0 Replies Latest reply on Jun 2, 2010 3:08 PM by PRAYMAYERD
    rotate3d behavior
    PRAYMAYERD Level 1
      I'll start by exclaiming I know I don't properly understand the 3d aspect of flex.
      In any case, I have 3 spark video players with fade, resize and rotate3d effects applied to them.
      The effects run wonderfully (for the most part) on the intended target... however, when the effects run on a target, the other video players also change position, sometimes dramatically.
      I realize somethings you will find have some silly logic.. but I've done some really major fundamental changes to the code to find whats reponsible.
      <s:Application
      xmlns:fx="http://ns.adobe.com/mxml/2009"
      xmlns:s="
      library://ns.adobe.com/flex/spark"
      xmlns:mx="
      library://ns.adobe.com/flex/mx"
      minWidth="
      955" minHeight="600" creationComplete="initActions();">
      <fx:Declarations>
      </fx:Declarations>
      <fx:Script>
      <![CDATA[
      import mx.events.FlexEvent;
      import spark.components.VideoDisplay;
      import spark.components.VideoPlayer;
      import spark.effects.Animate;
      import spark.effects.AnimateColor;
      import spark.effects.Fade;
      import spark.effects.Resize;
      import spark.effects.Rotate3D;
      private var roll3d_disp1:Rotate3D = new Rotate3D();
      private var roll3d_disp2:Rotate3D = new Rotate3D();
      private var roll3d_disp3:Rotate3D = new Rotate3D();
      private var resizeThis_disp1:Resize = new Resize();
      private var resizeThis_disp2:Resize = new Resize();
      private var resizeThis_disp3:Resize = new Resize();
      private var fadeThis_disp1:Fade = new Fade();
      private var fadeThis_disp2:Fade = new Fade();
      private var fadeThis_disp3:Fade = new Fade();
      //starting xyz rotation (rotate 3d) coords... set in initActions()
      private var startingX:Number = 0;
      private var startingY:Number = -30;
      private var startingZ:Number = 0;
      //finishing xyz rotation (rotate 3d) coords ... set in disp functions
      private var finishingX:Number = 0;
      private var finishingY:Number = 30;
      private var finishingZ:Number = 0;
      //starting width + height.. bound in the player tags..
      private var startingWi:Number = 300;
      private var startingHe:Number = 300;
      protected function initActions():void {
      // stuff for vid disp1
      disp1.rotationX = startingX;
      disp1.rotationY = startingY;
      disp1.rotationZ = startingZ;
      disp1.x = 100;
      disp1.y = 200;
      disp1.depth = 1;
      disp1.toolTip =
      'test 1';
      disp1.alpha = 0.80;
      disp1.source =
      'theDoctor.f4v';
      disp1.autoPlay =
      true;
      disp1.loop =
      true;
      disp2.rotationX = startingX;
      disp2.rotationY = startingY;
      disp2.rotationZ = startingZ;
      disp2.x = 400;
      disp2.y = 200;
      disp2.depth = 1;
      disp2.toolTip =
      'test 2';
      disp2.alpha = 0.80;
      disp2.source =
      'pcfusion_06_prod.f4v';
      disp2.autoPlay =
      true;
      disp2.loop =
      true;
      disp3.rotationX = startingX;
      disp3.rotationY = startingY;
      disp3.rotationZ = startingZ;
      disp3.x = 700;
      disp3.y = 200;
      disp3.depth = 1;
      disp3.toolTip =
      'test3';
      disp3.alpha = 0.80;
      disp3.source =
      'globe.f4v';
      disp3.autoPlay =
      true;
      disp3.loop =
      true;
      protected function disp1_rollOverHandler(event:MouseEvent):void
      disp1.depth = 2;
      resizeThis_disp1.target = event.currentTarget;
      resizeThis_disp1.widthFrom = startingWi;
      resizeThis_disp1.heightFrom = startingHe;
      resizeThis_disp1.widthTo = 640;
      resizeThis_disp1.heightTo = 400;
      resizeThis_disp1.duration = 400;
      resizeThis_disp1.startDelay = 250;
      fadeThis_disp1.target = event.currentTarget;
      fadeThis_disp1.alphaFrom = 0.80;
      fadeThis_disp1.alphaTo = 1.0;
      fadeThis_disp1.duration = 400;
      roll3d_disp1.target = event.currentTarget;
      roll3d_disp1.autoCenterProjection =
      true;
      roll3d_disp1.autoCenterTransform =
      true;
      roll3d_disp1.angleXFrom = startingX;
      roll3d_disp1.angleYFrom = startingY;
      roll3d_disp1.angleZFrom = startingZ;
      roll3d_disp1.angleXTo = finishingX;
      roll3d_disp1.angleYTo = finishingY;
      roll3d_disp1.angleZTo = finishingZ;
      roll3d_disp1.startDelay = 250;
      resizeThis_disp1.play();
      fadeThis_disp1.play();
      roll3d_disp1.play();
      protected function disp1_rollOutHandler(event:MouseEvent):void
      disp1.depth = 1;
      resizeThis_disp1.widthTo = startingWi;
      resizeThis_disp1.heightTo = startingHe;
      resizeThis_disp1.widthFrom = 500;
      resizeThis_disp1.heightFrom = 300;
      fadeThis_disp1.alphaTo = 0.80;
      fadeThis_disp1.alphaFrom = 1.0;
      roll3d_disp1.angleXTo = startingX;
      roll3d_disp1.angleYTo = startingY;
      roll3d_disp1.angleZTo = startingZ;
      roll3d_disp1.angleXFrom = finishingX;
      roll3d_disp1.angleYFrom = finishingY;
      roll3d_disp1.angleZFrom = finishingZ;
      protected function disp2_rollOverHandler(event:MouseEvent):void
      disp2.depth = 2;
      resizeThis_disp2.target = event.currentTarget;
      resizeThis_disp2.widthFrom = startingWi;
      resizeThis_disp2.heightFrom = startingHe;
      resizeThis_disp2.widthTo = 640;
      resizeThis_disp2.heightTo = 400;
      resizeThis_disp2.duration = 400;
      resizeThis_disp2.startDelay = 250;
      fadeThis_disp2.target = event.currentTarget;
      fadeThis_disp2.alphaFrom = 0.80;
      fadeThis_disp2.alphaTo = 1.0;
      fadeThis_disp2.duration = 400;
      roll3d_disp2.target = event.currentTarget;
      roll3d_disp2.autoCenterProjection =
      true;
      roll3d_disp2.autoCenterTransform =
      true;
      roll3d_disp2.angleXFrom = startingX;
      roll3d_disp2.angleYFrom = startingY;
      roll3d_disp2.angleZFrom = startingZ;
      roll3d_disp2.angleXTo = finishingX;
      roll3d_disp2.angleYTo = finishingY;
      roll3d_disp2.angleZTo = finishingZ;
      roll3d_disp2.startDelay = 250;
      resizeThis_disp2.play();
      fadeThis_disp2.play();
      roll3d_disp2.play();
      protected function disp2_rollOutHandler(event:MouseEvent):void
      disp2.depth = 1;
      resizeThis_disp2.widthTo = startingWi;
      resizeThis_disp2.heightTo = startingHe;
      resizeThis_disp2.widthFrom = 500;
      resizeThis_disp2.heightFrom = 300;
      fadeThis_disp2.alphaTo = 0.80;
      fadeThis_disp2.alphaFrom = 1.0;
      roll3d_disp2.angleXTo = startingX;
      roll3d_disp2.angleYTo = startingY;
      roll3d_disp2.angleZTo = startingZ;
      roll3d_disp2.angleXFrom = finishingX;
      roll3d_disp2.angleYFrom = finishingY;
      roll3d_disp2.angleZFrom = finishingZ;
      protected function disp3_rollOverHandler(event:MouseEvent):void
      disp3.depth = 2;
      resizeThis_disp3.target = event.currentTarget;
      resizeThis_disp3.widthFrom = startingWi;
      resizeThis_disp3.heightFrom = startingHe;
      resizeThis_disp3.widthTo = 640;
      resizeThis_disp3.heightTo = 400;
      resizeThis_disp3.duration = 400;
      resizeThis_disp3.startDelay = 250;
      fadeThis_disp3.target = event.currentTarget;
      fadeThis_disp3.alphaFrom = 0.80;
      fadeThis_disp3.alphaTo = 1.0;
      fadeThis_disp3.duration = 400;
      roll3d_disp3.target = event.currentTarget;
      roll3d_disp3.autoCenterProjection =
      true;
      roll3d_disp3.autoCenterTransform =
      true;
      roll3d_disp3.angleXFrom = startingX;
      roll3d_disp3.angleYFrom = startingY;
      roll3d_disp3.angleZFrom = startingZ;
      roll3d_disp3.angleXTo = finishingX;
      roll3d_disp3.angleYTo = finishingY;
      roll3d_disp3.angleZTo = finishingZ;
      roll3d_disp3.startDelay = 250;
      resizeThis_disp3.play();
      fadeThis_disp3.play();
      roll3d_disp3.play();
      // orig rollout
      protected function disp3_rollOutHandler(event:MouseEvent):void
      disp3.depth = 1;
      resizeThis_disp3.widthTo = startingWi;
      resizeThis_disp3.heightTo = startingHe;
      resizeThis_disp3.widthFrom = 500;
      resizeThis_disp3.heightFrom = 300;
      fadeThis_disp3.alphaTo = 0.80;
      fadeThis_disp3.alphaFrom = 1.0;
      roll3d_disp3.angleXTo = startingX;
      roll3d_disp3.angleYTo = startingY;
      roll3d_disp3.angleZTo = startingZ;
      roll3d_disp3.angleXFrom = finishingX;
      roll3d_disp3.angleYFrom = finishingY;
      roll3d_disp3.angleZFrom = finishingZ;
      </fx:Script>
      <s:VideoPlayer id="disp1"
      rollOver="
      disp1_rollOverHandler(event)"
      rollOut="
      disp1_rollOutHandler(event)"
      width="
      {startingWi}" height="{startingHe}" />
      <s:VideoPlayer id="disp2"
      rollOver="
      disp2_rollOverHandler(event)"
      rollOut="
      disp2_rollOutHandler(event)"
      width="
      <s:VideoPlayer id="disp3"
      rollOver="
      disp3_rollOverHandler(event)"
      rollOut="
      disp3_rollOutHandler(event)"
      width="
      </s:Application>
