5 Replies Latest reply on Jun 1, 2010 11:33 AM by hans-g.
    Why does the spry submenu when viewed IE7 not drop down directly under the main spry item?
    Annedys
      I am using Dreamweaver CS4. I have used a horizontal spry menu bar. When viewed in IE8, Firefox, Opera and Safari everything looks fine. When viewed in IE7 the spry sub menu does not drop down directly underneath the main spry item but to the right of it . In IE6 the top menu bar does not fit onto one line but goes into a second line. What am I doing wrong?  I am new to web design. www.dyshouse.co.uk
      @charset "UTF-8";
      /* SpryMenuBarHorizontal.css - version 0.6 - Spry Pre-Release 1.6.1 */
      /* Copyright (c) 2006. Adobe Systems Incorporated. All rights reserved. */
      LAYOUT INFORMATION: describes box model, positioning, z-order
      /* The outermost container of the Menu Bar, an auto width box with no margin or padding */
      ul.MenuBarHorizontal
      margin: 0;
      padding: 0;
      list-style-type: none;
      font-size: 100%;
      cursor: default;
      width: auto;
      /* Set the active Menu Bar with this class, currently setting z-index to accomodate IE rendering bug: http://therealcrisp.xs4all.nl/meuk/IE-zindexbug.html */
      ul.MenuBarActive
      z-index: 1000;
      /* Menu item containers, position children relative to this container and are a fixed width */
      ul.MenuBarHorizontal li
      margin: 0;
      font-size: 14px;
      position: relative;
      text-align: center;
      cursor: pointer;
      width: 7.14em;
      float: left;
      font-family: "Comic Sans MS", Arial, Verdana;
      background-image: none;
      /* Submenus should appear below their parent (top: 0) with a higher z-index, but they are initially off the left side of the screen (-1000em) */
      ul.MenuBarHorizontal ul
      margin: 0;
      padding: 0;
      font-size: 100%;
      z-index: 1020;
      cursor: default;
      position: absolute;
      left: -1000px;
      visibility: visible;
      width: 7.14em;
      /* Submenu that is showing with class designation MenuBarSubmenuVisible, we set left to auto so it comes onto the screen below its parent menu item */
      ul.MenuBarHorizontal ul.MenuBarSubmenuVisible
      left: auto;
      /* Menu item containers are same fixed width as parent */
      ul.MenuBarHorizontal ul li
      width: 7.14em;
      /* Submenus should appear slightly overlapping to the right (95%) and up (-5%) */
      ul.MenuBarHorizontal ul ul
      position: absolute;
      background-color: #CFF;
      /* Submenu that is showing with class designation MenuBarSubmenuVisible, we set left to 0 so it comes onto the screen */
      ul.MenuBarHorizontal ul.MenuBarSubmenuVisible ul.MenuBarSubmenuVisible
      DESIGN INFORMATION: describes color scheme, borders, fonts
      /* Submenu containers have borders on all sides */
      /* Menu items are a light gray block with padding and no text decoration */
      ul.MenuBarHorizontal a
      display: block;
      cursor: pointer;
      padding: 0.5em 0.75em;
      color: #333;
      text-decoration: none;
      /* Menu items that have mouse over or focus have a blue background and white text */
      ul.MenuBarHorizontal a:hover, ul.MenuBarHorizontal a:focus
      background-color: #33C;
      color: #FFF;
      font-weight: lighter;
      /* Menu items that are open with submenus are set to MenuBarItemHover with a blue background and white text */
      ul.MenuBarHorizontal a.MenuBarItemHover, ul.MenuBarHorizontal a.MenuBarItemSubmenuHover, ul.MenuBarHorizontal a.MenuBarSubmenuVisible
      color: #FFF;
      SUBMENU INDICATION: styles if there is a submenu under a given menu item
      /* Menu items that have a submenu have the class designation MenuBarItemSubmenu and are set to use a background image positioned on the far left (95%) and centered vertically (50%) */
      background-repeat: no-repeat;
      background-position: 95% 50%;
      ul.MenuBarHorizontal ul a.MenuBarItemSubmenu
      /* Menu items that are open with submenus have the class designation MenuBarItemSubmenuHover and are set to use a "hover" background image positioned on the far left (95%) and centered vertically (50%) */
      color: #FFF;
      ul.MenuBarHorizontal ul a.MenuBarItemSubmenuHover
      BROWSER HACKS: the hacks below should not be changed unless you are an expert
      /* HACK FOR IE: to make sure the sub menus show above form controls, we underlay each submenu with an iframe */
      ul.MenuBarHorizontal iframe
      position: absolute;
      z-index: 1010;
      filter:alpha(opacity:0.1);
      /* HACK FOR IE: to stabilize appearance of menu items; the slash in float is to keep IE 5.0 from parsing */
      @media screen, projection
      ul.MenuBarHorizontal li.MenuBarItemIE
      display: inline;
      f\loat: left;
      background-color: #FFc;
