9 Replies Latest reply on Jun 4, 2010 12:31 PM by M. Ridcully
    How to set ID to a button inside a ToggleButtonBar?
    M. Ridcully
      There's a ToggleButtonBar element, populated from a ViewStack. I need to set IDs to individual buttons (this is needed for QA automation).
      How do I do this?
        • 1. Re: How to set ID to a button inside a ToggleButtonBar?
          samschauhan
          I hope you just want to know which particular button is clicked.
          In that case for yourToggleButtonBar you can set:
          itemClick="clickHandler(event);"
          and then you can use event.index to get the button clicked.
          If the question is still not answered please elaborate your question a bit.
          Regards,
          Sameer Chauhan
          • 2. Re: How to set ID to a button inside a ToggleButtonBar?
            M. Ridcully Level 1
            No, it's not what I need.
            If I just put a Button, or any other control, directly into MXML, I can set its ID: <mx:Button id="btn0" ..etc.
            Now I need to do the same, but for buttons, created by ToggleButtonBar.
            • 3. Re: How to set ID to a button inside a ToggleButtonBar?
              samschauhan Level 1
              Ok, Got it. I am afraid I dont know the solution, though pretty sure that some work-around will be there.
              Why can't you put IDs to all the components which you are providing inside the dataProvider for ToggleButtonBar?
              Regards,
              SAM
              • 4. Re: How to set ID to a button inside a ToggleButtonBar?
                M. Ridcully Level 1
                I don't know how to do this. dataProvider is a ViewStack. I tried setting "id" properties of elements, added to ViewStack as children, but this doesn't seem to affect anything.
                • 5. Re: How to set ID to a button inside a ToggleButtonBar?
                  samschauhan Level 1
                  Can you please share your code, I should be able to help you in that.
                  Regards,
                  SAM
                  • 6. Re: How to set ID to a button inside a ToggleButtonBar?
                    BhaskerChari Level 4
                    Hi Ridcully,
                    Can you please share your code, so that I should be able to help you in that.
                    Regards
                    Bhasker Chari
                    • 7. Re: How to set ID to a button inside a ToggleButtonBar?
                      M. Ridcully Level 1
                      Here's a relevant piece of MXML:
                      <mx:ToggleButtonBar id="selector" dataProvider="{content}"/>
                      <mx:ViewStack id="content" selectedIndex="{selector.selectedIndex}"/>
                      And here's a function, used to populate the content at runtime:
                      function addView(index:int, view:UIComponent):void {
                         var container:Container = Container(content.getChildAt(index));
                         container.removeAllChildren();
                         container.addChild(view);
                         view.percentWidth = view.percentHeight = 100;
                      The problem is, I don't know how to set "id" property of the buttons in the selector.
                      • 8. Re: How to set ID to a button inside a ToggleButtonBar?
                        Hi Ridcully,
                        Why do you require to set button ids for the ToggleButtonBar...?
                        If at all you want to get a reference to any button within the ToggleButtonBar you can get by using the getChildAt() method and you an perform the opertaions on it.
                        Say if your ToggleButtonBar id="selector" then you can get a reference to any button by using below kine of code...
                        var btn:Button = selector.getChildAt(index) as Button;
                        Check out the below example...In which I am getting a reference to the button clicked in ToggleButtonBar.
                        You can also see in the below example the name of button clicked coming in an Alert.
                        <?xml version="1.0"?>
                        <mx:Application
                        xmlns:mx="http://www.adobe.com/2006/mxml">
                        <mx:Script>
                        <![CDATA[
                        import mx.controls.Alert;
                        import mx.controls.Button;
                        import mx.events.ItemClickEvent;
                        // Event handler function to print a message
                        // describing the selected Button control.
                        private function clickHandler(event:ItemClickEvent):void {
                        myTA.text=
                        "Selected button index: " + String(event.index) +
                        "\n" + "Selected button label: " + event.label;
                        var btn:Button = selector.getChildAt(event.index) as Button;
                        Alert.show(selector.name);
                        </mx:Script>
                        <mx:Panel title="ToggleButtonBar Control Example" height="75%" width="75%"
                        paddingTop="
                        10" paddingLeft="10" paddingRight="10" paddingBottom="10">
                        <mx:Label width="100%" color="blue"
                        text="
                        Select a button in the ToggleButtonBar control."/>
                        <mx:TextArea id="myTA" width="100%" height="100%"/>
                        <mx:ToggleButtonBar id="selector" itemClick="clickHandler(event);">
                        <mx:dataProvider>
                        <mx:Array>
                        <mx:String>Flash</mx:String>
                        <mx:String>Director</mx:String>
                        <mx:String>Dreamweaver</mx:String>
                        <mx:String>ColdFusion</mx:String>
                        </mx:Array>
                        </mx:dataProvider>
                        </mx:ToggleButtonBar>
                        </mx:Panel>
                        </mx:Application>
                        If this post answers your question or helps, please kindly mark it as such.
                        Bhasker Chari
                        • 9. Re: How to set ID to a button inside a ToggleButtonBar?
                          M. Ridcully Level 1
                          As I said above - for QA automation.
                          Anyway. I seem to have found a way to set those IDs, but it's quite hackish and fragile. I'd really like for someone from Adobe to confirm that it will work under all scenarios:
                          <mx:ToggleButtonBar id="selector" dataProvider="{content}" childAdd="viewButtonAdded(event)"/>
                          ... and later in a script:
                          private var _numViews:int = 0;
                          private function viewButtonAdded(event:ChildExistenceChangedEvent):void {
                             event.relatedObject["id"] = "view_" + _numViews++;
