2 Replies Latest reply: Jun 5, 2010 6:33 AM by CtDave RSS
    How to untagged a PDF file
    Sudh@k@r Community Member
      Please let me know how to untagged a PDF document.
      Thanks & Regards,
      Sudhakar
        • 1. Re: How to untagged a PDF file
          cyberRobot Community Member
          Here is one way to delete the tags using Acrobat 9:
          1. Open the PDF
          2. Open the Tags panel (View > Navigation Panels > Tags)
          3. Highlight all of your tags
          4. Click the Options icon in the Tags panel (the one that looks like a couple of gears)
          5. Click "Delete Tags"
          • 2. Re: How to untagged a PDF file
            CtDave CommunityMVP
            Additional "tag removal" schemes:
            --| 1
            Using Acrobat Pro.
            Advanced > PDF Optimizer
            Create a custom setting.
            Untick all but "Discard Objects"
            In Discard Objects, untick all but "Discard document tags"
            Use this to remove the PDF's structure tree.
            --| 2
            Using Acobat Pro.
            Advanced > Accessibility > TouchUp Reading Order
            With TORU, select "Clear Page Structure".
            --| 3
            Using Acrobat Pro.
            Preflight - Create a new profile. Configure it to use the Fixup "Discard document structure".
            Use this profile to remove a PDF's structure tree.
            --| 4
            Using Acrobat Pro.
            A Batch Sequence.
            Create a Batch Sequence that runs a Preflight.
            Select the Preflight profile created in #3 above.
            This Batch Sequence can be run across one or many PDFs in a given directory/folder.
            Be well...
