3 Replies Latest reply on Jun 6, 2010 2:36 AM by daslicht
    Bind <s:List/> dataProvider with AS3
    daslicht Level 2
      Hello,
      i found the following example:
      <?xml version="1.0"?>
      <!-- binding/BindSetterAS.mxml -->
      <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml">
           <mx:Script>
                <![CDATA[
                     import mx.binding.utils.*;
                     import mx.events.FlexEvent;
                     // Method called when myTI.text changes.
                     public function updateMyString(val:String):void {
                          myTA.text = val.toUpperCase();
                     <!-- Event listener to configure binding. -->
                     public function mySetterBinding(event:FlexEvent):void {
                          var watcherSetter:ChangeWatcher =  // not really nessesary ?
                               BindingUtils.bindSetter(updateMyString, myTI, "text");
           </mx:Script>
           <mx:Label text="Bind Setter using setter method"/>
           <mx:TextInput id="myTI"
                            text="Hello Setter" />
           <mx:TextArea id="myTA"
                           initialize="mySetterBinding(event);"/>
      </mx:Application>
      But how do I bind a ArrayCollection as Dataprovider for a Spark List using Actionscript ?
      Here my attempts:
      public function init():void
          BindingUtils.bindSetter(bindingHandler, myArrayCollection, "???");
      protected function bindingHandler():void
           this.my_list.dataProvider = myArrayCollection;
      <s:List id="my_list"/>
      Another Question:
      How do I initialze a customComponent manually so that all
      MXML Components whcioh are included in it are created on my command?
        • 1. Re: Bind <s:List/> dataProvider with AS3
          UbuntuPenguin Level 4
          Has the following code failed you ?
          <Container>
            ...blah .... blah
            [Bindable] public var myCollection:ArrayCollection;
            List list = new List();
            list.dataProvider = myCollection;
            Or you could use getter/setters
             private var _list:List;
             private var _myCollection:ArrayCollection;
             public function set myCollection( collection:ArrayCollection ):void
                  myCollection = collection;
                  _list.dataProvider = _myCollection;
          See , it's not too difficult.
          Sincerely,
            Ubu
          • 2. Re: Bind <s:List/> dataProvider with AS3
            daslicht Level 2
            Hello ,
            thank youi very much for taking time to read and write a reply.
            Yeh, I tried it wxactly as u have suggested.
            Let me explain why I was asking this question.
            I have the following setup: (the code is incomplete and only for illustration)
            mainapp                       //includes a singleton getter named instance
                 CRUD_and_Dataholder    /* this Component includes Dataservices and
                                                         a ArrayCollection ( lets call it myAC ) with its actual Data*/
                 view                               //this is the GUI
            The List Components Dataprovider, in 'view', is bound to mainapp.instance.CRUD_and_Dataholder.myAC;
            Anything is starting good, but the binding is not updating.
            I bet it has something to do with the initializing sequence of the components.
            How would  you solve such kind of things?
            Best Regards
            Marc
            • 3. Re: Bind <s:List/> dataProvider with AS3
              daslicht Level 2
              SWIZ!
              I thik this was the missing part of the puzzle.
              A while back I realized a project using cairngorm. I discontinued using it since its repetitive code.
              Now I found SWIZ which seems to be the solution to all my wishes
