3 Replies Latest reply on Aug 17, 2007 3:27 PM by FlashTastic
    help on as2
    wise_man_
      I saw this code one day and I'd like to have explanation on it :
      "class myClass extends Movieclip{
      this.createEmptyMovieClip(String(y), i+10).attachMovie(this.items[y].id,'_mc',1);
      this[y]._x = this[y].x=left+i*(this.icon_min+this.icon_spacing)+this.icon_spacing/2;
      regarding to the fact that "this[y]" refers to an empty movieclip in which another movieclip has been attached,
      what the "x" property is related to ?? cuz' I don't find it in the properties of a movieclip ...
      Thanx 4 ur answer
        • 1. Re: help on as2
          FlashTastic Level 1
          It's impossible to tell what you're after without posting more code. Post or link to the entire class, and explain what it's about.
          • 2. Re: help on as2
            wise_man_ Level 1
            here is the entire code :
            class Menu_ extends MovieClip {
            var icon_min:Number;
            var icon_max:Number;
            var icon_size:Number;
            var icon_spacing:Number;
            var width:Number;
            var span:Number;
            var amplitude:Number;
            var ratio:Number;
            var scale:Number = Number.NEGATIVE_INFINITY;
            var trend:Number = 0;
            var xmouse:Number;
            var ymouse:Number;
            var layout:String;
            var callback:Function;
            var items:Array;
            function Menu_() {
            setParameters();
            setLayout();
            createIcons();
            createTray();
            onEnterFrame = monitorDock;
            private function setParameters():Void {
            this.layout = this.layout ? this.layout : 'bottom';
            this.icon_min = this.icon_min ? this.icon_min : 32;
            this.icon_max = this.icon_max ? this.icon_max : 96;
            this.icon_spacing = this.icon_spacing ? this.icon_spacing : 2;
            this.span = this.span ? this.span : getSpan();
            this.amplitude = this.amplitude ? this.amplitude : getAmplitude();
            this.ratio = Math.PI/2/this.span;
            private function getSpan():Number {
            return (this.icon_min-16)*(240-60)/(96-16)+60;
            private function getAmplitude():Number {
            return 2*(this.icon_max-this.icon_min+this.icon_spacing);
            private function createIcons():Void {
            var y:Number;
            var id:String;
            this.scale = 0;
            this.width = (this.items.length-1)*this.icon_spacing+this.items.length*this.icon_min;
            var left:Number = (this.icon_min-this.width)/2;
            for (y=0; y<this.items.length; y++) {
            this.createEmptyMovieClip(String(y), y+10).attachMovie(this.items[y].id,'_mc',1);
            this[y]._mc._y = -this.icon_size/2;
            this[y]._mc._rotation = -this._rotation;
            this[y]._y = -this.icon_spacing;
            this[y].onRelease = launchIcon;
            this[y].onRollOver = rolloverIcon;
            this[y].onRollOut = rolloutIcon;
            //this[y].useHandCursor = false;
            private function launchIcon():Void {
            this._parent.callback(this._parent.items[this._name].label);
            private function rolloverIcon():Void {
            this._parent.rollover(this._parent.items[this._name].label);
            private function rolloutIcon():Void {
            this._parent.rollout(this._parent.items[this._name].label);
            private function createTray():Void {
            var height:Number = this.icon_min+2*this.icon_spacing;
            var width:Number = this.width+2*this.icon_spacing;
            var mc:MovieClip = this.createEmptyMovieClip('tray_mc', 1);
            mc.lineStyle(0,0xcccccc,80);
            mc.beginFill(0xe8e8e8,50);
            mc.lineTo(0,-height);
            mc.lineTo(width,-height);
            mc.lineTo(width,0);
            mc.lineTo(0,0);
            mc.endFill();
            private function setLayout():Void {
            switch (this.layout) {
            case 'left' :
            this._rotation = 90;
            break;
            case 'top' :
            this._rotation = 180;
            break;
            case 'right' :
            this._rotation = 270;
            break;
            default :
            this._rotation = Number(this.layout);
            private function checkBoundary():Boolean {
            var buffer:Number = 4*this.scale;
            return (this.ymouse<0) && (this.ymouse>-2*this.icon_spacing-this.icon_min+(this.icon_min-this.icon_max)*this.scale) && (this.xmouse>this[0]._x-this[0]._width/2-this.icon_spacing-buffer) && (this.xmouse<this[this.items.length-1]._x+this[this.items.length-1]._width/2+this.icon_sp acing+buffer);
            private function updateTray():Void {
            var x:Number;
            var w:Number;
            x = this[0]._x-this[0]._width/2-this.icon_spacing;
            w = this[this.items.length-1]._x+this[this.items.length-1]._width/2+this.icon_spacing;
            this['tray_mc']._x = x;
            this['tray_mc']._width = w-x;
            private function monitorDock():Boolean {
            var i:Number;
            var x:Number;
            var dx:Number;
            var dim:Number;
            // Mouse did not move and Dock is not between states. Skip rest of the block.
            if ((this.xmouse == this._xmouse) && (this.ymouse == this._ymouse) && ((this.scale<=0.01) || (this.scale>=0.99))) {
            return false;
            // Mouse moved or Dock is between states. Update Dock.
            this.xmouse = this._xmouse;
            this.ymouse = this._ymouse;
            // Ensure that inflation does not change direction.
            this.trend = (this.trend == 0) ? (checkBoundary() ? 0.25 : -0.25) : (this.trend);
            this.scale += this.trend;
            if ((this.scale<0.02) || (this.scale>0.98)) {
            this.trend = 0;
            // Actual scale is in the range of 0..1
            this.scale = Math.min(1, Math.max(0, this.scale));
            // Hard stuff. Calculating position and scale of individual icons.
            for (i=0; i<this.items.length; i++) {
            dx = this .x-this.xmouse;
            dx = Math.min(Math.max(dx, -this.span), this.span);
            trace(dx);
            dim = this.icon_min+(this.icon_max-this.icon_min)*Math.cos(dx*this.ratio)*(Math.abs(dx)>this.sp an ? 0 : 1)*this.scale;
            this
            ._x = this .x+this.scale*this.amplitude*Math.sin(dx*this.ratio);
            this
            ._xscale = this ._yscale=100*dim/this.icon_size;
            // Resize tray to contain icons.
            updateTray();
            return true;
            it's a menu that looks like mac menu .... and i don't understand what is the x property in this instruction :
            • 3. Re: help on as2
              FlashTastic Level 1
              It looks like it's being set to reference the original x co-ordinate of the icon, so it can be referenced later (perhaps to snap back to if the icon is dragged to an invalid position?)
              Anyhow, it doesn't seem that this is a standalone class, and has much more of it driven from either the timeline of a movie or another class (in which perhaps we would find that some items are added to the Menu_.items array).
              Hope that helps,
              Cheers, FlashTastic
