4 Replies Latest reply on Jun 2, 2010 2:18 AM by Rdsingh Ldh
    DefaultItemRender confusion help me.
    nikos101 Level 2
      when you do something likes this:
      <s:DataGroup id="dataGroup" itemRenderer="nikos.itemRenderers.LightBlueDefaultItemRenderer">
      instead of using the DefaultItemRenderer
      do you automactically have all the code for the  DefaultItemRenderer
      ie my LightBlueDefaultItemRenderer is the below:
      <s:ItemRenderer focusEnabled="false"
                      xmlns:fx="http://ns.adobe.com/mxml/2009" xmlns:s="library://ns.adobe.com/flex/spark"
                      autoDrawBackground="true">
          <s:states>
              <s:State name="normal" />
              <s:State name="hovered" />
              <s:State name="selected" />
              <s:State name="normalAndShowsCaret"/>
              <s:State name="hoveredAndShowsCaret"/>
              <s:State name="selectedAndShowsCaret"/>
          </s:states>
          <s:Label id="labelDisplay"
                   verticalCenter="0" left="3" right="3" top="6" bottom="4"
                   color.normal="#46F9FB" color.hovered="green" color.selected="red" fontWeight.normal="bold" fontFamily.normal="Verdana"/>
      </s:ItemRenderer>
      but the code for the   DefaultItemRenderer is much more complex like so:
      //  ADOBE SYSTEMS INCORPORATED
      //  Copyright 2004-2007 Adobe Systems Incorporated
      //  All Rights Reserved.
      //  NOTICE: Adobe permits you to use, modify, and distribute this file
      //  in accordance with the terms of the license agreement accompanying it.
      package spark.skins.spark
      import flash.display.DisplayObject;
      import flash.events.MouseEvent;
      import flash.geom.Point;
      import mx.controls.listClasses.*;
      import mx.core.IDataRenderer;
      import mx.core.UIComponent;
      import mx.core.mx_internal;
      import mx.events.FlexEvent;
      import spark.components.IItemRenderer;
      import spark.components.Label;
      import spark.components.supportClasses.TextBase;
      use namespace mx_internal;
      //  Events
      *  Dispatched when the <code>data</code> property changes.
      *  <p>When you use a component as an item renderer,
      *  the <code>data</code> property contains the data to display.
      *  You can listen for this event and update the component
      *  when the <code>data</code> property changes.</p>
      *  @eventType mx.events.FlexEvent.DATA_CHANGE
      *  @langversion 3.0
      *  @playerversion Flash 9
      *  @playerversion AIR 1.1
      *  @productversion Flex 3
      [Event(name="dataChange", type="mx.events.FlexEvent")]
      //  Styles
      include "../../styles/metadata/BasicInheritingTextStyles.as"
      include "../../styles/metadata/AdvancedInheritingTextStyles.as"
      include "../../styles/metadata/SelectionFormatTextStyles.as"
      *  The colors to use for the backgrounds of the items in the list.
      *  The value is an array of two or more colors.
      *  The backgrounds of the list items alternate among the colors in the array.
      *  @default undefined
      *  @langversion 3.0
      *  @playerversion Flash 10
      *  @playerversion AIR 1.5
      *  @productversion Flex 4
      [Style(name="alternatingItemColors", type="Array", arrayType="uint", format="Color", inherit="yes", theme="spark")]
      *  Color of focus ring when the component is in focus
      *  @default 0x70B2EE
      *  @langversion 3.0
      [Style(name="focusColor", type="uint", format="Color", inherit="yes", theme="spark")]
      *  Color of the highlights when the mouse is over the component
      *  @default 0xCEDBEF
      *  @langversion 3.0
      [Style(name="rollOverColor", type="uint", format="Color", inherit="yes", theme="spark")]
      *  Color of any symbol of a component. Examples include the check mark of a CheckBox or
      *  the arrow of a scroll button
      *  @default 0x000000
      *  @langversion 3.0
      [Style(name="symbolColor", type="uint", format="Color", inherit="yes", theme="spark")]
      //  Excluded APIs
      [Exclude(name="focusBlendMode", kind="style")]
      [Exclude(name="focusThickness", kind="style")]
      *  The DefaultItemRenderer class defines the default item renderer
      *  for a List control.
      *  The default item renderer just draws the text associated
      *  with each item in the list.
      *  <p>You can override the default item renderer
      *  by creating a custom item renderer.</p>
      *  @see spark.components.List
      *  @see mx.core.IDataRenderer
      *  @see spark.components.IItemRenderer
      *  @see spark.components.supportClasses.ItemRenderer
      *  @langversion 3.0
      public class DefaultItemRenderer extends UIComponent
          implements IDataRenderer, IItemRenderer
          //  Constructor
           *  Constructor.
           *  @langversion 3.0
          public function DefaultItemRenderer()
              super();
              addHandlers();
          //  Variables
          //  Private Properties
           *  @private
           *  Flag that is set when the mouse is hovered over the item renderer.
          private var hovered:Boolean = false;
          //  Overridden properties: UIComponent
          //  baselinePosition
           *  @private
          override public function get baselinePosition():Number
              if (!labelDisplay || !validateBaselinePosition())
                  return super.baselinePosition;
              return labelDisplay.y + labelDisplay.baselinePosition;
          //  Public Properties
          //  data
           *  @private
           *  Storage for the data property.
          private var _data:Object;
          [Bindable("dataChange")]
           *  The implementation of the <code>data</code> property
           *  as defined by the IDataRenderer interface.
           *  When set, it stores the value and invalidates the component
           *  to trigger a relayout of the component.
           *  @langversion 3.0
          public function get data():Object
              return _data;
           *  @private
          public function set data(value:Object):void
              _data = value;
              dispatchEvent(new FlexEvent(FlexEvent.DATA_CHANGE));
          //  itemIndex
           *  @private
           *  storage for the itemIndex property
          private var _itemIndex:int;
           *  @inheritDoc
           *  @default 0
          public function get itemIndex():int
              return _itemIndex;
           *  @private
          public function set itemIndex(value:int):void
              if (value == _itemIndex)
                  return;
              _itemIndex = value;
              invalidateDisplayList();
          //  label
           *  @private
           *  Storage var for label
          private var _label:String = "";
           *  @inheritDoc
           *  @default ""
          public function get label():String
              return _label;
           *  @private
          public function set label(value:String):void
              if (value == _label)
                  return;
              _label = value;
              // Push the label down into the labelDisplay,
              // if it exists
              if (labelDisplay)
                  labelDisplay.text = _label;
          //  labelDisplay
           *  Optional item renderer label component.
           *  This component is used to determine the value of the
           *  <code>baselinePosition</code> property in the host component of
           *  the item renderer.
           *  @langversion 3.0
          public var labelDisplay:TextBase;
          //  showsCaret
           *  @private
           *  Storage for the showsCaret property
          private var _showsCaret:Boolean = false;
           *  @inheritDoc
           *  @default false
          public function get showsCaret():Boolean
              return _showsCaret;
           *  @private
          public function set showsCaret(value:Boolean):void
              if (value == _showsCaret)
                  return;
              _showsCaret = value;
          //  selected
           *  @private
           *  storage for the selected property
          private var _selected:Boolean = false;
           *  @inheritDoc
           *  @default false
          public function get selected():Boolean
              return _selected;
           *  @private
          public function set selected(value:Boolean):void
              if (value != _selected)
                  _selected = value;
          //  dragging
           *  @private
           *  Storage for the dragging property.
          private var _dragging:Boolean = false;
           *  @inheritDoc
          public function get dragging():Boolean
              return _dragging;
           *  @private
          public function set dragging(value:Boolean):void
              if (value == _dragging)
                  return;
              _dragging = value;
          //  Overridden methods: UIComponent
           *  @private
          override protected function createChildren():void
              super.createChildren();
              if (!labelDisplay)
                  labelDisplay = new Label();
                  addChild(DisplayObject(labelDisplay));
                  if (_label != "")
           *  @private
          override protected function measure():void
              super.measure();
              // label has padding of 3 on left and right and padding of 5 on top and bottom.
              measuredWidth = labelDisplay.getPreferredBoundsWidth() + 6;
              measuredHeight = labelDisplay.getPreferredBoundsHeight() + 10;
              measuredMinWidth = labelDisplay.getMinBoundsWidth() + 6;
              measuredMinHeight = labelDisplay.getMinBoundsHeight() + 10;
           *  @private
          override protected function updateDisplayList(unscaledWidth:Number,
                                                        unscaledHeight:Number):void
              super.updateDisplayList(unscaledWidth, unscaledHeight);
              graphics.clear();
              var backgroundColor:uint;
              var drawBackground:Boolean = true;
              if (selected)
                  backgroundColor = getStyle("selectionColor");
              else if (hovered)
                  backgroundColor = getStyle("rollOverColor");
              else
                  var alternatingColors:Array = getStyle("alternatingItemColors");
                  if (alternatingColors && alternatingColors.length > 0)
                      // translate these colors into uints
                      styleManager.getColorNames(alternatingColors);
                      backgroundColor = alternatingColors[itemIndex % alternatingColors.length];
                  else
                      // don't draw background if it is the contentBackgroundColor. The
                      // list skin handles the background drawing for us.
                      drawBackground = false;
              graphics.beginFill(backgroundColor, drawBackground ? 1 : 0);
              if (showsCaret)
                  graphics.lineStyle(1, getStyle("selectionColor"));
                  graphics.drawRect(0.5, 0.5, unscaledWidth-1, unscaledHeight-1);
              else
                  graphics.lineStyle();
                  graphics.drawRect(0, 0, unscaledWidth, unscaledHeight);
              graphics.endFill();
              // make sure our width/height is in the min/max for the label
              var childWidth:Number = unscaledWidth - 6;
              childWidth = Math.max(labelDisplay.getMinBoundsWidth(), Math.min(labelDisplay.getMaxBoundsWidth(), childWidth));
              var childHeight:Number = unscaledHeight - 10;
              childHeight = Math.max(labelDisplay.getMinBoundsHeight(), Math.min(labelDisplay.getMaxBoundsHeight(), childHeight));
              // set the label's position and size
              labelDisplay.setLayoutBoundsSize(childWidth, childHeight);
              labelDisplay.setLayoutBoundsPosition(3, 5);
          //  Event handling
           *  @private
           *  Attach the mouse events.
          private function addHandlers():void
              addEventListener(MouseEvent.ROLL_OVER, itemRenderer_rollOverHandler);
              addEventListener(MouseEvent.ROLL_OUT, itemRenderer_rollOutHandler);
           *  @private
          private function anyButtonDown(event:MouseEvent):Boolean
              var type:String = event.type;
              return event.buttonDown || (type == "middleMouseDown") || (type == "rightMouseDown");
           *  @private
           *  Mouse rollOver event handler.
          protected function itemRenderer_rollOverHandler(event:MouseEvent):void
              if (!anyButtonDown(event))
                  hovered = true;
           *  @private
           *  Mouse rollOut event handler.
          protected function itemRenderer_rollOutHandler(event:MouseEvent):void
              hovered = false;
