0 Replies Latest reply on Jun 2, 2010 10:56 AM by Dan Caron
    Page Exporter Utility (PEU) 5 Script
    Dan Caron
      I love this script, It really has potential to shave valuable time off of our production (exporting Hundreds of pages manually to single files is tedious and time consuming). The problem I'm having is I'm hesitant to us it because it dosn't show warnings when there is a missing link or font. There's also no warning when it overwrites a file. My question is dose anyone know how to unsuppress the warnings? I've looked over the script and don't see anything that is actively suppressing them.
      Dan
      // PageExporterUtility5.0.js
      // An InDesign CS JavaScript
      // 08 NOV 2007
      // Copyright (C) 2007  Scott Zanelli. Lonelytree Software. (www.lonelytreesw.com)
      // Coming to you from Quincy, MA, USA
      // This program is free software; you can redistribute it and/or
      // modify it under the terms of the GNU General Public License
      // as published by the Free Software Foundation; either version 2
      // of the License, or (at your option) any later version.
      // This program is distributed in the hope that it will be useful,
      // but WITHOUT ANY WARRANTY; without even the implied warranty of
      // MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
      // GNU General Public License for more details.
      // You should have received a copy of the GNU General Public License
      // along with this program; if not, write to the Free Software
      // Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA  02110-1301, USA.
      var peuINFO = new Array();
      peuINFO["csVersion"] = parseInt(app.version);
      // Save the old interaction level
      if(peuINFO.csVersion == 3) { //CS1
          peuINFO["oldInteractionPref"] = app.userInteractionLevel;
          app.userInteractionLevel = UserInteractionLevels.interactWithAll;
      else { //CS2+
          peuINFO["oldInteractionPref"] = app.scriptPreferences.userInteractionLevel;
          app.scriptPreferences.userInteractionLevel = UserInteractionLevels.interactWithAll;
      // See if a document is open. If not, exit
      if((peuINFO["numDocsToExport"] = app.documents.length) == 0){
          byeBye("Please open a document and try again.",true);
      // Global Variable Initializations
      var VERSION_NAME = "Page Exporter Utility 5.0"
      var pseudoSingleton = 0;
      var progCurrentPage = 0;// Used for progress bar
      var progTotalPages = 0; // Used for progress bar
      var commonBatchINFO = getNewTempENTRY(); // Used if "Set For All Batch Jobs" is selected
      commonBatchINFO["infoLoaded"] = false;
      peuInit(); // Initialize commonly needed info
      // Store information needed for batch processing (valid for single also)
      var printINFO = new Array();
      // Get all needed info by looping for each document being exported
      for(currentDoc = 0; currentDoc < peuINFO.numDocsToExport; currentDoc++) {
          // Get name of document and set it as the base name
          // minus the extention if it exists
          var tempENTRY = getNewTempENTRY(); // "Struct" for current document info
          tempENTRY.theDoc = app.documents[currentDoc]
          tempENTRY.singlePage = (tempENTRY.theDoc.documentPreferences.pagesPerDocument==1)?true:false;
          tempENTRY.getOut = true;
          var baseName = (tempENTRY.theDoc.name.split(".ind"))[0];
          // Display the dialog box and loop for correct info
          if((!commonBatchINFO.infoLoaded && peuINFO.batchSameForAll) || (!peuINFO.batchSameForAll) ){// get all info
              do{
                  tempENTRY.getOut = true; // For handling input errors
                  var mainDialog = createMainDialog(tempENTRY.theDoc.name, currentDoc+1, peuINFO.numDocsToExport);
                  // Exit if cancel button chosen
                  if(!mainDialog.show() ){
                      mainDialog.destroy();
                      byeBye("Exporting has canceled by user.",peuINFO.sayCancel);
                  if(formatTypeRB.selectedButton == 4 - peuINFO.adjustForNoPS){
                      changePrefs();
                      tempENTRY.getOut = false;
                      continue;
                  // Read info from dialog items and keep as defaults and place in tempENTRY
                  peuINFO.defaultDir = outputDirs.selectedIndex;
                  // The index of the selected directory is the same as the
                  // index in the array of directories.
                  tempENTRY.outDir = peuINFO.dirListArray[peuINFO.defaultDir];
                  // Type of renaming to do
                  tempENTRY.nameConvType = namingConvention.selectedButton
                  // The base name to add page info to
                  tempENTRY.baseName = removeColons(removeSpaces(newBaseName.editContents) );
                  // The start [and end] page numbers
                  var startEndPgs = startEndPgs.editContents;
                  // Wether to do spreads or not
                  peuINFO.doSpreadsON = (doSpreads.checkedState)?1:0;
                  tempENTRY.doSpreadsON = peuINFO.doSpreadsON;
                  // Wether to send entire file as one document
                  peuINFO.doOneFile = (oneFile.checkedState)?1:0;
                  tempENTRY.doOneFile = peuINFO.doOneFile;
                  // Export format type
                  tempENTRY.formatType = formatTypeRB.selectedButton + peuINFO.adjustForNoPS;
                  // Set persistence during warnings
                  peuINFO.editStartEndPgs = startEndPgs;
                  baseName = tempENTRY.baseName;
                  peuINFO.exportDefaultType = tempENTRY.formatType;
                  // Determine if page replacement token exists when the page token option is used
                  if(peuINFO.pageNamePlacement == 2){
                      var temp = tempENTRY.baseName.indexOf("<#>");
                      if(temp == -1){//Token isn't there
                          alert("There is no page item token (<#>) in the base name. Please add one or change the page naming placement preference.");
                          tempENlert.getOut = false;
                          pseudoSingleton--; // Allow prefs to be accessed again, but just once
                          continue;
                      else
                          pseudoSingleton++;
                  else // Try to remove any <#>s as a precaution
                      tempENTRY.baseName = tempENTRY.baseName.replace(/<#>/g,"");
                  // Layer Versioning & Batch options
                  if(currentDoc < 1){
                      peuINFO.layersON = (doLayers.checkedState)?1:0;
                      if(peuINFO.numDocsToExport > 1){
                          peuINFO.batchSameForAll = (commonBatch.checkedState)?1:0;
                          peuINFO.batchON = (doBatch.checkedState)?1:0;
                          if(!peuINFO.batchON)
                              peuINFO.numDocsToExport = 1;
                  //Check if spreads chosen with 'Add ".L"' option as this isn't supported.
                  if(peuINFO.doSpreadsON && tempENTRY.nameConvType == 1){
                      alert ("Spreads cannot be used with the 'Add \".L\"' option.\nThis combination is not supported. (1.1)");
                      tempENTRY.nameConvType = 0;
                      continue;
                  else if(peuINFO.doSpreadsON && tempENTRY.nameConvType == 4){
                      alert ("Spreads cannot be used with the 'Numeric Override' option.\nThis combination is not supported. (1.2)");
                      continue;
                  // Check if "Send Entire File At Once" is selected with JPG or EPS
                  if(peuINFO.doOneFile && tempENTRY.formatType > 1 ){
                      alert ("The 'Send Entire File At Once' option can only be used with PostScript or PDF formats. (1.3)");
                      continue;
                  // Check if: batch printing and using the "Same for all jobs options" and a page range other than "All" was used
                  if(peuINFO.doBatch && peuINFO.batchSameForAll && startEndPgs != "All"){
                      alert ("The 'Set For All Batch Jobs' option can only be used with a Page Range of 'All'. Page Range has been reset to 'All'. (1.4)");
                      startEndPgs = "All";
                  // Create page info, skip if doing entire file as one
                  var tempPageCount = 0;
                  if(tempENTRY.doOneFile)
                      tempPageCount = 1;
                  else{
                      // Get names of all the pages. Needed when pages are named using sectioning
                      tempENTRY = recordPgNames(tempENTRY);
                      // Check Page Validity and get Page counts of entered section(s)
                      var temp = checkPages(tempENTRY, startEndPgs);
                      tempENTRY = temp[0];
                      tempPageCount = temp[1];
                      temp = null; // Free it up
              } while(!tempENTRY.getOut);
              // Remove dialog from memory
              // Determine if tag will fit correctly
              tempENTRY.useTag = usePgInfoTag(tempENTRY.theDoc.viewPreferences.horizontalMeasurementUnits,tempENTRY.theDoc.documentPreferences.pageWidth);
                  // Get the format info for this document
              switch(tempENTRY.formatType){
                  case 0://PS
                  tempENTRY.psINFO = getPSoptions(tempENTRY.theDoc.name.split(".ind")[0]);
                  break;
                  case 1://PDF
                  tempENTRY.pdfPRESET = getPDFoptions(tempENTRY);
                  break;
                  case 2: // EPS Formatting
                  tempENTRY.epsINFO = getEPSoptions(tempENTRY.theDoc.name.split(".ind")[0]);
                  peuINFO.origSpread = app.epsExportPreferences.epsSpreads;// Used to reset to original state when done
                  app.epsExportPreferences.epsSpreads = peuINFO.doSpreadsON;
                  break;
                  case 3: // JPEG Formatting
                  tempENTRY.jpegINFO = getJPEGoptions(tempENTRY.theDoc.name.split(".ind")[0]);
                  break;
              // If Specific Directory was chosen for the output directory, get it now
              if(peuINFO.defaultDir == 0){
                  tempENTRY.outDir = getDirectory("Please select the output directory:",peuINFO.startingDirectory);
                  if(tempENTRY.outDir != null)
                      tempENTRY.outDir += "/";
                  else
                      byeBye("Exporting has been canceled by user.", peuINFO.sayCancel);
              // Set the common elements for all batch jobs if it was selected
              if(!commonBatchINFO.infoLoaded && peuINFO.batchSameForAll){
                  commonBatchINFO.infoLoaded = true;
                  commonBatchINFO.pageNamePlacement = tempENTRY.pageNamePlacement;
                  commonBatchINFO.outDir = tempENTRY.outDir;
                  commonBatchINFO.nameConvType = tempENTRY.nameConvType
                  commonBatchINFO.doSpreadsON = tempENTRY.doSpreadsON;
                  commonBatchINFO.doOneFile = tempENTRY.doOneFile;
                  commonBatchINFO.formatType = tempENTRY.formatType;
                  commonBatchINFO.psINFO = tempENTRY.psINFO;
                  commonBatchINFO.pdfPRESET = tempENTRY.pdfPRESET
                  commonBatchINFO.epsINFO = tempENTRY.epsINFO
                  commonBatchINFO.jpegINFO = tempENTRY.jpegINFO;
          } // End each/first of batch
          else{ // Get the base name for other batch jobs
              do{
                  var nameDialog = app.dialogs.add({name:(VERSION_NAME + ": Base Name for \"" + tempENTRY.theDoc.name + "\"" + ((peuINFO.numDocsToExport==1)?"":" (" + (currentDoc+1) + " of " + peuINFO.numDocsToExport + " documents)") ), canCancel:true} );
                  with (nameDialog){
                      with (dialogColumns.add() ){
                          with(dialogRows.add() ){
                          staticTexts.add({staticLabel:"Enter the Base Name for \"" + tempENTRY.theDoc.name + "\""} );
                          var newBaseName = textEditboxes.add({editContents:baseName, minWidth:135} );
                              staticTexts.add({staticLabel:"", minWidth:400} );
                  if(!nameDialog.show() ){
                      nameDialog.destroy();
                      byeBye("User canceled export.",peuINFO.sayCancel);
                  else{
                              alert("There is no page item token (<#>) in the base name. Please add one or click cancel in the next dialog box.");
              }while(!tempENTRY.getOut);
              // Set pgStart and pgEnd, forcing "All" pages to output
              tempENTRY = (checkPages(tempENTRY, "All"))[0];
              // The page count is all pages due to common batching
              tempPageCount = tempENTRY.theDoc.pages.length;
              // This info is common, get it from commonBatchINFO:
              tempENTRY.pageNamePlacement = commonBatchINFO.pageNamePlacement;
              tempENTRY.outDir = commonBatchINFO.outDir;
              tempENTRY.nameConvType = commonBatchINFO.nameConvType
              tempENTRY.doSpreadsON = commonBatchINFO.doSpreadsON;
              tempENTRY.doOneFile = commonBatchINFO.doOneFile;
              tempENTRY.formatType = commonBatchINFO.formatType;
              tempENTRY.psINFO = commonBatchINFO.psINFO;
              tempENTRY.pdfPRESET = commonBatchINFO.pdfPRESET
              tempENTRY.epsINFO = commonBatchINFO.epsINFO
              tempENTRY.jpegINFO = commonBatchINFO.jpegINFO;
          // Get any layering info
          if(peuINFO.layersON){
              tempENTRY.layerINFO = layerManager(tempENTRY.theDoc);
              if (tempENTRY.layerINFO == null) // Only one layer, turn it off for this doc
                  tempENTRY.layersON = false;
              else
                  tempENTRY.layersON = true;
          // Sum up pages for the grand total for use in progress bar
          var temp = 1;
          if(peuINFO.doProgressBar && tempENTRY.layersON){
              // Figure tally for progress bar to include versions
              for(i=0;i < tempENTRY.layerINFO.verControls.length; i++)
                  if (tempENTRY.layerINFO.verControls[i] == 1)
                      temp++;
              if(!peuINFO.baseLaersAsVersion)
                  temp--;
          progTotalPages += (tempPageCount*temp);
          // All info for this doc is finally gathered, add it to the main printINFO array
          printINFO.push(tempENTRY);
          // Only one chance to change prefs: trigger singleton
          pseudoSingleton++;
      }// end of main for loop
      savePrefs(); // Record any changes
      // Initiallize progress bar if available
      if(peuINFO.doProgressBar)
          app.createProgressBar("Exporting Pages...", 0, progTotalPages, true);
      // Export by looping through all open documents if using batch option, otherwise just the front document is exported
      for(currentDoc = 0; currentDoc < printINFO.length; currentDoc++){
          var currentINFO = printINFO[currentDoc];
          // Set message in progress bar if available
          if(peuINFO.doProgressBar){
                  var progCancel = app.setProgress(currentINFO.theDoc.name);
                  if(progCancel)
          // Set format options here so it's done just once per document
          setExportOption(currentINFO);
          // "Do one file" or PS/PDF with one page:
          if (currentINFO.doOneFile || currentINFO.singlePage){
              // Remove page token if it was entered and this name positioning option is set
              currentINFO.baseName = currentINFO.baseName.replace(/<#>/g,"");
              if(currentINFO.layersON){
                  var theLayers = currentINFO.theDoc.layers;
                  var baseControls = currentINFO.layerINFO.baseControls;
                  var versionControls = currentINFO.layerINFO.verControls;
                  var lastVersion = -1;
                  // Loop for versioning
                   for(v = 0; v < versionControls.length; v++){
                      if(!versionControls[v])
                          continue;
                      if(lastVersion != -1)// Turn the last layer back off
                          theLayers[lastVersion].visible = false;
                      lastVersion = v;
                      theLayers[v].visible = true;
                      currentINFO.outfileName = addPartToName(currentINFO.baseName, theLayers[v].name, peuINFO.layerBeforeON)
                      // Export this version
                      exportPage(currentINFO, PageRange.allPages);
                      // Advance progress bar if available
                          advanceBar();
                  // If Base layer/s is/are to be output as a version, do it now
                  if(peuINFO.baseLaersAsVersion){
                      lastVersion = -1;
                      // Turn off all versioning layers
                      for(v = 0; v < currentINFO.layerINFO.baseControls.length; v++){
                          if(currentINFO.layerINFO.baseControls[v])// its a base layer, keep track of last base version layer number
                              lastVersion = v;
                          else
                              theLayers[v].visible = false;
                      if (!lastVersion == -1){// Only export if there was a base version
                          currentINFO.outfileName = addPartToName(currentINFO.baseName, theLayers[lastVersion].name, peuINFO.layerBeforeON);
                          // Export the base layer(s)
                              advanceBar();
              else{ // No layer versioning, just export
                  currentINFO.outfileName = currentINFO.baseName;
                      advanceBar();
                  byeBye("Done exporting as a single file.",true);
          else{ // Do single pages/spreads
              if (!currentINFO.hasNonContig)
                  // Pages are contiguous, can just export
                  outputPages(currentINFO.pgStart, currentINFO.pgEnd, currentINFO);
              else{ // Export non-contiguous
                  // Loop through array of page sections
                  for (ii = 0; ii < currentINFO.nonContigPgs.length; ii++){
                      temp = currentINFO.nonContigPgs[ii];
                      // Here we handle the start/end pages for any non-contig that has "-"
                      if (temp.indexOf("-") != -1){
                          temp2 = temp.split("-");
                          outputPages(temp2[0],temp2[1], currentINFO);
                      else // The non-contiguous page is a single page
                          outputPages(temp, temp, currentINFO);
          // Set the spread settings back to what it was originally
          try{
              switch (currentINFO.formatType){
                  case 0: // PostScript Formatting
                      theDoc.printPreferences.printSpreads = peuINFO.origSpread;
                      break;
                  case 1: // PDF Formatting
                      currentINFO.pdfPRESET.exportReaderSpreads = peuINFO.origSpread;
                      break;
                      app.epsExportPreferences.epsSpreads = peuINFO.origSpread;
                      break;
                      app.jpegExportPreferences.exportingSpread = peuINFO.origSpread;
                      break;
          catch(e){/*Just ignore it*/}
      byeBye("The requested pages are done being exported.",true); // Last line of script execution
      /*         Operational Functions           */
       * Handle exporting
      function outputPages(pgStart, pgEnd, currentINFO){
          var pgRange;
          var layerName = "";
          var numVersions;
          var currentPage;
          var numericallyLastPage;
          if (currentINFO.layersON){
              numVersions = versionControls.length;
              // Compensate for base layers as a version
                  numVersions++;
          else
              numVersions = 1;
          for (v = 0; v < numVersions; v++){
                  if(v == (numVersions - 1) && peuINFO.baseLaersAsVersion){
                      var currentLayer = -1;
                      // Base layer(s) are to be output as a version
                      for(slbm = 0; slbm < baseControls.length; slbm++){
                          if(baseControls[slbm])// its a base layer, use its name for page name
                              currentLayer = slbm;
                          else
                              theLayers[slbm].visible = false;
                      // Check if there was no base layer at all
                      if (currentLayer == -1)
                          layerName = "**NO_BASE**"
                      else
                          layerName = theLayers[currentLayer].name;
                  else{
                          continue;
                      lastVersion = v;
                      layerName = theLayers[v].name;
              if (currentINFO.nameConvType == 4){
                  currentPage = pgStart;
                  numericallyLastPage = pgEnd;
              else if (currentINFO.doSpreadsON){
                  currentPage = pgStart - 1;
              else {
                  currentPage = getPageOffset(pgStart, currentINFO.pageNameArray , currentINFO.pageRangeArray);
                  numericallyLastPage = getPageOffset(pgEnd, currentINFO.pageNameArray, currentINFO.pageRangeArray);
              if(layerName != "**NO_BASE**"){
                  do{
                      currentINFO.outfileName = getPageName(currentPage, layerName, currentINFO);
                          pgRange = currentINFO.pageRangeArray[getPageOffset(currentINFO.theDoc.spreads[currentPage].pages[0].name, currentINFO.pageNameArray, currentINFO.pageRangeArray)];
                      else if (currentINFO.nameConvType == 4)
                          pgRange = currentINFO.pageRangeArray[currentPage-1];
                      else
                          pgRange = currentINFO.pageRangeArray[currentPage];
                      // Do the actual export:
                      exportPage(currentINFO, pgRange);
                      // Update progress bar if available
                          advanceBar();
                      currentPage++;
                  } while(currentPage <= numericallyLastPage);
       * Export the page
      function exportPage(currentINFO, pgRange){
          var outFile = currentINFO.outDir + currentINFO.outfileName;
                  with(currentINFO.theDoc.printPreferences){
                      printFile = new File(outFile + ((currentINFO.psINFO.ext)?".ps":""));
                      pageRange = pgRange;
                  // Needed to get around blank pages using separations
                  try{
                      currentINFO.theDoc.print(false);
                  catch(e){/*Just skip it*/}
                  break;
                  app.pdfExportPreferences.pageRange = pgRange;
                  currentINFO.theDoc.exportFile(ExportFormat.pdfType, (new File(outFile + ".pdf")), false, currentINFO.pdfPRESET);
                  break;
                  app.epsExportPreferences.pageRange = pgRange;
                  currentINFO.theDoc.exportFile(ExportFormat.epsType, (new File(outFile + ".eps")), false);
                  break;
                  if(pgRange == PageRange.allPages){
                      app.jpegExportPreferences.jpegExportRange = ExportRangeOrAllPages.exportAll;
                  else{
                      app.jpegExportPreferences.jpegExportRange = ExportRangeOrAllPages.exportRange;
                      app.jpegExportPreferences.pageString = pgRange;
                  currentINFO.theDoc.exportFile(ExportFormat.jpg, (new File(outFile + ".jpg")), false);
                  break;
       * Create a name for the page being exported
      function getPageName(currentPage, layerName, currentINFO){
          var pgRename = "";
              currentINFO["currentSpread"] = currentINFO.theDoc.spreads[currentPage].pages;
          switch (currentINFO.nameConvType){
              case 3: // Odd/Even pages/spreads = .LA.F/LA.B, LB.F/LB.B ...
                  pgRename = makeLotName(currentPage+1, peuINFO.subType);
                  break;
              case 2: // Odd/Even pages/spreads = .F/.B
                  pgRename = ((currentPage+1)%2 == 0) ? "B" : "F";
                  break;
              case 1: // Add ".L" to the page name
                  pgRename = "L" + currentINFO.pageNameArray[currentPage];
                  break;
              case 0: case 4:// As is or Numeric Override
                              // Optionally add "P" and any zeros if options chosen and is numerically named
                              // otherwise, just the "seperatorChar" is added to page name
                      // Loops through number of pages per spread
                      // and adds each page name to the final name (P08.P01)
                      for (j = 0; j < currentINFO.currentSpread.length; j++){
                          if(currentINFO.currentSpread[j].appliedSection.includeSectionPrefix)
                              var tempPage = currentINFO.pageRangeArray[getPageOffset(currentINFO.currentSpread[j].name, currentINFO.pageNameArray, currentINFO.pageRangeArray)];
                          else
                              var tempPage = currentINFO.pageNameArray[getPageOffset(currentINFO.currentSpread[j].name, currentINFO.pageNameArray, currentINFO.pageRangeArray)];
                          var tempPageNum = parseInt(tempPage,10);
                          /* If section name starts with a number, need to compare length of orig vs parsed
                           * to see if the page name is solely a number or a combo num + letter, etc.
                          if (! isNaN(tempPageNum) && ((""+tempPage).length == (""+tempPageNum).length )){
                              if (peuINFO.addZeroON)
                                  tempPage = addLeadingZero(tempPageNum, currentINFO.theDoc.pages.length);
                              if (peuINFO.addPon)
                                  tempPage = "P" + tempPage;
                          pgRename = (j==0) ? tempPage : pgRename + peuINFO.charList[peuINFO.seperatorChar] + tempPage;
                  else {
                      // Create a new name for an individual page
                          pgRename = currentPage;
                      else
                          pgRename = currentINFO.pageNameArray[currentPage];
                      if (! isNaN(parseInt(pgRename,10)) && (""+pgRename).length == (""+parseInt(pgRename,10)).length) {
                              pgRename = addLeadingZero(pgRename, currentINFO.theDoc.pages.length);
                          if (peuINFO.addPon)
                              pgRename = "P" + pgRename;
                  break;
              pgRename = addPartToName(pgRename, layerName, peuINFO.layerBeforeON);
          // Add page name to base name based on option selected
              pgRename = removeColons(currentINFO.baseName.replace(/<#>/g,pgRename) );
          else
              pgRename = addPartToName(currentINFO.baseName, pgRename,peuINFO.pageNamePlacement);
          return pgRename;
       * Add a name part before or after a given base string
      function addPartToName(theBase, addThis, addBefore){
          //Remove any colons
          theBase = removeColons(theBase);
          addThis = removeColons(addThis);
          return (addBefore) ? (addThis + peuINFO.charList[peuINFO.seperatorChar] + theBase ):(theBase + peuINFO.charList[peuINFO.seperatorChar] + addThis);
       * Find the offset page number for a page by its name
      function getPageOffset(pgToFind, pageNameArray, pageRangeArray){
          var offset;
          for(offset = 0; offset<pageRangeArray.length;offset++){
              if((""+ pgToFind).toLowerCase() == (("" + pageNameArray[offset]).toLowerCase() ) || (""+ pgToFind).toLowerCase() == (("" + pageRangeArray[offset]).toLowerCase() ) )
                  return offset;
          return -1;
       * Replace any colons with specialReplaceChar
      function removeColons(tempName){
          return tempName.replace(/:/g,peuINFO.charList[peuINFO.specialReplaceChar]);
       * Remove spaces from front and end of name
      function removeSpaces(theName){
          // Trim any leading or trailing spaces in base name
          var i,j;
          for(i = theName.length-1;i>0 && theName.charAt(i) == " ";i--);// Ignore any spaces on end of name
          for(j = 0; j<theName.length && theName.charAt(j) == " ";j++);// Ignore any spaces at front of name
          theName = theName.substring(j,i+1);
          return theName
       * Add leading zero(s)
      function addLeadingZero(tempPageNum, pageCount){
          if(peuINFO.zeroPadding == 0){
              // Normal padding
              if((tempPageNum < 10 && pageCount < 100) || (tempPageNum > 9 && pageCount > 99 && tempPageNum < 100))
                  return addSingleZero(tempPageNum);
              else if(tempPageNum < 10 && pageCount > 99)
                  return addDoubleZero(tempPageNum);
              else
                  return ("" + tempPageNum);
          }else if(peuINFO.zeroPadding == 1){
              // Pad to 2 digits
              if(tempPageNum < 10)
              else
          }else{
              // Pad to 3 digits
              else if(tempPageNum < 100)
              else
       * Add leading zero helper for single
      function addSingleZero(pgNum){
          return ("0" + pgNum);
       * Add leading zero helper for double
      function addDoubleZero(pgNum){
          return ("00" + pgNum);
       * Create lot name from page number
      function makeLotName(thePage, subType){
          var iii = thePage;
          var curr = 0;
          var alphaBet = "ABCDEFGHIJKLMNOPQRSTUVWXYZ";
          var lotName = "L";
          if(subType == 0){
              while(iii>52){
                  curr = Math.floor((iii-1)/52)-1;
                  lotName += alphaBet[curr];
                  if(curr >= 0)
                      iii -= 52*(1+curr);
                  else
                      iii -= 52;
              lotName += alphaBet[Math.floor((iii-1)/2)%26];
          else
              for(iii=thePage; iii>0; iii-=52)
          return lotName += (thePage & 0x1)?".F":".B";
       * Advance progress bar one unit
      function advanceBar(){
          var progCancel = app.setProgress(++progCurrentPage);
          if(progCancel)
       * Create an Empty tempENTRY "struct"
      function getNewTempENTRY(){
          var newTempENTRY = new Array();
          newTempENTRY["theDoc"] = null;
          newTempENTRY["singlePage"] = null;
          newTempENTRY["getOut"] = null;
          newTempENTRY["outDir"] = null;
          newTempENTRY["outfileName"] = "";
          newTempENTRY["nameConvType"] = null;
          newTempENTRY["baseName"] = null;
          newTempENTRY["doSpreadsON"] = null;
          newTempENTRY["doOneFile"] = null;
          newTempENTRY["formatType"] = null;
          newTempENTRY["layersON"] = null;
          newTempENTRY["hasNonContig"] = false;
          newTempENTRY["nonContigPgs"] = null;
          newTempENTRY["pageNameArray"] = new Array();
          newTempENTRY["pageRangeArray"] = new Array();
          newTempENTRY["psINFO"] = null;
          newTempENTRY["pdfPRESET"] = null;
          newTempENTRY["epsINFO"] = null;
          newTempENTRY["jpegINFO"] = null;
          newTempENTRY["layerINFO"] = null;
          newTempENTRY["useTag"] = null;
          newTempENTRY["pgStart"] = null;
          newTempENTRY["pgEnd"] = null;
          return newTempENTRY;
       * Record all the page/spread names
      function recordPgNames(tempENTRY){
          for (i = 0; i < tempENTRY.theDoc.documentPreferences.pagesPerDocument; i++){
              var aPage = tempENTRY.theDoc.pages.item(i);
              tempENTRY.pageNameArray[i] = aPage.name;
              tempENTRY.pageRangeArray[i] = (aPage.appliedSection.includeSectionPrefix)? aPage.name : (aPage.appliedSection.name + aPage.name);
          return tempENTRY;
       * Set the export options
      function setExportOption(currentINFO){
              // Set any options here instead of with each page
                  setPSoptions(currentINFO);
                  break;
                  // Nothing to do
                  break;
                  setEPSoptions(currentINFO.epsINFO);
                  break;
                  setJPEGoptions(currentINFO.jpegINFO);
                  break;
       * Get PostScript format options
      function getPSoptions(docName){
          var psOptions = new Array();
          psOptions["ignore"] = true;
          var tempGetOut, PSdlog, pgHeight, pgWidth;
          var changeAddPSextention, tempBaseName;
          var printPreset;
          do{
              tempGetOut = true;
              PSdlog = app.dialogs.add({name:"PostScript Options for \"" + docName + "\"", canCancel:true} );
              with (PSdlog)
                      with (dialogRows.add() )
                          staticTexts.add({staticLabel:"Print Presets:"} );
                      printPreset = dropdowns.add({stringList:peuINFO.psPrinterNames , minWidth:236, selectedIndex:peuINFO.defaultPrintPreset} );
                          staticTexts.add({staticLabel:"Override PS Page Size (" + peuINFO.measureLableArray[peuINFO.measurementUnits] + ")"} );
                      with (borderPanels.add() )
                              with (dialogRows.add() ){
                                  staticTexts.add({staticLabel:"Width:", minWidth:45} );
                                  pgWidth = textEditboxes.add({editContents:"0", minWidth:53} );
                                  staticTexts.add({staticLabel:"Height:", minWidth:45} );
                                  pgHeight = textEditboxes.add({editContents:"0", minWidth:54} );
                          staticTexts.add({staticLabel:"Add \".ps\" to end of file name"} );
                          changeAddPSextention = dropdowns.add({stringList:["No","Yes"], selectedIndex:peuINFO.addPSextention} )
              if((PSdlog.show()) ){
                  // Get the page height + width
                  pgHeight = parseFloat(pgHeight.editContents);
                  pgWidth = parseFloat(pgWidth.editContents);
                  // Check entered H & W for error
                  if(isNaN(pgHeight) || isNaN(pgWidth) || pgHeight < 0 || pgWidth < 0 ){
                      alert ("Both page height and width must be numeric and greater than zero (3.1).");
                      pgHeight = "0";
                      pgWidth  = "0";
                      tempGetOut = false;
                      continue;
                  if(pgHeight > 0 && pgWidth > 0) // User changed size, use the new size
                      psOptions.ignore = false;
                  psOptions["height"] = pgHeight + peuINFO.measureUnitArray[peuINFO.measurementUnits];
                  psOptions["width"] = pgWidth + peuINFO.measureUnitArray[peuINFO.measurementUnits];
                  psOptions["ext"] = changeAddPSextention.selectedIndex;
                  peuINFO.addPSextention = psOptions["ext"];
                  psOptions["preset"] = printPreset.selectedIndex
                  peuINFO.defaultPrintPreset = psOptions.preset;
                  savePrefs();
                  PSdlog.destroy();
              else{
                  PSdlog.destroy();
                  byeBye("Exporting has been canceled by user.",peuINFO.sayCancel);
          } while(!tempGetOut);
          return psOptions;
       * Set Postscript options
      function setPSoptions(theINFO){
              activePrinterPreset = peuINFO.csPSprinters[theINFO.psINFO.preset];
              peuINFO.origSpread = printSpreads; // Used to reset to original state when done
              printSpreads = theINFO.doSpreadsON;
              if(colorOutput != ColorOutputModes.separations && colorOutput != ColorOutputModes.inripSeparations)
                  printBlankPages = true;
              if (theINFO.useTag)
                  pageInformationMarks = true;
              else
                  pageInformationMarks = false;
              if(!theINFO.psINFO.ignore){
                  try{
                      paperSize = PaperSizes.custom;
                      paperHeight = theINFO.psINFO.height;
                      paperWidth = theINFO.psINFO.width;
                  catch(Exception){
                      alert ("The current PPD doesn't support custom page sizes. The page size from the Print Preset will be used (3.2).");
       * Get PDF options
      function getPDFoptions(theINFO){
          var PDFdlog = app.dialogs.add({name:"PDF Options for \"" + theINFO.theDoc.name.split(".ind")[0] + "\"", canCancel:true} );
          var temp = new Array();
          for(i=0;i<app.pdfExportPresets.length;i++)
              temp.push(app.pdfExportPresets[i].name);
          // Test if default PDFpreset is greater # than actual list.
          // This occurs if one was deleted and the last preset in the list was the default
          if(peuINFO.defaultPDFpreset > temp.length-1)
              peuINFO.defaultPDFpreset = 0;
          with (PDFdlog)
                      staticTexts.add({staticLabel:"PDF Export Preset:"} );
                  pdfPresets = dropdowns.add({stringList: temp, minWidth:50, selectedIndex:peuINFO.defaultPDFpreset} );
          if(PDFdlog.show() ){
              temp = app.pdfExportPresets[pdfPresets.selectedIndex];
              peuINFO.defaultPDFpreset = pdfPresets.selectedIndex;
              peuINFO.origSpread = temp.exportReaderSpreads;
              try{
                  temp.exportReaderSpreads = theINFO.doSpreadsON;
                  temp.pageInformationMarks = (theINFO.useTag && temp.cropMarks)?true:false;
              }catch(e){/*ignore it*/}
              PDFdlog.destroy();
              return temp;
          else{
              PDFdlog.destroy();
              byeBye("PDF exporting has been canceled by user.", peuINFO.sayCancel);
       * Get JPEG options
      function getJPEGoptions(docName){
          var JPEGdlog = app.dialogs.add({name:"JPEG Options for \"" + docName + "\"", canCancel:true} );
          with (JPEGdlog)
                      staticTexts.add({staticLabel:"Quality:"} );
                  JPEGquality = dropdowns.add({stringList:(new Array("Low","Medium","High","Maximum")) , minWidth:50, selectedIndex:peuINFO.defaultJPEGquality} );
                      staticTexts.add({staticLabel:"Encoding Type:"} );
                      JPEGrender = dropdowns.add({stringList:["Baseline","Progressive"] , minWidth:50, selectedIndex:peuINFO.defaultJPEGrender } );
          if(JPEGdlog.show() ){
              peuINFO.defaultJPEGquality = JPEGquality.selectedIndex;
              temp["qualityType"] = peuINFO.defaultJPEGquality;
              peuINFO.defaultJPEGrender = JPEGrender.selectedIndex;
              temp["renderType"] = peuINFO.defaultJPEGrender;
          else{
              JPEGdlog.destroy();
              byeBye("JPEG exporting has been canceled by user.",peuINFO.sayCancel);
          JPEGdlog.destroy();
          return temp;
       * Set JPEG options
      function setJPEGoptions(theINFO){
          with(app.jpegExportPreferences){
              peuINFO.origSpread = exportingSpread; // Used to reset to original state when done
              exportingSpread = currentINFO.doSpreadsON;
              exportingSelection = false; // Export the entire page
              if(peuINFO.csVersion > 3)
              switch (theINFO.qualityType){
                  case 0:
                      jpegQuality = JPEGOptionsQuality.low;
                      break;
                  case 1:
                      jpegQuality = JPEGOptionsQuality.medium;
                      break;
                  case 2:
                      jpegQuality = JPEGOptionsQuality.high;
                      break;
                  case 3:
                      jpegQuality = JPEGOptionsQuality.maximum;
                      break;
              jpegRenderingStyle = (theINFO.renderType)? JPEGOptionsFormat.baselineEncoding : JPEGOptionsFormat.progressiveEncoding;
       * Get EPS options
      function getEPSoptions(docName){
          var epsOptions = new Array();
          var epsDialog = app.dialogs.add({name:"EPS Options for \"" + docName + "\"", canCancel:true} );
          var oldBleed = peuINFO.bleed;
          with (epsDialog){
              // Left Column
                              staticTexts.add({staticLabel:"Flattener Presets:"} );
                          changeFlattenerPreset = dropdowns.add({stringList:peuINFO.flattenerNames , minWidth:180, selectedIndex:peuINFO.defaultFlattenerPreset} );
                              changeIgnoreOverride = checkboxControls.add({staticLabel:"Ignore Overrides", checkedState:peuINFO.ignoreON} );
                              staticTexts.add({staticLabel:"Preview Type:"} );
                          changePreviewPreset = dropdowns.add({stringList:peuINFO.previewTypes , minWidth:180, selectedIndex:peuINFO.defaultPreview} );
                              staticTexts.add({staticLabel:"Bleed:"} );
                              changeBleedVal = realEditboxes.add({editValue:peuINFO.bleed, minWidth:60} );
                              staticTexts.add({staticLabel:peuINFO.measureLableArray[peuINFO.measurementUnits]} );
                              staticTexts.add({staticLabel:"OPI Options:"} );
                              staticTexts.add({staticLabel:"Omit:"} );
                              changeOpiEPS = checkboxControls.add({staticLabel:"EPS", checkedState:peuINFO.epsON} );
                              changeOpiPDF = checkboxControls.add({staticLabel:"PDF", checkedState:peuINFO.pdfON} );
                              changeOpiBitmap = checkboxControls.add({staticLabel:"Bitmapped", checkedState:peuINFO.bitmapON} );
              // Right column
                  with(borderPanels.add() ){
                      with(dialogColumns.add() ){
                              staticTexts.add({staticLabel:"PostScript level:"} );
                              var changePSlevel = dropdowns.add({stringList:["2","3"] , minWidth:75, selectedIndex:peuINFO.psLevel} );
                              staticTexts.add({staticLabel:"Color mode:"} );
                                  var changeColorMode = dropdowns.add({stringList:["Unchanged","Grayscale", "RGB", "CMYK"] , minWidth:100, selectedIndex:peuINFO.colorType } );
                              else
                                  var changeColorMode = dropdowns.add({stringList:["Unchanged","Grayscale", "RGB", "CMYK","PostScript Color Management"] , minWidth:100, selectedIndex:peuINFO.colorType } );
                              staticTexts.add({staticLabel:"Font embedding:"} );
                              var changeFontEmbedding = dropdowns.add({stringList:["None","Complete", "Subset"] , minWidth:100, selectedIndex:peuINFO.fontEmbed } );
                              staticTexts.add({staticLabel:"Type of data to send:"} );
                              var changeDataToSend = dropdowns.add({stringList:["All","Proxy"] , minWidth:50, selectedIndex:peuINFO.dataSent } );
                              staticTexts.add({staticLabel:"Data type:"} );
                              var changeDataType = dropdowns.add({stringList:["Binary","ASCII"] , minWidth:50, selectedIndex:peuINFO.dataType } );
                              staticTexts.add({staticLabel:"Perform OPI replacement:"} );
                              var changeOPIreplace = dropdowns.add({stringList:["No","Yes"] , minWidth:50, selectedIndex:peuINFO.opiReplacement} );
          do{
              var getOut = true;
              if((epsDialog.show()) ){
                  // Use these to update the prefs file
                  peuINFO.defaultFlattenerPreset = changeFlattenerPreset.selectedIndex;
                  peuINFO.ignoreON = (changeIgnoreOverride.checkedState)?1:0;
                  peuINFO.defaultPreview = changePreviewPreset.selectedIndex;
                  peuINFO.bleed = changeBleedVal.editContents;
                  peuINFO.epsON = (changeOpiEPS.checkedState)?1:0;
                  peuINFO.pdfON = (changeOpiPDF.checkedState)?1:0;
                  peuINFO.bitmapON = (changeOpiBitmap.checkedState)?1:0;
                  peuINFO.psLevel = changePSlevel.selectedIndex;
                  peuINFO.colorType = changeColorMode.selectedIndex;
                  peuINFO.fontEmbed = changeFontEmbedding.selectedIndex;
                  peuINFO.dataSent = changeDataToSend.selectedIndex;
                  peuINFO.dataType = changeDataType.selectedIndex;
                  peuINFO.opiReplacement = changeOPIreplace.selectedIndex;
                  // Check if bleed value is OK
                  peuINFO.bleed = parseFloat(peuINFO.bleed)
                  if (isNaN(peuINFO.bleed)){
                      alert("Bleed value must be a number (1.1).");
                      getOut = false;
                      peuINFO.bleed = oldBleed;
                  else if (peuINFO.bleed < 0){
                      alert("Bleed value must be greater or equal to zero (1.2).");
                      getOut = false;
                  else {
                      // Check if bleed is too big
                      try {
                          app.epsExportPreferences.bleedBottom = "" + peuINFO.bleed + peuINFO.measureUnitArray[peuINFO.measurementUnits];
                      catch (Exception){
                          alert("The bleed value must be less than one of the following: 6 in | 152.4 mm | 432 pt | 33c9.384");
                          getOut = false;
              else{
                  epsDialog.destroy();
                  byeBye("EPS Export canceled by user.", peuINFO.sayCancel);
          }while(!getOut);
              // These are used for exporting
              epsOptions["defaultFlattenerPreset"] = changeFlattenerPreset.selectedIndex;
              epsOptions["ignoreON"] = peuINFO.ignoreON;
              epsOptions["defaultPreview"] = changePreviewPreset.selectedIndex;
              epsOptions["bleed"] = peuINFO.bleed;
              epsOptions["epsON"] = peuINFO.epsON;
              epsOptions["pdfON"] = peuINFO.pdfON;
              epsOptions["bitmapON"] = peuINFO.bitmapON;
              epsOptions["psLevel"] = changePSlevel.selectedIndex;
              epsOptions["colorType"] = changeColorMode.selectedIndex;
              epsOptions["fontEmbed"] = changeFontEmbedding.selectedIndex;
              epsOptions["dataSent"] = changeDataToSend.selectedIndex;
              epsOptions["dataType"] = changeDataType.selectedIndex;
              epsOptions["opiReplacement"] = changeOPIreplace.selectedIndex;
              return epsOptions;
       *     Apply chosen settings to the EPS export prefs
      function setEPSoptions(theINFO){
          with(app.epsExportPreferences){
              appliedFlattererPreset = peuINFO.flattenerNames[theINFO.defaultFlattenerPreset];
              bleedBottom = "" + theINFO.bleed + peuINFO.measureUnitArray[peuINFO.measurementUnits];
              bleedInside = bleedBottom;
              bleedOutside = bleedBottom;
              bleedTop = bleedBottom;
              epsSpreads = currentINFO.doSpreadsON;
              ignoreSpreadOverrides = theINFO.ignoreON;
              switch (theINFO.dataType){
                  case 0:
                      dataFormat = DataFormat.binary;
                      break;
                  case 1:
                      dataFormat = DataFormat.ascii;
                      break;
              switch (theINFO.colorType){
                  case 0:
                      epsColor = EPSColorSpace.unchangedColorSpace;
                      break;
                  case 1:
                      epsColor = EPSColorSpace.gray;
                      break;
                  case 2:
                      epsColor = EPSColorSpace.rgb;
                      break;
                  case 3:
                      epsColor = EPSColorSpace.cmyk;
                      break;
                  case 4:
                      epsColor = EPSColorSpace.postscriptColorManagement;
                      break;
              switch (theINFO.fontEmbed){
                  case 0:
                      fontEmbedding = FontEmbedding.none;
                      break;
                  case 1:
                      fontEmbedding = FontEmbedding.complete;
                      break;
                  case 2:
                      fontEmbedding = FontEmbedding.subset;
                      break;
              switch (theINFO.dataSent){
                  case 0:
                      imageData = EPSImageData.allImageData;
                      break;
                  case 1:
                      imageData = EPSImageData.proxyImageData;
                      break;
              switch (theINFO.defaultPreview){
                  case 0:
                      preview = PreviewTypes.none;
                      break;
                  case 1:
                      preview = PreviewTypes.tiffPreview;
                      break;
                  case 2:
                      preview = PreviewTypes.pictPreview;
                      break;
              switch (theINFO.psLevel){
                  case 0:
                      postScriptLevel = PostScriptLevels.level2;
                      break;
                  case 1:
                      postScriptLevel = PostScriptLevels.level3;
                      break;
              // Setting these three to false prevents a conflict error when trying to set the opiImageReplacement value
              omitBitmaps = false;
              omitEPS = false;
              omitPDF = false;
              if (theINFO.opiReplacement){
                  opiImageReplacement = true;
              else {
                  opiImageReplacement = false;
                  omitBitmaps = theINFO.bitmapON;
                  omitEPS = theINFO.epsON;
                  omitPDF = theINFO.pdfON;
       * Build the main dialog box
      function createMainDialog (docName, thisNum, endNum){
          var theDialog = app.dialogs.add({name:(VERSION_NAME + ": Enter the options for \"" + docName + "\"" + ((endNum==1)?"":" (" + thisNum + " of " + endNum + " documents)") )
          with (theDialog){
              // Left Column
                      staticTexts.add({staticLabel:"Page Naming Options"} );
                          // Radio butons for renaming convention
                          namingConvention = radiobuttonGroups.add();
                          with(namingConvention){
                              radiobuttonControls.add({staticLabel:"As Is", checkedState:(peuINFO.nameConvType == 0)} );
                              radiobuttonControls.add({staticLabel:"Add \".L\"", checkedState:(peuINFO.nameConvType == 1)} );
                              radiobuttonControls.add({staticLabel:"Odd/Even = \".F/.B\"", checkedState:(peuINFO.nameConvType == 2)} );
                              radiobuttonControls.add({staticLabel:"Odd/Even = \"LA.F/LA.B\"" , checkedState:(peuINFO.nameConvType == 3)});
                              radiobuttonControls.add({staticLabel:"Numeric Override" , checkedState:(peuINFO.nameConvType == 4)});
                          staticTexts.add({staticLabel:""} );
                          staticTexts.add({staticLabel:"Base Name"} );
                          newBaseName = textEditboxes.add({editContents:baseName, minWidth:100} );
              // Middle Column
                      staticTexts.add({staticLabel:"Page Export Options"} );
                  with (borderPanels.add() ){
                              // Start and end pages text entry box
                              staticTexts.add({staticLabel:"Start[-End] Page"} );
                              startEndPgs = textEditboxes.add({editContents:peuINFO.editStartEndPgs, minWidth:103} );
                              doSpreads = checkboxControls.add({staticLabel:"As Spreads", checkedState:peuINFO.doSpreadsON} );
                              oneFile = checkboxControls.add({staticLabel:"Send Entire File At Once (PS+PDF only)", checkedState:peuINFO.doOneFile});
                      staticTexts.add({staticLabel:"Output Directory"} );
                      outputDirs = dropdowns.add({stringList:peuINFO.outDirNameArray , minWidth:204, selectedIndex:peuINFO.defaultDir} );
              // Right Column 1
                      staticTexts.add({staticLabel:"Output Format"} );
                              formatTypeRB = radiobuttonGroups.add();
                          with(formatTypeRB){
                              // If there are no print presets, don't add radio button for it
                              if(peuINFO.adjustForNoPS == 0)
                                  radiobuttonControls.add({staticLabel:"PostScript", checkedState:(peuINFO.exportDefaultType ==0)} );
                              radiobuttonControls.add({staticLabel:"PDF", checkedState:((peuINFO.exportDefaultType==1)||(peuINFO.adjustForNoPS==1 && peuINFO.exportDefaultType==0))} );
                              radiobuttonControls.add({staticLabel:"EPS", checkedState:(peuINFO.exportDefaultType==2)} );
                              radiobuttonControls.add({staticLabel:"JPEG", checkedState:(peuINFO.exportDefaultType==3), minWidth:140} );
                              if(pseudoSingleton < 1)
                                  radiobuttonControls.add({staticLabel:"Change Preferences", checkedState:false} );
                  if(pseudoSingleton < 2){
                      pseudoSingleton++;
                          staticTexts.add({staticLabel:"Advanced Export Options"} );
                                  doLayers = checkboxControls.add({staticLabel:"Layer Versioning", checkedState:peuINFO.layersON, minWidth:140});
                                          doBatch = checkboxControls.add({staticLabel:"Batch Export Enabled", checkedState:peuINFO.batchON, minWidth:130});
                                              commonBatch = checkboxControls.add({staticLabel:"Set For All Batch Jobs", checkedState:peuINFO.batchSameForAll, minWidth:140});
          return theDialog;
       * Test if doc width can support page info.
      function usePgInfoTag(theUnits, docWidth){
          var usePgInfo = true;
          switch (theUnits){
              case MeasurementUnits.points:
                  if(docWidth < 337.5)
                      usePgInfo = false;
              break;
              case MeasurementUnits.picas:
                  if(docWidth < 28.125)
                      usePgInfo = false;
              break;
              case MeasurementUnits.inches:
              case MeasurementUnits.inchesDecimal:
                  if(docWidth < 4.6875)
                      usePgInfo = false;
              break;
              case MeasurementUnits.millimeters:
                  if(docWidth < 119.0625)
                      usePgInfo = false;
              break;
              case MeasurementUnits.centimeters:
                  if(docWidth < 11.90625 )
                      usePgInfo = false;
              break;
              case MeasurementUnits.ciceros:
                  if(docWidth < 26.3922)
                      usePgInfo = false;
              break;
          return usePgInfo;
       * Optionally display alert and get out of Dodge
      function byeBye(msg,doTell){
              app.setProgress(999999);
              app.userInteractionLevel = peuINFO.oldInteractionPref;
          else
              app.scriptPreferences.userInteractionLevel = peuINFO.oldInteractionPref;
          if(doTell)
              alert(msg);
          exit();
       * Let user select a directory
      function getDirectory(showText, startingDirectory){
          return Folder.selectDialog(showText, startingDirectory);
       * The Layer Manager
      function layerManager(theDoc){
          var theLayers = theDoc.layers;
          var baseControls = new Array();
          var verControls = new Array();
          var lmi,getOut,numVerChosen;
          if (theLayers.length < 2){
            alert("Versioning Error:\nYou need at least two layers for versioning support.\nVersioning is turned off for \"" + theDoc.name + "\".");
            return null;
          do{
              getOut = true;
              var layerDialog = app.dialogs.add({name:"Version Manager for \"" + theDoc.name + "\"", canCancel:true} );
              with (layerDialog){
                          staticTexts.add({staticLabel:"Select Base Layer(s)     "} );
                              for(lmi = 0; lmi<theLayers.length;lmi++){
                                  baseControls[lmi] = checkboxControls.add({staticLabel:theLayers[lmi].name, checkedState:false, minWidth:104});
                              baseControls[lmi-1].checkedState = true;
                          staticTexts.add({staticLabel:"Select Version Layer(s)"} );
                                  verControls[lmi] = checkboxControls.add({staticLabel:theLayers[lmi].name, checkedState:true, minWidth:104});
                              verControls[lmi-1].checkedState = false;
              if(layerDialog.show() ){
                  numVerChosen = 0;
                  for(lmi=0; lmi< baseControls.length; lmi++){
                      if(baseControls[lmi].checkedState == true && verControls[lmi].checkedState == true){
                          alert("A layer cannot be both a base and version layer.\nPlease try again.");
                          getOut = false;
                          break;
                      if(verControls[lmi].checkedState == true){
                          numVerChosen++;
                          verControls[lmi] = true;
                      else
                          verControls[lmi] = false;
                      // Turn all layers off except base layers
                      theLayers[lmi].visible = baseControls[lmi].checkedState;
                      baseControls[lmi] = baseControls[lmi].checkedState;
                  if(numVerChosen == 0 && getOut){
                      alert("At least one version layer needs to be chosen.\nPlease try again.");
                      getOut = false;
              else{ // user canceled
                layerDialog.destroy();
                  byeBye("Exporting was canceled by user.",peuINFO.sayCancel);
          } while(!getOut);
          var theControls = new Array();
          theControls["baseControls"] = baseControls;
          theControls["verControls"] = verControls;
          return theControls;
       * Check Pages for Validity
      function checkPages(tempENTRY, startEndPgs){
          // Set Start and End Pages
          var pgsNoGood = false;
          var spreadsNoGood = false;
          var notNumber = false;
          var allSpreads = tempENTRY.theDoc.spreads;
          var spreadCount = allSpreads.length;
          if (startEndPgs == "All"){
              if (tempENTRY.doSpreadsON){
                  tempENTRY.pgStart = 1;
                  tempENTRY.pgEnd = spreadCount;
              else if (tempENTRY.nameConvType == 4){
                  tempENTRY.pgEnd = tempENTRY.theDoc.documentPreferences.pagesPerDocument;
              else {
                  tempENTRY.pgStart = tempENTRY.pageRangeArray[0];
                  tempENTRY.pgEnd = tempENTRY.pageRangeArray[tempENTRY.pageRangeArray.length-1];
              // Tally pages for the progress bar
              tempPageCount = (tempENTRY.doSpreadsON)?spreadCount:tempENTRY.theDoc.documentPreferences.pagesPerDocument;
          else if (startEndPgs.indexOf("-") != -1 && startEndPgs.indexOf(",") == -1){
              // Page range contains a "-" but not a "," (ie 11-15)
              var temp = startEndPgs.split("-");
              tempENTRY.pgStart = temp[0];
              tempENTRY.pgEnd = temp[1];
              // Test if any contiguous pages are out of range or not valid page names...
                  if (isNaN(tempENTRY.pgStart) || isNaN(tempENTRY.pgEnd) )
                      notNumber = true;
                  else if (tempENTRY.pgStart > spreadCount || tempENTRY.pgEnd > spreadCount || tempENTRY.pgStart < 0 || tempENTRY.pgEnd < 0 )
                      spreadsNoGood = true;
                  tempPageCount = tempENTRY.pgEnd - tempENTRY.pgStart +1;
              else if (tempENTRY.nameConvType != 4 && (getPageOffset(tempENTRY.pgStart,tempENTRY.pageNameArray,tempENTRY.pageRangeArray) == -1 || getPageOffset(tempENTRY.pgEnd,tempENTRY.pageNameArray,tempENTRY.pageRangeArray) == -1) )
                  pgsNoGood = true;
              else if (tempENTRY.nameConvType == 4 && (tempENTRY.pgStart < 1 || tempENTRY.pgEnd < 1 || tempENTRY.pgStart > tempENTRY.tempENTRY.pageRangeArray.length || tempENTRY.pgEnd > tempENTRY.tempENTRY.pageRangeArray.length) )
                  pgsNoGood = true;
              else// Range OK, find out num of pages
                  tempPageCount = getPageOffset(tempENTRY.pgEnd,tempENTRY.pageNameArray,tempENTRY.pageRangeArray) - getPageOffset(tempENTRY.pgStart,tempENTRY.pageNameArray,tempENTRY.pageRangeArray) + 1;
          else if (startEndPgs.indexOf(",") > -1){
              // Page range contains a comma. Deal with any "-" at print time (ie 1-3,4,7-11)
              tempENTRY.nonContigPgs = startEndPgs.split(",");
              tempENTRY.hasNonContig = true;
              // Check page range(s) for anything funky
              // and eventually issue error message if not compliant
              for(i = 0; i < tempENTRY.nonContigPgs.length; i++){
                  var temp = tempENTRY.nonContigPgs[i];
                      // Test if start or end page is not in the document
                      var temp2 = temp.split("-");
                      var temp3 = temp2[0];
                      var temp4 = temp2[1];
                          temp3 = parseInt(temp3,10);
                          temp4 = parseInt(temp4,10);
                          if (isNaN(temp3) || isNaN(temp4) )
                              notNumber = true;
                          else    if (temp3 > spreadCount || temp3 < 1 || temp4 > spreadCount || temp4 < 1)
                          tempPageCount += temp4 - temp3;
                      else if (tempENTRY.nameConvType == 4 && (temp3 < 1 || temp4 < 1 || temp3 > tempENTRY.pageRangeArray.length || temp4 > tempENTRY.pageRangeArray.length) )
                          pgsNoGood = true;
                      else if (tempENTRY.nameConvType != 4 && getPageOffset(temp3,tempENTRY.pageNameArray,tempENTRY.pageRangeArray) == -1 || getPageOffset(temp4,tempENTRY.pageNameArray,tempENTRY.pageRangeArray) == -1)
                          pgsNoGood = true;
                      else// Range OK, find out num of pages for prog bar
                          tempPageCount += getPageOffset(temp4,tempENTRY.pageNameArray,tempENTRY.pageRangeArray) - getPageOffset(temp3,tempENTRY.pageNameArray,tempENTRY.pageRangeArray);
                  // Test if a single page (was between a ",") is out of range or isn't a number
                  else if (tempENTRY.doSpreadsON && isNaN(parseInt(temp,10) ) )
                      notNumber = true;
                  else if ((tempENTRY.doSpreadsON && parseInt(temp,10) > spreadCount) || (tempENTRY.doSpreadsON && parseInt(temp,10) < 0) )
                  else if (tempENTRY.nameConvType == 4 && (parseInt(temp,10) < 1 || parseInt(temp,10) > tempENTRY.pageRangeArray.length ) )
                      pgsNoGood = true;
                  else if (tempENTRY.nameConvType != 4 && getPageOffset(temp,tempENTRY.pageNameArray,tempENTRY.pageRangeArray) == -1)
                      pgsNoGood = true;
                  tempPageCount++; // Add either a single page between commas or add the extra from "tempPageCount += (temp4 - temp3)" above
          else{ // Page range is single page (ie 5)
              tempENTRY.pgStart = startEndPgs;
              tempENTRY.pgEnd = startEndPgs;
                  if (isNaN(tempENTRY.pgStart) )
                      notNumber = true;
                  else if (tempENTRY.pgStart > spreadCount || tempENTRY.pgStart < 0)
              else if (tempENTRY.nameConvType != 4 && getPageOffset(tempENTRY.pgStart,tempENTRY.pageNameArray,tempENTRY.pageRangeArray) == -1)
                  pgsNoGood = true;
              else if (tempENTRY.nameConvType == 4 && (tempENTRY.pgStart < 1 || tempENTRY.pgStart > tempENTRY.tempENTRY.pageRangeArray.length) )
                  pgsNoGood = true;
                  tempPageCount = 1;
          // Check if any problems exist, alert user and reset value as needed
          if (spreadsNoGood||notNumber||pgsNoGood){
              peuINFO.editStartEndPgs = "All";
              tempPageCount = 0; // Ranges are no good, don't add yet
              if (spreadsNoGood)
                  alert("You have entered an invalid spread range!\nSpreads must be greater than zero and less than\nor equal to the number of spreads in the document (2.1).");
              else if (notNumber)
                  alert("You have entered a non-numeric spread number. Please use numerals and try again (2.2).");
              else if (pgsNoGood)
                  alert("You have entered a page name that doesn't exist in this document.\nBe sure to include section names if they are being used.\nPlease check your entered page name(s) and try again (2.3).");
          return [tempENTRY, tempPageCount];
      /* Initialization and preference functions */
       * Initiallization routine
      function peuInit(){
          // Default Preferences, init peuINFO "dictionary"
          peuINFO["outDirNameArray"] = ["Specific Directory"];
          peuINFO["dirListArray"] = ["Specific Directory"]
          peuINFO["startingDirectory"] = "/c/";
          peuINFO["defaultDir"] = 0;
          peuINFO["addZeroON"] = 1;
          peuINFO["addPon"] = 1;
          peuINFO["pageNamePlacement"] = 0;
          peuINFO["doSpreadsON"] = 0;
          peuINFO["seperatorChar"] = 0;
          peuINFO["specialReplaceChar"] = 1;
          peuINFO["doOneFile"] = 0;
          peuINFO["exportDefaultType"] = 0;
          peuINFO["defaultPrintPreset"] = 0;
          peuINFO["measurementUnits"] = 0;
          peuINFO["addPSextention"] = 1;
          peuINFO["defaultJPEGquality"] = 0;
          peuINFO["defaultJPEGrender"] = 0;
          peuINFO["sayCancel"] = 1;
          peuINFO["subType"] = 1;
          peuINFO["layersON"]  = 0;
          peuINFO["layerBeforeON"] = 0;
          peuINFO["batchON"] = 0;
          peuINFO["origSpread"] = false;
          peuINFO["nameConvType"] = 0;
          peuINFO["defaultPDFpreset"] = 0;
          peuINFO["baseLaersAsVersion"] = 0;
          peuINFO["batchSameForAll"] = 0;
          peuINFO["zeroPadding"] = 0;
          // EPS options
          peuINFO["ignoreON"] = 1;
          peuINFO["bleed"]= 0.125;
          peuINFO["epsON"] = 0;
          peuINFO["pdfON"] = 0;
          peuINFO["bitmapON"] = 0;
          peuINFO["psLevel"] = 1;
          peuINFO["colorType"] = 3;
          peuINFO["fontEmbed"] = 1;
          peuINFO["dataSent"] = 0;
          peuINFO["dataType"] = 1;
          peuINFO["opiReplacement"] = 0;
          peuINFO["defaultPreview"] = 1;
          peuINFO["defaultFlattenerPreset"] = 0;
          peuINFO["previewTypes"] = new Array();
          peuINFO.previewTypes[0] = "None";
          peuINFO.previewTypes[1] = "Tiff";
          // Only add pict if we are on a Mac
          if (File.fs != "Windows")
              peuINFO.previewTypes[2] = "Pict";
          // Check if preferences file exists, if not save one
          peuINFO["prefsFile"] = File((Folder(app.activeScript)).parent + "/PageExporter5Prefs.txt");
          if(!peuINFO.prefsFile.exists)
              savePrefs();
          else
              readPrefs();
          peuINFO["csFlattenerPresets"] = app.flattenerPresets;
          peuINFO["flattenerNames"] = new Array();
          for (i = 0; i < peuINFO.csFlattenerPresets.length; i ++)
              peuINFO.flattenerNames.push(peuINFO.csFlattenerPresets[i].name);
          // Check if the default flattener preset is beyond the actual number of presets.
          // This can occur if the default was the last in the list and was deleted
          if(peuINFO.defaultFlattenerPreset > peuINFO.flattenerNames.length-1)
                  peuINFO.defaultFlattenerPreset = 0;
          // Test for 'ActivePageItemRunTime' plugin for progress bar:
          try{
              app.documents[0].labeledPageItems;
              peuINFO["doProgressBar"] = true;
          catch(e){
              peuINFO["doProgressBar"] = false;
          // Various Globals
          peuINFO["editStartEndPgs"] = "All";
          peuINFO["charList"] = [".","_"," ",""];
          peuINFO["measureUnitArray"] = [" in"," cm"," mm"," pt"," p"," c"];
          peuINFO["measureLableArray"] = ["inches","centimeters","millimeters","points","picas","ciceros"];
          // Load and determine which print presets are "PostScript File" for the printer
          // Need to do this before building main dialog to check for PSfile "printers"
          var csPrintPresets = app.printerPresets;
          peuINFO["csPSprinters"] = new Array();
          peuINFO["psPrinterNames"] = new Array();
          for(i = 0; i < csPrintPresets.length; i ++)
              if(csPrintPresets[i].printer == Printer.postscriptFile){
                  peuINFO.psPrinterNames.push(csPrintPresets[i].name);
                  peuINFO.csPSprinters.push(csPrintPresets[i]);
          // If a print preset was deleted and the default was last in the list,
          // problems resulted. This fixes that
          if(peuINFO.defaultPrintPreset > peuINFO.psPrinterNames.length-1)
              peuINFO.defaultPrintPreset = 0;
          peuINFO["adjustForNoPS"] = (peuINFO.psPrinterNames.length == 0)? 1:0; // Adjusts array offset if there are no PSfile printers
          return peuINFO;
       * Read the preferences from a text file
      function readPrefs(){
          peuINFO.prefsFile.open("r");
          peuINFO.outDirNameArray = (peuINFO.prefsFile.readln() ).split(",");
          peuINFO.dirListArray = (peuINFO.prefsFile.readln() ).split(",");
          peuINFO.startingDirectory = peuINFO.prefsFile.readln();
          peuINFO.defaultDir = Number(peuINFO.prefsFile.readln() );
          peuINFO.addZeroON = Number(peuINFO.prefsFile.readln() );
          peuINFO.addPon = Number(peuINFO.prefsFile.readln() );
          peuINFO.pageNamePlacement = Number(peuINFO.prefsFile.readln() );
          peuINFO.doSpreadsON = Number(peuINFO.prefsFile.readln() );
          peuINFO.seperatorChar = Number(peuINFO.prefsFile.readln() );
          peuINFO.specialReplaceChar = Number(peuINFO.prefsFile.readln() );
          peuINFO.doOneFile = Number(peuINFO.prefsFile.readln() );
          peuINFO.exportDefaultType = Number((peuINFO.prefsFile.readln() ));
          peuINFO.defaultPrintPreset = Number(peuINFO.prefsFile.readln() );
          peuINFO.measurementUnits = Number(peuINFO.prefsFile.readln() );
          peuINFO.addPSextention = Number(peuINFO.prefsFile.readln() );
          peuINFO.defaultJPEGquality = Number(peuINFO.prefsFile.readln() );
          peuINFO.defaultJPEGrender = Number(peuINFO.prefsFile.readln() );
          peuINFO.sayCancel = Number(peuINFO.prefsFile.readln() );
          peuINFO.subType = Number(peuINFO.prefsFile.readln() );
          peuINFO.layersON = Number(peuINFO.prefsFile.readln() );
          peuINFO.layerBeforeON = Number(peuINFO.prefsFile.readln() );
          peuINFO.batchON = Number(peuINFO.prefsFile.readln() );
          peuINFO.ignoreON = Number(peuINFO.prefsFile.readln() );
          peuINFO.bleed = Number(peuINFO.prefsFile.readln() );
          peuINFO.epsON = Number(peuINFO.prefsFile.readln() );
          peuINFO.pdfON = Number(peuINFO.prefsFile.readln() );
          peuINFO.bitmapON = Number(peuINFO.prefsFile.readln() );
          peuINFO.psLevel = Number(peuINFO.prefsFile.readln() );
          peuINFO.colorType = Number(peuINFO.prefsFile.readln() );
          peuINFO.fontEmbed = Number(peuINFO.prefsFile.readln() );
          peuINFO.dataSent = Number(peuINFO.prefsFile.readln() );
          peuINFO.dataType = Number(peuINFO.prefsFile.readln() );
          peuINFO.opiReplacement = Number(peuINFO.prefsFile.readln() );
          peuINFO.defaultPreview = Number(peuINFO.prefsFile.readln() );
          peuINFO.defaultFlattenerPreset = Number(peuINFO.prefsFile.readln() );
          peuINFO.defaultPDFpreset =  Number(peuINFO.prefsFile.readln() );
          peuINFO.baseLaersAsVersion = Number(peuINFO.prefsFile.readln() );
          peuINFO.batchSameForAll = Number(peuINFO.prefsFile.readln() );
          peuINFO.zeroPadding = Number(peuINFO.prefsFile.readln() );
          peuINFO.prefsFile.close();
       * Save the preferences to a text file
      function savePrefs(){
          var newPrefs =
          peuINFO.outDirNameArray + "\n" +
          peuINFO.dirListArray + "\n" +
          peuINFO.startingDirectory  + "\n" +
          peuINFO.defaultDir + "\n" +
          peuINFO.addZeroON + "\n" +
          peuINFO.addPon + "\n" +
          peuINFO.pageNamePlacement + "\n" +
          peuINFO.doSpreadsON + "\n" +
          peuINFO.seperatorChar + "\n" +
          peuINFO.specialReplaceChar + "\n" +
          peuINFO.doOneFile + "\n" +
          peuINFO.exportDefaultType + "\n" +
          peuINFO.defaultPrintPreset + "\n" +
          peuINFO.measurementUnits + "\n" +
          peuINFO.addPSextention + "\n" +
          peuINFO.defaultJPEGquality + "\n" +
          peuINFO.defaultJPEGrender + "\n" +
          peuINFO.sayCancel + "\n" +
          peuINFO.subType + "\n" +
          peuINFO.layersON + "\n" +
          peuINFO.layerBeforeON + "\n" +
          peuINFO.batchON + "\n" +
          peuINFO.ignoreON + "\n" +
          peuINFO.bleed + "\n" +
          peuINFO.epsON + "\n" +
          peuINFO.pdfON + "\n" +
          peuINFO.bitmapON + "\n" +
          peuINFO.psLevel + "\n" +
          peuINFO.colorType + "\n" +
          peuINFO.fontEmbed + "\n" +
          peuINFO.dataSent + "\n" +
          peuINFO.dataType + "\n" +
          peuINFO.opiReplacement + "\n" +
          peuINFO.defaultPreview + "\n" +
          peuINFO.defaultFlattenerPreset + "\n" +
          peuINFO.defaultPDFpreset + "\n" +
          peuINFO.baseLaersAsVersion + "\n" +
          peuINFO.batchSameForAll + "\n" +
          peuINFO.zeroPadding + "\n" +
          "0\n0\n0\n0\n0\n0\n0\n0\n0\n0\n";// Add (10) for extra prefs in future
          peuINFO.prefsFile.open("w");
          peuINFO.prefsFile.write(newPrefs);
       * Change Preferences
      function changePrefs(){
          var popChoice = 0;
          var prefItems = makePrefsDlog();
          if(prefItems.otherPrefsDlog.show()){
              // Add a default directories
              if(prefItems.addDefDir.checkedState)
                  addDirectories();
              // Delete directories
              if(prefItems.delDefDir.checkedState)
                  deleteDirectories();
              // Change Start Directory
              if(prefItems.changeStartDirectory.checkedState){
                  tempStartDirectory = getDirectory("Please select the new start directory:",peuINFO.startingDirectory);
                  if(tempStartDirectory != null)
                      peuINFO.startingDirectory = tempStartDirectory;
              // The other prefs = the index of popups selected
              peuINFO.seperatorChar = prefItems.changeSepToken.selectedIndex;
              peuINFO.specialReplaceChar = prefItems.changeRepToken.selectedIndex;
              peuINFO.measurementUnits = prefItems.changeUnits.selectedIndex;
              peuINFO.addZeroON = prefItems.changeAddZero.selectedIndex;
              peuINFO.addPon = prefItems.changeAddP.selectedIndex;
              peuINFO.pageNamePlacement = prefItems.changeBeforeON.selectedIndex;
              peuINFO.layerBeforeON = prefItems.changeLayerON.selectedIndex;
              peuINFO.sayCancel = prefItems.changeShowCancel.selectedIndex;
              peuINFO.subType = prefItems.changeSubType.selectedIndex;
              peuINFO.baseLaersAsVersion = (prefItems.changeBaseExport.checkedState)?1:0;
              peuINFO.zeroPadding = prefItems.changePadding.selectedIndex;
              prefItems.otherPrefsDlog.destroy();
              savePrefs()
       * Change Preferences Helper: Build Prefs Dialog Box
      function makePrefsDlog(){
          var prefsItems = new Array();
          prefsItems["otherPrefsDlog"] = app.dialogs.add({name:"Change Preferences", canCancel:true} );
          with (prefsItems.otherPrefsDlog){
              // Left column
                      staticTexts.add({staticLabel:"User Defined Preferences"} );
                              prefsItems["addDefDir"] = checkboxControls.add({staticLabel:"Add an Output Directory", checkedState:false});
                              prefsItems["delDefDir"] = checkboxControls.add({staticLabel:"Delete an Output Directory", checkedState:false});
                              prefsItems["changeStartDirectory"] = checkboxControls.add({staticLabel:"Change Starting Directory", checkedState:false});
                              staticTexts.add({staticLabel:"Separator Character"} );
                              prefsItems["changeSepToken"] = dropdowns.add({stringList:[".","_","<space>","nothing"], selectedIndex:peuINFO.seperatorChar});
                              staticTexts.add({staticLabel:"Replacement Character"} );
                              prefsItems["changeRepToken"] = dropdowns.add({stringList:[".","_","<space>","nothing"], selectedIndex:peuINFO.specialReplaceChar} );
                              staticTexts.add({staticLabel:"Measurement Units"} );
                              prefsItems["changeUnits"] = dropdowns.add({stringList:peuINFO.measureLableArray, selectedIndex:peuINFO.measurementUnits} );
                              staticTexts.add({staticLabel:"Add Leading Zero(s)"} );
                              prefsItems["changeAddZero"] = dropdowns.add({stringList:["No","Yes"], selectedIndex:peuINFO.addZeroON} );
                              staticTexts.add({staticLabel:"Force Page Numbers to"} );
                              prefsItems["changePadding"] = dropdowns.add({stringList:["Normal","2","3"], selectedIndex:peuINFO.zeroPadding} );
                              staticTexts.add({staticLabel:"Digits when Adding Leading Zeros"} );
                              staticTexts.add({staticLabel:"Add \"P\" to Numeric Pages"} );
                              prefsItems["changeAddP"] = dropdowns.add({stringList:["No","Yes"], selectedIndex:peuINFO.addPon} );
                              staticTexts.add({staticLabel:"Add Page Name"} );
                              prefsItems["changeBeforeON"] = dropdowns.add({stringList:["After","Before","by replacing \"<#>\" in"], selectedIndex:peuINFO.pageNamePlacement} );
                              staticTexts.add({staticLabel:"Add Layer Name"} );
                              prefsItems["changeLayerON"] = dropdowns.add({stringList:["After","Before"], selectedIndex:peuINFO.layerBeforeON} );
                              staticTexts.add({staticLabel:"Page Name"} );
                              staticTexts.add({staticLabel:"Alert on Cancel"} );
                              prefsItems["changeShowCancel"] = dropdowns.add({stringList:["No","Yes"], selectedIndex:peuINFO.sayCancel} );
                              staticTexts.add({staticLabel:"Lot Naming Type"} );
                              prefsItems["changeSubType"] = dropdowns.add({stringList:["Consecutive","Redundant"], selectedIndex:peuINFO.subType} );
                              prefsItems["changeBaseExport"] = checkboxControls.add({staticLabel:"Export Base Layer(s) as an Individual Version", checkedState:peuINFO.baseLaersAsVersion, minWidth:140});
          return prefsItems;
       * Change Preferences Helper: Add one or more output directories
      function addDirectories(){
          var prefGetOut1 = true;
          do{
              tempDir = getDirectory("Select a new directory to add:",peuINFO.startingDirectory);
              if(tempDir != null){
                  peuINFO.dirListArray.push(tempDir + "/");
                  do{
                      var prefGetOut = true;
                      var tempDlog = app.dialogs.add({name:"Output Directory Name", canCancel:false} );
                      with (tempDlog)
                                  staticTexts.add({staticLabel:"Enter the name to use for this new directory:"} );
                                  var tempChange = textEditboxes.add({editContents:"newName", minWidth:170} );
                      if(tempDlog.show()){
                          tempChange = tempChange.editContents;
                          if(tempChange.length < 1){
                              prefGetOut = false;
                              alert("The name must have at least one character!");
                          else
                              peuINFO.outDirNameArray.push(tempChange);
                  } while(!prefGetOut);
              if(prefGetOut1){
                  tempDlog = app.dialogs.add({name:"", canCancel:true} );
                  with (tempDlog)
                              staticTexts.add({staticLabel:"Do you want to add another default directory? (OK=yes, Cancel=no)"} );
                  prefGetOut1 = tempDlog.show();
          } while(prefGetOut1);
          tempDlog.destroy();
       * Change Preferences Helper: Delete directories from the output directories list
      function deleteDirectories(){
          do{
              var menuArray = new Array();// Needed to rig the menu list. ID has weird bug that keeps deleted items in an array
              for(place = 0;place < peuINFO.outDirNameArray.length;place++)
                  menuArray[place] = peuINFO.outDirNameArray[place];
              var outDirNameArrayCnt = peuINFO.outDirNameArray.length;
              var tempDlog = app.dialogs.add({name:"Delete an Output Directory", canCancel:true} );
              with (tempDlog)
                          var killIt = dropdowns.add({stringList:menuArray, minWidth:204, selectedIndex: 0 } );
                  killIt = killIt.selectedIndex;
                  if(killIt == peuINFO.defaultDir)
                      peuINFO.defaultDir--;
                  if(killIt == 0)
                      alert("The \"Specific Directory\" entry can't be deleted.");
                  else{
                          peuINFO.outDirNameArray.splice(killIt,1);
                          peuINFO.dirListArray.splice(killIt, 1);
              tempDlog.destroy();
              with (tempDlog)
                          staticTexts.add({staticLabel:"Do you want to delete another default directory? (OK=yes, Cancel=no)"} );
              var prefGetOut = tempDlog.show();
          } while(prefGetOut);
