0 Replies Latest reply on Jun 1, 2010 1:49 PM by webacity
    popup window disappears
    webacity Level 1
      Hi
      I have a text box field:
        <form id="form1" name="form1" method="post" action="">
          <span id="sprytextfield1">
            <label for="calc2"></label>
            <input type="text" name="calc2" id="calc2" onchange="checkCalc()"/>
            <span class="textfieldRequiredMsg">A value is required.</span></span>
        </form>
      when user types in correct answer and hits return key, it calls a function:
      function checkCalc(){
          if (document.form1.calc2.value == "1"){
          MM_showHideLayers('pop1','','show','pop2','','hide');
          else { alert("you are incorrect!");
      </script>
      The popup window appears but only for a second and then it disappears
      I use the same MM_showHideLayers('pop1','','show','pop2','','hide') function elsewhere and the pop up remains open
      The pop up is a ap div, with default setting set to hidden. The function then shows the layer, by setting the visability to 'show'
      <p>Velit esse cillum dolore quis nostrud exercitation consectetur <span class="hyperlink" onmousedown="MM_showHideLayers('pop1','','show','pop2','','hide')" onmouseup="MM_effectHighlight('pop1 content', 1000, '#FFFFFF', '#EAEAEA', '#FFFFFF', false)">adipisicing</span> elit. In reprehenderit in voluptate lorem ipsum dolor sit amet, sed do eiusmod tempor incididunt. Ut labore et dolore magna aliqua.</p>
