1 Reply Latest reply on Aug 16, 2007 12:58 PM by Newsgroup_User
    Multiple instances of jrun.exe running?
    NuckNuck
      Is it common for there to be more than one instance of jrun.exe running in a non-clustered installation of CF7? There have been episodes where jrun.exe seems to get taxed on moderately size queries. After looking at Task Manager on Win2K3 server - there are sometimes 3 or 4 instances of jrun.exe running. The first instance is usually very high (ex. 450 MB) while the other instance(s) hover around the 10-15 MB mark and remain constant. Does this sound like an issue that can be controlled by CFAdmin or are there issues with our configuration:
      Win2K3 Server (VMWare instance)
      CF7.01 (yes we know it needs a patch)
      512 MB RAM
      Any thoughts on this is appreciated.
      Thanks.
        • 1. Re: Multiple instances of jrun.exe running?
          Level 7
          Yes.
          A multi-server install (not a clustered) of CF could well have one instance
          of JRUN.EXE running for each CF instance. There's usually at least two: one
          for the initial CF instance, and one for the JMC. You can switch the JMC
          one off (starting it on the off-chance you need it, which is almost never).
          That's not especially high for a CF app server. We generally allocate the
          max 1.3GB (on Windows) to the JVM that each CF instance is using.
          > 512 MB RAM
          OK, that's not even enough RAM for a PC workstation these days, let alone a
          server! W2k3 itself needs around a minimum of 400MB to run. The default
          install of CF will want another 512MB.
          I would not run a desktop PC on less than 2GB RAM these days. And make
          that 4GB for a server. A low-spec'ed one.
          Adam
