connect(connectUrl +
      "/" + DeveloperKey);
      loginState = LoginConnecting;
      // Alert.show("Connecting to " + connectUrl + "\n");
      private function netConnectionHandler(event:NetStatusEvent):void
      //Alert.show("NetConnection event: " + event.info.code + "\n");
      switch (event.info.code)
      case "NetConnection.Connect.Success":
      Alert.show(netConnection.nearID);
      break;
      case "NetConnection.Connect.Closed":
      // Alert.show("CONNECTION CLOSED");
      break;
      case "NetStream.Connect.Success":
      // we get this when other party connects to our control stream our outgoing stream
      // Alert.show("CONNECTION FROM"+ event.info.stream.farID );
      break;
      case "NetConnection.Connect.Failed":
      // Alert.show("CANNOT CONNECT");
      break;
      case "NetStream.Connect.Closed":
      // Alert.show("CLOSED");
      break;
      private function outgoingStreamHandler(event:NetStatusEvent):void
      //status("Outgoing stream event: " + event.info.code + "\n");
      case "NetStream.Play.Start":
      outgoingStream.send(
      "onIncomingCall", "khkhjhkjh");
      break;
      private function incomingStreamHandler(event:NetStatusEvent):void
      //status("Incoming stream event: " + event.info.code + "\n");
      case "NetStream.Play.UnpublishNotify":
      Alert.show(
      "hangup");
      break;
      public function start_send():void
      //creating a send stream if the registartion has been successfull
      sendStream =
      new NetStream(netConnection, NetStream.DIRECT_CONNECTIONS);
      sendStream.addEventListener(NetStatusEvent.NET_STATUS,outgoingStreamHandler);
      sendStream.publish(
      "media");
      sendStream.attachAudio(Microphone.getMicrophone());
      sendStream.attachCamera(Camera.getCamera());
      Alert.show(
      "creating the sending stream");
      public function start_receive():void
      Alert.show(
      "start receive");
      //recvStream = new NetStream(netConnection,the_id);
      recvStream =
      recvStream.addEventListener(NetStatusEvent.NET_STATUS, incomingStreamHandler);
      recvStream.play(
      "media");
      remoteVideo =
      new Video();
      remoteVideo.width = 320;
      remoteVideo.height = 240;
      remoteVideo.attachNetStream(recvStream);
      remoteVideoDisplay.addChild(remoteVideo);
      //remoteVideoDisplay.play();
      public function get_id_from_text():void
      the_id=get_id_textinput.text;
      Alert.show(the_id.toString());
      </mx:Script>
      <mx:Button x="368" y="273" label="Register and get ID" click="register()" id="label2" height="52" width="164"/>
      <mx:Button x="25" y="303" label="start sending" id="send_button" click="start_send()"/>
      <mx:Button x="178" y="303" label="start receiveing" id="rec_button" click="start_receive()"/>
      <mx:TextInput x="351" y="122" width="232" id="get_id_textinput"/>
      <mx:Label x="368" y="96" text="the id of we should listen to" width="215"/>
      <mx:VideoDisplay x="25" y="23" width="269" height="231" id="remoteVideoDisplay"/>
      </mx:Application>
      [/CODE]
