6 Replies Latest reply on Jun 6, 2010 8:34 AM by David_F57
    Flex Kaleidoscope
    Francisc Level 3
      Hello!
      Does anyone know of any Kaleidoscope components out there?
      I would like to play around with such a thing but don't know how to start.
      Thank you!
        • 1. Re: Flex Kaleidoscope
          PRAYMAYERD
          I'm sorry, I'm not sure. But I do want to mention the MASH thing is awesome.
          • 2. Re: Flex Kaleidoscope
            David_F57 Level 5
            hi,
            The answer is shaderjob, there are available kaeidedoscope/stereographic pixelbender filters that are available. I am busy at the moment but over the weekend I'll see if I can put something together
            http://www.adobe.com/cfusion/exchange/index.cfm?event=extensionDetail&loc=en_us&extid=1742 024
            http://www.adobe.com/cfusion/exchange/index.cfm?event=extensionDetail&loc=en_us&extid=1703 523
            David.
            • 3. Re: Flex Kaleidoscope
              Francisc Level 3
              Haha! Thank you, `PRAYMAYERD`.
              • 4. Re: Flex Kaleidoscope
                Francisc Level 3
                Thank you David. Much appreciated.
                • 5. Re: Flex Kaleidoscope
                  Francisc Level 3
                  David, the links you provided are exampls of doing that with Pixel Bender.
                  Is there no other way like using the native drawing API and BitmapData for example?
                  • 6. Re: Flex Kaleidoscope
                    David_F57 Level 5
                    hi,
                    You can use the drawing api but you still need to apply a formula to set the perspective to each view. Pixelbender filters work very well in flex, I've started to play a little with the filters I mentioned but having fun getting it right,below is the code so far, I might try the stereographic filter as this seems to be less savage with settings.
                    also these are a couple of links to where i've used pixelbender filters when 'playing'
                    http://gumbo.flashhub.net/menu/  - the crossfade is done with a pixelbender filter
                    http://gumbo.flashhub.net/reflect/ a filter that creates a dynamic reflection(pixel bender filter in a component)
                       xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600" creationComplete="application1_creationCompleteHandler(event)" skinClass="appskin">
                    <fx:Declarations>
                    <!-- Place non-visual elements (e.g., services, value objects) here -->
                    </fx:Declarations>
                    <fx:Script>
                    <![CDATA[
                    import mx.controls.Alert;
                    import mx.events.FlexEvent;
                    import spark.events.DropDownEvent;
                    [Embed(source="assets/Kaleidoscope.pbj", mimeType="application/octet-stream")] private var Kaleidoscope:Class;
                    [Bindable] [Embed(source="images/img1.jpg")] private var img:Class;
                    private var shader:Shader = new Shader(new Kaleidoscope());
                    [Bindable] private var job:ShaderJob;
                    [Bindable] private var angle: int = 4;
                    [Bindable] private var direction: Number=1;
                    [Bindable] private var basepoint: Number=1;
                    private var calcbase:Number=0.1;
                    protected function application1_creationCompleteHandler(event:FlexEvent):void
                    updateShader();
                    private function updateShader(): void
                    calcbase = holder.width*basepoint/10;
                    job = new ShaderJob(shader);
                    job.addEventListener(ShaderEvent.COMPLETE, shaderCompleteHandler);
                    ShaderInput(shader.data.src).input=(new img()).bitmapData;
                    ShaderParameter(shader.data.angle).value=[2*Math.PI/angle];
                    ShaderParameter(shader.data.direction).value=[direction/10];
                    ShaderParameter(shader.data.basepoint).value=[calcbase,calcbase];
                    var jobResult:BitmapData = new BitmapData(holder.width,holder.height);
                    job.target = jobResult;
                    job.start(false);
                    private function shaderCompleteHandler(shaderEvent:ShaderEvent):void
                    job.removeEventListener(ShaderEvent.COMPLETE,shaderCompleteHandler);
                    holder.source=new Bitmap(shaderEvent.bitmapData);
                    protected function slider_changeHandler(event:Event):void
                    updateShader();
                    </fx:Script>
                    <s:controlBarContent>
                    </s:controlBarContent>
                    <mx:Image id="src" x="89" y="145" width="200" height="200" source="{img}"/>
                    <s:HSlider x="860" y="145" minimum="1" maximum="42" stepSize="1" value="@{direction}" change="{slider_changeHandler(event)}"/>
                    <s:HSlider x="860" y="183" minimum="1" maximum="10" stepSize="1" value="@{basepoint}" change="{slider_changeHandler(event)}"/>
                    <s:HSlider x="860" y="232" minimum="3" maximum="12" stepSize="1" value="@{angle}" change="slider_changeHandler(event)"/>
                    <mx:Image id="holder" x="345" y="145" width="200" height="200"/>
                    </s:Application>
