0 Replies Latest reply on Jun 3, 2010 3:28 AM by Alex Uhlmann
    [svn:cairngorm3:] 16416: Moved DataCache to Integration (this isn' t dependent on Parsley but only on the utility library Spicelib, it works cross-frameworks), Adjusted unit tests and Insync samples to latest module library improvements for Flex 4 .
    Alex Uhlmann Level 3
      Revision: 16416
      Revision: 16416
      Author:   auhlmann@adobe.com
      Date:     2010-06-03 03:28:11 -0700 (Thu, 03 Jun 2010)
      Log Message:
      Moved DataCache to Integration (this isn't dependent on Parsley but only on the utility library Spicelib, it works cross-frameworks), Adjusted unit tests and Insync samples to latest module library improvements for Flex 4.
      Modified Paths:
          cairngorm3/trunk/libraries/Integration/.actionScriptProperties
          cairngorm3/trunk/libraries/Integration/.flexLibProperties
          cairngorm3/trunk/libraries/Integration/pom.xml
      Added Paths:
          cairngorm3/trunk/libraries/Integration/libs/spicelib-flex-2.2.2.swc
          cairngorm3/trunk/libraries/Integration/src/com/adobe/cairngorm/integration/data/
          cairngorm3/trunk/libraries/Integration/src/com/adobe/cairngorm/integration/data/DataCache .as
          cairngorm3/trunk/libraries/Integration/src/com/adobe/cairngorm/integration/data/IDataCach e.as
          cairngorm3/trunk/libraries/Integration/src/com/adobe/cairngorm/integration/data/SyncIdMet adata.as
