6 Replies Latest reply on Jun 1, 2010 10:26 AM by asifdegr8
    Problem with checkbox item renderer in datagrid
    asifdegr8
      I have a data grid having check box as an item renderer. I have viewed many posts in this forum but nothing useful in my case. I am failed to bind my datagrid itemrenderer checkbox with the field of dataprovider i.e. listUnitMovement.CHECK_PATH. Then I have to traverse data provider to check which checkboxes are checked.
      [Bindable]
      var listUnitMovement:XMLList=null;
      In a function call
      public function init(event:ResultEvent):void
          listUnitMovement=event.result.unitmovement;
           <mx:DataGrid id="dg_country"
                                 dataProvider="{listUnitMovement}"
                                    enabled="true">
                                  <mx:columns>
                                     <mx:DataGridColumn>
                                          <mx:itemRenderer>
                                              <mx:Component>
                                                  <mx:CheckBox selectedField="CHECK_PATH"  />
                                              </mx:Component>
                                          </mx:itemRenderer>
                                      </mx:DataGridColumn>
                                      <mx:DataGridColumn headerText="Latitude" dataField="NEW_LAT" visible="false"/>
                                      <mx:DataGridColumn headerText="Longitude" dataField="NEW_LONG" visible="false"/>
                                     <mx:DataGridColumn>
                                          <mx:itemRenderer>
                                              <mx:Component>
                                                  <mx:Button label="Details"/>
                                              </mx:Component>
                                          </mx:itemRenderer>
                                  </mx:columns>
                              </mx:DataGrid>
        • 1. Re: Problem with checkbox item renderer in datagrid
          BhaskerChari Level 4
          Post the total code....I will solve it for you...
          Bhasker Chari
          • 2. Re: Problem with checkbox item renderer in datagrid
            asifdegr8 Level 1
            it would be difficult to post complete code as i crop a portion of code from a very big application. it is also using database at back end. You can suppose any data provider here.
            • 3. Re: Problem with checkbox item renderer in datagrid
              asifdegr8 Level 1
              suppose our data provider listUnitMovement has following fields.
              listUnitMovement.CHECK_PATH (boolean) true/false
              listUnitMovement.NEW_LAT (number)
              listUnitMovement.NEW_LONG(number)
              • 4. Re: Problem with checkbox item renderer in datagrid
                asifdegr8 Level 1
                                           <mx:DataGridColumn>
                                                    <mx:itemRenderer>
                                                        <mx:Component>
                                                            <mx:CheckBox selectedField="CHECK_PATH" change="data.CHECK_PATH=selected"  />
                                                        </mx:Component>
                                                    </mx:itemRenderer>
                when i add change="data.CHECK_PATH=selected" event in check box control as i mentioned above, it will not allow me to select checkbox.
                • 5. Re: Problem with checkbox item renderer in datagrid
                  Do you want to just check/uncheck the checkboxes based on the CHECK_PATH field.
                  Do you want something like this...
                  <mx:Application
                  xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute">
                  <mx:Script>
                  <![CDATA[
                  import mx.collections.ArrayCollection;
                  Bindable]
                  private var listUnitMovement:ArrayCollection = new ArrayCollection([{CHECK_PATH:true,NEW_LAT:109.233,NEW_LONG:232.22},{CHECK_PATH:true,NEW_LAT:109.233,NEW_LONG:232.22},{CHECK_PATH:false,NEW_LAT:133.233,NEW_LONG:702.22}]);
                  </mx:Script>
                  <mx:DataGrid dataProvider="{listUnitMovement}">
                  <mx:columns>
                  <mx:DataGridColumn>
                  <mx:itemRenderer>
                  <mx:Component>
                  </mx:Component>
                  </mx:itemRenderer>
                  <mx:DataGridColumn dataField="NEW_LAT"/>
                  <mx:DataGridColumn dataField="NEW_LONG"/>
                  </mx:columns>
                  </mx:DataGrid>
                  </mx:Application>
                  Please let me know clearly what's your problem...Do you want to just bind the check box based on XmlList or something else..?
                  Bhasker Chari.S
                  • 6. Re: Problem with checkbox item renderer in datagrid
                    asifdegr8 Level 1
                    I just want to bind the check box based on XmlList. The code you written is working fine for data provider based on array collection, but it didn't work for XMLList.
