3 Replies Latest reply on Jul 21, 2015 9:54 AM by rscott13
    .eps  "Can't Save Illustration. Can't Print Illustration."
    James Warcroft
      Quick background. . .
      Im a graphic artist and just built my new PC at work on Friday.
      On Monday I started installing everything, Windows 7, numerous programs, etc.
      I installed CS5 (Illustrator, Photoshop, InDesign) and, even though Ive only used Illustrator so far, it seems to be workign fine.
      When Ive finished a job I save it as a .eps so it can be opened in Roland Versaworks for printing.
      That was all workign fine, until this morning (Wednesday).
      Every time I try to save as a .eps I get the message "Can't save Illustration. Can't print Illustration."
      I did not shut down my PC Tuesday night, I leave my PC on overnight so I can jump straight back into things the next morning.
      Ive tried deleting my profile/properties folder, that didnt work.
      Ive uninstalled (and used the CS5 cleaner tool) then reinstalled twice today, that didnt work.
      Numerous restarts. That didnt work.
      All other formats (that I use and save as) work fine. Just cant save as an eps.
      I can open an eps, but if I try to save it I get tthe same message.
      Now. . .
      The only thing I did Tuesday afternoon was install Corel Draw X5.
      Could Corel have some how screwed with eps in some bazaar way?
      before I left work today I completely uninstalled Corel and CS5. I will reinstall CS5 tomorrow morning and see what happens.
      In the mean time. . . and suggestions?
        • 1. Re: .eps  "Can't Save Illustration. Can't Print Illustration."
          I have just got a brand new cpu.  Win 7 pro 64 bit.
          Also Illustrator 5.1 and photoshop, acrobat and indesign 5.1. and I have the same problem.  Eps files just wont save.  I deleted the prefs files and nothing.  I created a new admin account and that fixed it for half an hour but now nothing.  I work in a sign shop and my rip sftware also versaworks cant  find cut lines unless I use the .eps format.  Just so were all clear, If I create a new document and leave it blank.  I still cant save as eps.
          Please help, not impressed buying new software and having it completely not work.
          Dickie D
          • 2. Re: .eps  "Can't Save Illustration. Can't Print Illustration."
            I'm having the same issue. Just went from XP to Windows 7 on a new PC.
            Loaded CS5.
            Open .eps file I've already created and printed try to save to desktop (or anywhere else) and get the same "Can't Save Illustration. Can't Print Illustration"
            I can save as .ai and I can save as version3 or 8.
            Don't have a problem saving PS files as .eps.
            From the searching I've done online, it appears this is fairly common, yet I've not found the solution. I'm wondering if it's the windows 7 64 bit operating system?!?!
            Any help would be greatly appreciated.
            • 3. Re: .eps  "Can't Save Illustration. Can't Print Illustration."
              rscott13 Level 1
              UPDATE: printer drivers were not installed on new pc, set print to pdf and works fine
