0 Replies Latest reply on Jun 1, 2010 2:35 AM by Marijan Tompa [tomaxxi]
    Change Cursor Key Increments from script
    Marijan Tompa [tomaxxi] Level 4
      Hey!
      I wanna share script for changeing cursor key increment.
      /*1*/ // Save to preferences
      //tomaxxiINCR.jsx
      //An InDesign CS3/CS4/CS5 JavaScript
      if (app.dialogs.length > 0) app.dialogs.everyItem().destroy();
      if (Number(app.version.split(".")[0]) < 5){
           alert("Script is not compattible");
      }else{
          if (app.documents.length != 0){
              ChangeIncrement();
          }else{
              exit();
      function ChangeIncrement(){
           app.scriptPreferences.userInteractionLevel = UserInteractionLevels.interactWithAll;
           var saveSett = eval(loadSettings());
           var UNITS = UNITS||(function(){
                var muArray={}, mUnits=MeasurementUnits;
                muArray[mUnits.AGATES]=['agt','0.001','19.444'];
                muArray[mUnits.CENTIMETERS]=['cm','0.001','3.527'];
                muArray[mUnits.CICEROS]=['ci','0c0.001','7c9.839'];
                muArray[mUnits.INCHES]=['in','0.001','1.388'];
                muArray[mUnits.INCHES_DECIMAL]=['in','0.001','1.388'];
                muArray[mUnits.MILLIMETERS]=['mm','0.001','35.277'];
                muArray[mUnits.POINTS]=['pt','0.001','100'];
               muArray[mUnits.PICAS]=['pc','0p0.001','8p4'];
                     if (Number(app.version.split(".")[0]) > 6){
                          muArray[mUnits.PIXELS]=['px','0.001','100'];
                return muArray;
           var vp = app.activeDocument.viewPreferences;
           var vx = app.viewPreferences;
           if((UNITS[vp.horizontalMeasurementUnits][0]== "agt")||
           (UNITS[vx.horizontalMeasurementUnits][0]== "agt")){
                mk=5.1428571;
                hk=5.1428571;
           }else{
                mk = UnitValue(1,UNITS[vx.horizontalMeasurementUnits][0]).as('pt');
                hk = UnitValue(1,UNITS[vp.horizontalMeasurementUnits][0]).as('pt');
           var currentINCR = vp.cursorKeyIncrement;
           var myINCR = app.dialogs.add({
                name:"/// Set Key Increment ///", canCancel:true});
                with(myINCR.dialogColumns.add()){
                     with(dialogRows.add()){
                          with(dialogColumns.add()){
                               staticTexts.add({staticLabel:"Key Increment:", minWidth:10});
                               var myIncrement = measurementEditboxes.add({editValue:currentINCR*hk, editUnits:vp.horizontalMeasurementUnits});
                               staticTexts.add({staticLabel:UNITS[vp.horizontalMeasurementUnits][1] + " - " + UNITS[vp.horizontalMeasurementUnits][2]+" "
                               + UNITS[vp.horizontalMeasurementUnits][0], minWidth:10});
                               var saveToPrefs = checkboxControls.add({staticLabel:"&Save to preferences", checkedState:saveSett});
                               staticTexts.add({staticLabel:"*If you don't save, value will be for this document only!", minWidth:10});
           if(myINCR.show() == true){
                if((myIncrement.editValue < 0.001)||(myIncrement.editValue > 100)){
                     alert("Set Key Increment Value Error!\r\rValue must be between " + UNITS[vp.horizontalMeasurementUnits][1] + " and "
                     +UNITS[vp.horizontalMeasurementUnits][2] + " " + UNITS[vp.horizontalMeasurementUnits][0]);
                }else{
                     vp.cursorKeyIncrement=myIncrement.editValue/hk;
                          if(saveToPrefs.checkedState == 1){vx.cursorKeyIncrement=myIncrement.editValue/mk;}
                saveSettings(saveToPrefs.checkedState);
           myINCR.destroy();
      function loadSettings(){
           var f = File(app.activeScript);
                if ( f.open('r') ){
                     var sett=String(f.readln());
                     sett=sett.substr(sett.indexOf("*")+1,1);
                     return sett;
      function saveSettings(curSett){
           if(curSett == true){curSett = 1;}else{curSett = 0;}
           var settPos = String();
           if ( f.open('e') ){
                settPos = f.readln();
                settPos = settPos.indexOf("*")+1;
                f.seek(settPos);
                f.write(curSett);
                f.close();
      tomaxxi
