6 Replies Latest reply on Jun 3, 2010 4:03 AM by Jayagopal Flex
    Tab Navigator Problem
    Jayagopal Flex
          I have a tab navigator in which i have loaded five canvas. I want the canvas to be loaded after clicking the confirm box.Please give me a code for this.
      Reagrds,
      Jayagopal P.S
        • 1. Re: Tab Navigator Problem
          BhaskerChari Level 4
          Can you post the code that you are working...?
          Bhasker Chari
          • 2. Re: Tab Navigator Problem
            TanweerHq Level 2
            This is a simple solution. You need to chaneg the tabnavigator index. Thats it..Please find the example below :
            tb1.selectedIndex = index you required ; //tb1 is the id of your tab navigator
            Please mark as answer if this is correct
            • 3. Re: Tab Navigator Problem
              Jayagopal Flex Level 1
              <mx:Application
              xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute" creationComplete="init()">
              <mx:Script>
              <![CDATA[
              import mx.events.CloseEvent;
              import mx.events.DataGridEvent;
              import mx.events.ListEvent;
              import mx.controls.Alert;
              public var flag:Boolean=false;
              public function test(evt:Event):void
              if(flag==true)
              evt.preventDefault();
              else
              Alert.show(
              "Do you want to navigate away from this page","Testing",Alert.YES|Alert.NO,this,Confirmfile,null,Alert.OK);
              public function Confirmfile(obj:CloseEvent):void
              if(obj.detail==Alert.OK)
              flag=
              true;
              addEventListener(MouseEvent.CLICK,test);
              else
              flag=
              false;
              </mx:Script>
              <mx:TabNavigator width="103" change="test(event)" id="tabone">
              <mx:Canvas label="First Canvas" width="100%" height="100%">
              <mx:Label text="First Canvas"/>
              </mx:Canvas>
              <mx:Canvas label="Second Canvas" width="100%" height="100%">
              <mx:Label text="Second Canvas"/>
              </mx:Canvas>
              <mx:Canvas label="Third Canvas" width="100%" height="100%">
              <mx:Label text="Third Canvas"/>
              </mx:Canvas>
              </mx:TabNavigator>
              </mx:Application>
              Here i need to display the canvas only after getting the confirmation from alert.In default it shows the alert box after loding the canvas.
              • 4. Re: Tab Navigator Problem
                TanweerHq Level 2
                <mx:Application
                xmlns:mx="
                <mx:Script>
                <![CDATA[
                import
                import
                import
                import
                public
                public
                if
                else
                Alert.show(
                "data", "title",
                Alert.OK | Alert.CANCEL,
                this,
                alertListener,
                null, Alert.OK);
                public
                if
                true
                else
                flag=
                false
                private
                function alertListener(e:CloseEvent):void
                if(e.detail = Alert.OK)
                //canvas visibility will be set here
                </mx:Script>
                <mx:TabNavigator
                <mx:Canvas
                <mx:Label
                </mx:Canvas>
                <mx:Canvas
                <mx:Label
                </mx:Canvas>
                <mx:Canvas
                <mx:Label
                </mx:Canvas>
                </mx:TabNavigator>
                </mx:Application>
                flag=
                (flag==true)
                mx.controls.Alert;
                mark as answer if it helps you
                • 5. Re: Tab Navigator Problem
                  Hi JayaGopal,
                  Please find the working code below...Had to do a bit of work
                  If this post answers your question or helps, please kindly mark it as such.
                  <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute" creationComplete="init()">
                  <mx:Script>
                  <![CDATA[
                    import mx.events.IndexChangedEvent;
                    import mx.controls.TabBar;
                    private var clickedTabIndex:int = -1;
                    private var prevTabIndex:int = 0;
                    public function init():void
                     tabone.addEventListener(MouseEvent.CLICK, onTabClick, true);
                    private function onTabClick(event:MouseEvent):void
                        if (event.target.parent is TabBar)
                            clickedTabIndex = TabBar(event.target.parent).getChildIndex(event.target as DisplayObject);
                            event.stopImmediatePropagation();
                            event.preventDefault();
                            Alert.show("Do you want to navigate away from this page","Testing",Alert.YES|Alert.NO,this,Confirmfile,null,Alert.OK);
                     flag = true;
                     if(flag==true)
                      evt.stopImmediatePropagation();
                     else
                     var OKIndex:int = Alert.YES;
                     var NOIndex:int = Alert.NO;
                     if(obj.detail == Alert.YES)
                      tabone.getTabAt(prevTabIndex).selected = false;
                      tabone.getTabAt(clickedTabIndex).selected = true;
                      prevTabIndex = clickedTabIndex;
                     else
                  </mx:Script>
                    </mx:Canvas>
                    </mx:Canvas>
                    </mx:Canvas>
                  </mx:TabNavigator>
                  </mx:Application>
                  Bhasker Chari
                  • 6. Re: Tab Navigator Problem
                    Thanks very much it helped me a lot
                    Thanks & Reagrds,
                    Jayagopal.
