3 Replies Latest reply on Jun 3, 2010 6:35 PM by davidmacy
    Export to EPS on Macbook Pro i7, CS4 and CS5, ULTRA SLOW
      Just curious if anyone has run into extremely sluggish behavior when running either CS4 or CS5 on a brand new i7 Macbook Pro.
      I have a brand new, 2.66 i7 Macbook Pro with 4 gigs of RAM and CS4 installed.  I had a 100 percent vector Illustrator file that was only 1.5 MB in size. I added a clipping mask and then "saved as" an EPS.  I then received a progress bar that stated "Writing Illustrator EPS Format".  It's been 20 minutes and the bar hasn't even reached a 1/4 completion. I then tried this same task on a different Macbook Pro i7, also brand new, also 2.66 i7, but with CS5 and 8 gigs of RAM.  It wasn't any faster.  Both machines are sitting with the bar barely moving.  I estimate this task would take 2-3 hours to export which is totally unacceptable.
      This problem is not unique to this file.  Every time I have tried to save as an Illustrator EPS file, the machine becomes so slow it is essentially unusable.
      How can the same thing be wrong on two brand new machines, with two different versions of Illustrator?
      Does anyone know what is wrong?
        • 1. Re: Export to EPS on Macbook Pro i7, CS4 and CS5, ULTRA SLOW
          Scott Falkner Level 5
          Illustrator cannot export to EPS. You can only save your file as EPS. The difference is not insignificant. To export a file one is generally leaving the current file open and creating a new file that is somehow less than the complete file. Illustrator files exported to TIFF, PSD, or JPEG are less than the full Illustrator file because they are no longer vectors and are far less editable than the full Illustrator file.
          An Illustrator EPS file is the data in your file saved in three formats: A fully editable Illustrator file, a PostScript file giving output instructions to a printer, and a low resolution preview for viewing when imported into other programs. While the Illustrator file may be only 1.5 MB, the instructions to produce the PostScript code for the printer might be complex due to blends, gradients or gradient meshes, pattern swatches, symbols, placed raster art, or effects. If the file is physically large, then the lo-resolution preview can get massive as well. A 6 foot by 10 foot banner will need a preview that’s 44 MB, and that’s not even required for printing. It is qute possible for an Illustrator file that physically large to be only 1.5 MB.
          EPS is a dying format. There is probably no reason for you to be saving your file as EPS. If you only need to use it in Illustrator then save as .AI with PDF compatibility turned off (this option appears after you slick Save). If you need to use the Illustrator file in another program, the save as .AI with PDF compatibility turned on.
          Can you tell us why you are saving as EPS?
          • 2. Re: Export to EPS on Macbook Pro i7, CS4 and CS5, ULTRA SLOW
            burntgoathead Level 1
            Sorry, I meant "Saved As" not Export.  I have only been using the "Save As" command.
            As for the file, there are no blends, gradients, meshes, swatches, symbols, raster art, or effects. The file was, however, a 3 foot by 7 foot banner created at actual size. But even when I reduced the size to 3 inches by 7 inches, it still ran extremely slow.
            The only reason I'm saving to an EPS is because the print houses I send stuff to all request the EPS format.  A lot of print houses are behind the times and I have to meet their requests.
            BTW, thank you for the response.
            • 3. Re: Export to EPS on Macbook Pro i7, CS4 and CS5, ULTRA SLOW
              davidmacy Adobe Employee
              Are there many transparent objects? EPS does not support transparency so everything transparent needs to go through the Flattener, which can be slow.
              P.S. look for a print shop that will take PDF.
