1 Reply Latest reply on Jun 2, 2010 7:33 AM by gkaiseril
    Requiring form fields, error with script
    mazz930
      So, am trying to require fields in a form. all that is required is to enter a value. I tried using this script in the "on blur" action, and it does work, except it keeps popping up the message and wont let me enter a value. Whats wrong here?
      f = getField(event.target.name)
      if (f.value.length == 0)
         f.setFocus()
         //Optional Message - Comment out the next line to remove
         app.alert("This field is required. Please enter a value.")
        • 1. Re: Requiring form fields, error with script
          If you are trying to access the value of the field as a string. Also you might try using the 'Validation' tab. Using the on burr action will keep a user locked into that field. The Validation will throw the error but allow the user to move to another field. You should also have a final check of the form to make sure all of the required fields are filled in.
          if (event.value.toString().length == 0) {
             event.rc = false;
             this.getField(event.target.name).setFocus()
             app.alert("This field is required. Please enter a value.",  1, 0, 'Required Field')
