0 Replies Latest reply on Jun 3, 2010 3:37 AM by Alex Uhlmann
    [svn:cairngorm3:] 16426: Moved DataCache to Integration (this isn' t dependent on Parsley but only on the utility library Spicelib, it works cross-frameworks), Adjusted unit tests and Insync samples to latest module library improvements for Flex 4 .
    Alex Uhlmann Level 3
      Revision: 16426
      Revision: 16426
      Author:   auhlmann@adobe.com
      Date:     2010-06-03 03:37:25 -0700 (Thu, 03 Jun 2010)
      Log Message:
      Moved DataCache to Integration (this isn't dependent on Parsley but only on the utility library Spicelib, it works cross-frameworks), Adjusted unit tests and Insync samples to latest module library improvements for Flex 4.
      Removed Paths:
          cairngorm3/trunk/libraries/Integration/test/com/
