5 Replies Latest reply on Jun 1, 2010 10:02 PM by Joe ... Ward
    Uploading Images
    GeorgeWS Level 1
      I have this to read the saved image:
      private
      function upload():void
      var uploader:Uploader = new Uploader();
      var dir:File = File.applicationStorageDirectory.resolvePath("images/");
      var files:Array = dir.getDirectoryListing();
      for (var i:uint = 0; i < files.length; i++)
      file = files[i];
      if (!file.isDirectory)
      uploader.addFile(file);
      uploader.addEventListener(Event.COMPLETE, uploadCompleteHandler);
      uploader.addEventListener(ProgressEvent.PROGRESS, progressHandler);
      uploader.start(UPLOAD_URL +
      "/upload.cfm");
      private function progressHandler(event:ProgressEvent):void
      trace("Progress", event.bytesLoaded, event.bytesTotal);
      * Upload complete handler.
      private function uploadCompleteHandler(event:Event):void
      trace("complete");
      This seems to be doing the right thing. When I use the Debugger it looks like its uploading the image. But It never gets to its destination. I am using ClodFusion 8. I made an errordebug.pdf page to show me whats going on. It says in the detail [empty string] and that my FileField is "File". To me that means I am not calling in the image. I can see that that the images are saved on the local machine. My upload.cfm is like this:
      <cffile action="upload" filefield="File" destination="c:\inetpub\wwroot\images\" accept="application/octet-stream"/>
      Any thoughts would be great for I am stumped.
      George
        • 1. Re: Uploading Images
          Joe ... Ward Level 4
          Without knowing what the Uploader class does, it's hard to know what is wrong. What data type does addFile() take?
          • 2. Re: Uploading Images
            GeorgeWS Level 1
            jpg
            • 3. Re: Uploading Images
              Okay, the file format is jpg, but what is the ActionScript data type?
              • 4. Re: Uploading Images
                GeorgeWS Level 1
                I use the web cam on my laptop (but have plans to move this to my new HTC Incredable) I got this to work befor but just cannot seem to remember what I did to get it going. But this is what I do with the captured image:
                private
                function getJPEG(bmd:BitmapData):ByteArray {
                var jpg:JPGEncoder = new JPGEncoder();
                return jpg.encode(bmd);
                So I see the images in the applicationStorageDirectory location then upload button pressed and this gets run:
                private
                function upload():
                void
                file = files[i];
                "/upload.cfm");
                I can get a test response from my upload.cfm I  know the above hits the cfm file. When I look at my ColdFusion error its telling me that Im not sending a file. I keep thinking its the filefield name.
                         filefield="file"
                         destination="c:\inetpub\wwwroot\Files\Displays\"
                         nameconflict="overwrite"
                Thanks for looking
                • 5. Re: Uploading Images
                  A File object doesn't represent the data in the file. Probably you need to read the file into a ByteArray using the FileStream class and pass that ByteArray to the Upload.addFile() method.
