7 Replies Latest reply on Jun 3, 2010 5:56 AM by BhaskerChari
    Hierarchical Arraycollection
    Yoni_Hillel_Barak
      Hi everybody. I have the following arraycollection structure:
              public var dpac:ArrayCollection = new ArrayCollection ([
                  { date:"01/01/2006", cash;50000,
                    stocks:198192, retirement:130101,
                    home:750000, other:19148 },
                  { date:"02/01/2006", cash:50000,
                    stocks:210309, retirement:143707,
                    home:760000, other:19493 },
                  { date:"04/01/2006", cash:50000,
                    stocks:292269, retirement:242596,
                    home:770000, other:21445 }]);
      As you can see, values are Hard-Coded. I want to assign the values of "date", "cash" and all the others during the run of the program. How can I create an arraycollection with this structure that will be dynamic and not hard coded?
      Sorry if this is very basic stuff, I'm new to flex.
        • 1. Re: Hierarchical Arraycollection
          BhaskerChari Level 4
          Try to use the application code below:
          <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" creationComplete="loadData();" layout="absolute">
          <mx:Script>
            <![CDATA[
             import mx.collections.ArrayCollection;
             import mx.rpc.xml.SimpleXMLDecoder;
             private var loader:URLLoader = new URLLoader();
             public var dpac:ArrayCollection = new ArrayCollection();
             private function loadData():void
              var request:URLRequest = new URLRequest();
              request.url = "data.xml";
              loader.load(request);
              loader.addEventListener(Event.COMPLETE,dataLoadComp);
             private function dataLoadComp(event:Event):void
              var xml:XML = new XML(loader.data);
              var xmlDoc:XMLDocument = new XMLDocument(xml);
              var decoder:SimpleXMLDecoder = new SimpleXMLDecoder(true);
              var obj:Object = decoder.decodeXML(xmlDoc);
              dpac = obj.root.item as ArrayCollection;
          </mx:Script>
          </mx:Application>
          Below are your data.xml contents:::
          <root>
          <item>
          <date>01/01/2006</date>
          <cash>50000</cash>
          <stocks>198192</stocks>
          <retirement>130101</retirement>
          <home>750000</home>
          <other>19148</other>
          </item>
          <item>
          <date>02/01/2006</date>
          <cash>50000</cash>
          <stocks>210309</stocks>
          <retirement>143707</retirement>
          <home>760000</home>
          <other>19493</other>
          </item>
          <item>
          <date>04/01/2006</date>
          <cash>50000</cash>
          <stocks>292269</stocks>
          <retirement>242596</retirement>
          <home>770000</home>
          <other>21445</other>
          </item>
          </root>
          If you are using any backend as source for data then process the request on serverside and return the result in xml format to flex and use in the same fashion as above.
          If this post answers your question or helps, please kindly mark it as such.
          Bhasker Chari
          • 2. Re: Hierarchical Arraycollection
            Yoni_Hillel_Barak Level 1
            I don't want to get the data from external xml. I have an ABAP program that can communicate with a compiled SWF file through a unique interface.I've used it up until now to create charts. What I did was this: I created an arraycollection and 3 or 4 variables of type string, I used the arraycollection as the datasource for the chart and the variables as the Yfield and Xfield of each series.
            It looked like this:
            private var ds;arraycollection
            private var sales;string
            private var forecst;string
            private var date;string
            and then:
            <mx:columnchart dataprovider="ds"
            <mx:lineseries dataprovider="ds" xField="date" yField="sales"
            <mx:lineseries dataprovider="ds" xField="date" yField="forecast"
            very simple stuff as you can see.
            then, during the run of the abap program, I have an interface in which I can "talk" to the flex swf in the following way:
            "date = 12.03.09", sales = 1, forecast = 2"
            "date = 13.03.09", sales = 2, forecast =3"
            "date = 14.03.09", sales = 3, forecast = 4"
            And then i get a chart that displays 3 weeks (12-14.03.09) and their respected sales and forecasts.
            My question is: is there a way to create a structure that is variable-based, like the one I showed here, with an structure like the one in my original post?
            • 3. Re: Hierarchical Arraycollection
              How do you get the following values into flex.
              Do u get the above values in strings ...can you please post the function or code in your flex app where you capture these values in Flex.
              Bhasker Chari
              • 4. Re: Hierarchical Arraycollection
                Here is the code of my flex program:
                    <mx:Script>
                        <![CDATA[
                            import mx.events.EffectEvent;
                            import mx.charts.ChartItem;
                            import mx.charts.HitData;
                            import mx.charts.chartClasses.IAxis;
                            import mx.charts.chartClasses.Series;
                            import mx.charts.series.ColumnSet;
                            import mx.charts.series.items.ColumnSeriesItem;
                            import mx.utils.StringUtil;
                            import sap.FlashIsland;
                            [Bindable]
                            public var dataSource:ArrayCollection;
                            [Bindable]
                            public var WeekLbl:String;
                            [Bindable]
                            public var Store_Stock:String;
                            [Bindable]
                            public var Promotion:String;
                public function initApp():void
                                  FlashIsland.register(this);
                            private function linearAxis_labelFunc(item:Object, prevValue:Object, axis:IAxis):String {
                                return numberFormatter.format(item);
                    </mx:Script>
                   <mx:NumberFormatter id="numberFormatter" precision="0" />
                    <mx:ColumnChart id="columnChart"
                            dataProvider="{dataSource}"
                            width="100%"
                            height="100%">
                        <mx:horizontalAxis>
                            <mx:CategoryAxis id="ca" categoryField="{WeekLbl}" />
                        </mx:horizontalAxis>
                        <mx:verticalAxis>
                            <mx:LinearAxis labelFunction="linearAxis_labelFunc" />
                        </mx:verticalAxis>
                        <mx:horizontalAxisRenderers>
                            <mx:AxisRenderer axis="{ca}" />
                        </mx:horizontalAxisRenderers>
                        <mx:series>
                            <mx:LineSeries
                                      showDataEffect="slideIn"
                                    xField="{WeekLbl}"
                                    yField="{Store_Stock}"
                                    displayName="Store Stock"
                                    form="curve"
                                    lineStroke="{s1}">
                            </mx:LineSeries>
                            <mx:LinenSeries
                                      showDataEffect="slideIn3"
                                    xField="{WeekLbl}"
                                    yField="{Promotion}"
                                    displayName="Promotion" >
                            </mx:LinenSeries
                        </mx:series>
                        <mx:seriesFilters>
                            <mx:Array />
                        </mx:seriesFilters>
                    </mx:ColumnChart>
                            <mx:Legend dataProvider="{columnChart}" direction="horizontal"/>
                </mx:Application>
                In this program, I have 3 variables I assign values to during the run of the abap program: Store_Stock, Promotion and WeelLbl. All of the belong to the same "father", dataSource of type arraycollection.
                • 5. Re: Hierarchical Arraycollection
                  Where your dataSource ArrayCollection gets populated in your Flex application...I want the block of code where this dataSource ArrayCollection is set.
                  Bhasker Chari
                  • 6. Re: Hierarchical Arraycollection
                    The datasource gets populated during the run of the Abap program. The Abap program gets the and sends it to the Flex App.
                    • 7. Re: Hierarchical Arraycollection
                      Ofcourse the date gets populated during the run of the Abap program but how do you identify or capture the event that the data is loaded into flex application.
                      Bhasker
