7 Replies Latest reply on Jun 2, 2010 1:26 PM by David Simons
    Rotobrush to MASKS
    CharlesPeterson
      Ok,
      In the help file it says you can copy rotobrush properties as a MASK.
      How do you do this?
        • 1. Re: Rotobrush to MASKS
          Todd_Kopriva Level 8
          What it says in the Help document is this:
          "You can copy Roto Brush Path properties, and paste them into masks, shapes, and instances of the Paint effect, just like you can with other kinds of paths."
          That refers to the fact that you can copy the Roto Brush strokes' paths and paste them into mask path properties.
          However, I'm guessing that that's not what you're actually trying to do. I'm guessing that what you actually want is to take the transparency information that the Roto Brush effect creates as a matte and convert that to a mask that defines the same transparency information. To do that, you could use the Auto-trace command. The masks created by Auto-trace aren't usually what you want for conventional mask-animation rotoscoping work, though.
          So, the question is this: What are you trying to accomplish?
          • 2. Re: Rotobrush to MASKS
            CharlesPeterson Level 1
            This is what I am trying to do. Maybe I am mis-understanding the help file.
            After I use the rotobrush, is there anyway to convert that information to a masl, so you can tweak difficult areas?
            I am roto an actor in front of a blank monitor that is black. When he crosses over the screen, his shadow almost matches the same color on the monitor and rotobrush has a hard time in this area. It does fine else where.
            So what I would like to do is that the rotobrush, convert it to a keyframe mask and make adjustments that way.
            Can you do that???
            • 3. Re: Rotobrush to MASKS
              As I said in my previous message, you can use Auto-trace to make masks that trace around the alpha channel (matte) created by the Roto Brush effect. You could conceivably use these masks as you describe.
              However, what I'd do (based on what I'm picturing from your description), is create three different Roto Brush spans: one that includes the problematic duration and one before and one after. The only one that will be tricky is the problematic area. I'd use more corrective strokes for that time span to try to get things as close as I could, and then I'd at some point switch over to drawing some masks or using the Brush tool to paint on the alpha channel to do the cleanup work.
              In other words, I wouldn't try to convert the output of the Roto Brush effect to masks; I'd instead use masks on top of what I'd done with Roto Brush. This is very similar to the sort of rotoscoping cleanup that one almost always has to do with problematic areas during color keying work.
              • 4. Re: Rotobrush to MASKS
                Jeff Almasol Adobe Employee
                You might also try changing the Edge Detection setting (within the Propagation group) to see if it helps keep the edge on the shadow.
                • 5. Re: Rotobrush to MASKS
                  Thanks for the information guys! I will try to have a little more patience with the RotoBrush and mess around with the settings.
                  • 6. Re: Rotobrush to MASKS
                    The Roto Brush tool is a little funky to use. Path's aren't editable and in some cases, Mocha (part of CS5) or even drawing masks by hand will get you there quicker. I've successfully use Roto Brush on about eight or ten really difficult projects so far. Each was a real learning experience. I'm preparing a tutorial on the tool that I hope will make it a little easier to understand. Until then here's what I know.
                    1. The strokes that you apply to the layer with the Roto Brush are vectors.
                    2. The strokes define search areas, they do not create a mask directly.
                    3. The stroke position is not animated over time.
                    4. Roto Brush is, in most cases, faster by far than drawing masks.
                    5. It seems to be a best practice to use Roto Brush on small sections of the image
                    6. You must freeze Roto Brush before you return to the composition window or the footage will be re-interpretted and the roto will change.
                    7. The vector paths you create do not seem to be useful for anything but Roto Brush.
                    I hope this helps. For your application I think a combination of multiple uses of Roto Brush combined with some hand drawn masks may be the best option. Only one of my recent Roto projects was completed by using a single copy of the layer with a single application of Roto Brush.
                    • 7. Re: Rotobrush to MASKS
                      Adobe Employee
                      Rick, regarding "You must freeze Roto Brush before you return to the composition window or the footage will be re-interpretted and the roto will change", you shouldn't need to freeze, though if you're done changing things it is a good idea, as it will save you lots of re-rendering for any results that fall out of the cache, or after you close & reopen the project.
                      If you've found a case where the results are changing when the inputs are the same, please file a bug.
                      True, though if you actually want to have a stroke persist over multiple frames, you can reveal the stroke in the timeline (PP) and extend its duration. Once you've done that, you can even animation the the position/scale/rotation etc. of the stroke. You usually shouldn't need to do this, but if you have a troublesome area that requires repeated correction on every frame, it could come in handy. To see where the stroke is, select it in the timeline, or hit cmd-A to select all strokes when the layer panel is active.
