3 Replies Latest reply on Jun 1, 2010 3:12 PM by TechByter
    Testing server not set up correctly
    TechByter Level 1
      Under Windows 7 (64-bit) I have installed XAMPP, which is on E:\xampp\.
      I have copied the website I want to work on from its location on another drive to E:\xampp\htdocs\website\.
      With a browser, I can view the site with http://localhost/website/.
      Dreamweaver CS5 tells me that there is dynamic content and I give it permission to discover the content.
      I am then told the site definition for the server is incorrect.
      So I probably have something misconfigured, but I haven't figured out what.
      Settings:
      Local site folder: E:\xampp\htdocs\website\
      Server name: Local testing server
      Connect using: Local/Network
      Server folder: E:\xampp\htdocs\
      Web URL: http://localhost/website\.
      Server model: PHP MySQL
      What am I doing wrong?
      Thanks!
        • 1. Re: Testing server not set up correctly
          Richard_vav Level 3
          Can I ask which way you entered those settings, did you edit the site from the manage sites window, the only reason I ask is that for some reason it doesn't always seem to work when you do it that way.
          I had the same problem and I ended up deleting the server and then opening a file which has d-related files and then clicking on setup on the folowing info band that appears near the top of the window
          "Dynamically-realated files cannot be discovered becuase a testing server is not defined. Setup"
          As for your settings, they look ok, but so did mine, these are the settings I ended up using, which apart from the sub folder in xampp look identical to yours.
          Connect using: local/network
          server folder: c:\xampp\htdocs\
          web url: http://localhost/
          server model: php mysql
          The other thing to double check is that you have started apache in xampp, every so often I forget to start it and dreamweaver will error when looking for the d-related files
          Richard
          • 2. Re: Testing server not set up correctly
            TechByter Level 1
            Wow, is that ever screwy!
            Thanks, Richard. I had set it up from Manage Sites. I deleted the testing server there and set it up from the "setup" message as you suggested and it works.
            This seems like a bug that shouldn't have escaped alpha testing, to say nothing of beta testing.
            • 3. Re: Testing server not set up correctly
              TechByter Level 1
              After performing the actions described above, I now have a functional testing server. I still need to modify some PHP settings, but I should be able to work through that.
