0 Replies Latest reply on Jun 3, 2010 8:42 AM by Alex Uhlmann
    [svn:cairngorm3:] 16430: Moved DataCache to Integration (this isn' t dependent on Parsley but only on the utility library Spicelib, it works cross-frameworks), Adjusted unit tests and Insync samples to latest module library improvements for Flex 4 .
    Alex Uhlmann
      Revision: 16430
      Revision: 16430
      Author:   auhlmann@adobe.com
      Date:     2010-06-03 08:42:24 -0700 (Thu, 03 Jun 2010)
      Log Message:
      Moved DataCache to Integration (this isn't dependent on Parsley but only on the utility library Spicelib, it works cross-frameworks), Adjusted unit tests and Insync samples to latest module library improvements for Flex 4.
      Added Paths:
          cairngorm3/trunk/libraries/IntegrationParsley/test/
          cairngorm3/trunk/libraries/IntegrationParsley/test/com/
          cairngorm3/trunk/libraries/IntegrationParsley/test/com/adobe/
          cairngorm3/trunk/libraries/IntegrationParsley/test/com/adobe/cairngorm/
          cairngorm3/trunk/libraries/IntegrationParsley/test/com/adobe/cairngorm/integration/
          cairngorm3/trunk/libraries/IntegrationParsley/test/com/adobe/cairngorm/integration/AllInt egrationParsleyTests.as
          cairngorm3/trunk/libraries/IntegrationParsley/test/com/adobe/cairngorm/integration/localc onnection/
          cairngorm3/trunk/libraries/IntegrationParsley/test/com/adobe/cairngorm/integration/localc onnection/LocalConnectionProxyTest.as
