0 Replies Latest reply on May 31, 2010 6:19 PM by aban123
    Problem with Flex Builder 4 Plugin and SpringSource 2.3.2.RELEASE
    aban123
      I am getting following error while opening up a Flex project. The file icons are showing up correctly but then it is creating a stream of following errors.Any help is appreciated.
      Session Data
      eclipse.buildId=2.3.2.201003230009-RELEASE
      java.version=1.6.0_18
      java.vendor=Sun Microsystems Inc.
      BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_US
      Framework arguments:  -product com.springsource.sts.ide
      Command-line arguments:  -os win32 -ws win32 -arch x86_64 -product com.springsource.sts.ide
      Exception Track Trace:
      java.lang.NoClassDefFoundError: com/adobe/flexide/editorcore/EditorUtility
      at com.adobe.flexbuilder.editorcore.editor.ToggleModeAction.selectionChanged(ToggleModeActio n.java:64)
      at org.eclipse.ui.internal.PluginAction.refreshEnablement(PluginAction.java:206)
      at org.eclipse.ui.internal.PluginAction.selectionChanged(PluginAction.java:277)
      at org.eclipse.ui.internal.PluginAction.selectionChanged(PluginAction.java:299)
      at org.eclipse.ui.internal.AbstractSelectionService.fireSelection(AbstractSelectionService.j ava:156)
      at org.eclipse.ui.internal.AbstractSelectionService$1.selectionChanged(AbstractSelectionServ ice.java:62)
      at org.eclipse.jface.viewers.Viewer$2.run(Viewer.java:162)
      at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
      at org.eclipse.core.runtime.Platform.run(Platform.java:888)
      at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:48)
      at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:175)
      at org.eclipse.jface.viewers.Viewer.fireSelectionChanged(Viewer.java:160)
      at org.eclipse.jface.viewers.StructuredViewer.updateSelection(StructuredViewer.java:2132)
      at org.eclipse.jface.viewers.StructuredViewer.handleSelect(StructuredViewer.java:1160)
      at org.eclipse.jface.viewers.StructuredViewer$4.widgetSelected(StructuredViewer.java:1190)
      at org.eclipse.jface.util.OpenStrategy.fireSelectionEvent(OpenStrategy.java:228)
      at org.eclipse.jface.util.OpenStrategy.access$4(OpenStrategy.java:222)
      at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrategy.java:389)
      at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
      at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
      at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3910)
      at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3503)
      at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2405)
      at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369)
      at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2221)
      at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
      at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
      at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:493)
      at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
      at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:113)
      at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:194)
      at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLau ncher.java:110)
      at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.jav a:79)
      at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:368)
      at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
      at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
      at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
      at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
      at java.lang.reflect.Method.invoke(Method.java:597)
      at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:559)
      at org.eclipse.equinox.launcher.Main.basicRun(Main.java:514)
      at org.eclipse.equinox.launcher.Main.run(Main.java:1311)
      at org.eclipse.equinox.launcher.Main.main(Main.java:1287)
