2 Replies Latest reply on May 31, 2010 7:46 AM by archemedia
    Storing binary data in mySql
    archemedia Level 4
      I want to store user preferences in a database. To avoid creating multiple rows in a table for every user, or to avoid too many fields in a table I want to create an object on the client side, serialize it and then, store this serialized string on the server.
      I would do this as follows:
      var t:Object = {id: 1, color: 0x567834};
      var b:ByteArray = new ByteArray();
      b.writeObject(t);
      b.position = 0;
      var s:String = b.toString();
      Now I can store s into my database.
      What should I do to reconvert s to an object?
      Help appreciated!
      Dany
        • 1. Re: Storing binary data in mySql
          David_F57 Level 5
          hi,
          If you use amfphp you just send the binary straight to the db and retrieve it as binary as well no need for any conversions.
          flex  and remoteobject methods
                  <mx:method name="uploadConfig" result="qryUpLoad(event)" />
                  <mx:method name="downloadConfig" result="qryUserConfige(event)" />
          private function saveConfig() : void
                  var ba: byteArray  = new ByteArray();
                 ........populate ba
                  clients.uploadConfig(ba);
          private function getConfig(): void
               clients.downloadConfig(UserID);
          private function qryUserConfig(res:ResultEvent): void
          var result: ByteArray = res.result as ByteArray;
          the php
          function uploadconfig($ba) {
          $data = $ba->data;
          $mysql = mysql_connect(localhost,"root","");
          $data = mysql_real_escape_string($data);
          mysql_select_db( "catalog" );
          $Query = "INSERT INTO user (ID,data) VALUES(0,'$data')";
          $Result = mysql_query( $Query );
          return $Result;
          function downloadconfig($id) {
          $Result = mysql_query("SELECT data FROM user WHERE ID=$id");
          $row = mysql_fetch_object($Result);
          mysql_close();
          $config = new ByteArray($row->data);
          return $config;
          • 2. Re: Storing binary data in mySql
            archemedia Level 4
            Thx David, just what I needed!
            Dany
