1 Reply Latest reply on Jun 1, 2010 3:58 PM by Cyril Hanquez
    unable to bind the select() result to datagrid here........in air+sql connection
    flex_able
      <mx:WindowedApplication xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute" creationComplete="init()">
      <mx:Script>
      <![CDATA[
      import mx.controls.Alert;
      import flash.data.SQLConnection;
      import flash.events.SQLErrorEvent;
      import flash.data.SQLStatement;
      import flash.events.SQLEvent;
      import flash.filesystem.File;
      public function init():void
      // creating a connection and the database
      var conn:SQLConnection = new SQLConnection();
      conn.addEventListener(SQLEvent.OPEN, openHandler);
      conn.addEventListener(SQLErrorEvent.ERROR, errorHandler);
      var dbFile:File = File.applicationStorageDirectory.resolvePath("DBSample.db");
      conn.openAsync(dbFile);
      // putting the database creation into the open handler of conn object
      function openHandler(event:SQLEvent):void
          trace("the database was created successfully");
          var createStmt:SQLStatement = new SQLStatement();
          createStmt.sqlConnection = conn;
      var sql:String =
          "CREATE TABLE IF NOT EXISTS employees (" +
          "    firstName TEXT, " +
          "    lastName TEXT, " +
      createStmt.text = sql;
      createStmt.addEventListener(SQLEvent.RESULT, createResult);
      createStmt.addEventListener(SQLErrorEvent.ERROR, createError);
      createStmt.execute();
      function createResult(event:SQLEvent):void
          Alert.show("Table created");
      // table structure error handle
      function createError(event:SQLErrorEvent):void
          trace("Error message:", event.error.message);
          trace("Details:", event.error.details);
      // error handler for conn object
      function errorHandler(event:SQLErrorEvent):void
      b2.addEventListener(MouseEvent.CLICK,select);
      // select function
      function select():void
      // select statement
      var selectStmt:SQLStatement = new SQLStatement();
      selectStmt.sqlConnection = conn;
      selectStmt.text = "SELECT firstName, lastName FROM employees";
      selectStmt.addEventListener(SQLEvent.RESULT, resultHandler);
      selectStmt.addEventListener(SQLErrorEvent.ERROR, errorHandler);
      selectStmt.execute();
      function resultHandler(event:SQLEvent):void
          var result:SQLResult = selectStmt.getResult();
          var numResults:int = result.data.length;
          for (var i:int = 0; i < numResults; i++)
              var row:Object = result.data[i];
              var output:String = "firstname: " + row.firstName;
              output += "; lastName: " + row.lastName;
              trace(output);
      b1.addEventListener(MouseEvent.CLICK,insert);
      // insert fuction
      function insert():void
      var insertStmt:SQLStatement = new SQLStatement();
      insertStmt.sqlConnection = conn;
      var sqls:String =
          "INSERT INTO employees  (firstName, lastName)  values(:firstName,:lastName)";
          //""   + "(firstName, lastName) " + "VALUES ('Bob', 'Smith')";
          insertStmt.parameters[":firstName"] = fname.text;
            insertStmt.parameters[":lastName"] = lname.text;
      insertStmt.text = sqls;
      insertStmt.addEventListener(SQLEvent.RESULT, insertResult);
      insertStmt.addEventListener(SQLErrorEvent.ERROR, insertError);
      insertStmt.execute();
      function insertResult(event:SQLEvent):void
          trace("INSERT statement succeeded");
          fname.text="";
          lname.text="";
      function insertError(event:SQLErrorEvent):void
      </mx:Script>
      <mx:TextInput x="17" y="52" id="fname" />
      <mx:TextInput x="17" y="120" id="lname"/>
      <mx:DataGrid x="375" y="87" dataProvider="">
      <mx:columns>
      <mx:DataGridColumn headerText="fname" dataField="col1"/>
      <mx:DataGridColumn headerText="lname" dataField="col2"/>
      </mx:columns>
      </mx:DataGrid>
      <mx:Button x="58" y="207" id="b1" label="insert" />
      <mx:Button x="375" y="288" id="b2" label="select" />
      </mx:WindowedApplication>
