0 Replies Latest reply on Jun 3, 2010 3:29 AM by Alex Uhlmann
    [svn:cairngorm3:] 16419: Moved DataCache to Integration (this isn' t dependent on Parsley but only on the utility library Spicelib, it works cross-frameworks), Adjusted unit tests and Insync samples to latest module library improvements for Flex 4 .
    Alex Uhlmann Level 3
      Revision: 16419
      Revision: 16419
      Author:   auhlmann@adobe.com
      Date:     2010-06-03 03:29:13 -0700 (Thu, 03 Jun 2010)
      Log Message:
      Moved DataCache to Integration (this isn't dependent on Parsley but only on the utility library Spicelib, it works cross-frameworks), Adjusted unit tests and Insync samples to latest module library improvements for Flex 4.
      Modified Paths:
          cairngorm3/trunk/libraries/IntegrationParsley/.actionScriptProperties
          cairngorm3/trunk/libraries/IntegrationParsley/.flexLibProperties
          cairngorm3/trunk/libraries/IntegrationParsley/.settings/org.eclipse.core.resources.prefs
      Removed Paths:
          cairngorm3/trunk/libraries/IntegrationParsley/src/com/adobe/cairngorm/integration/data/
