9 Replies Latest reply on Jun 4, 2010 11:22 AM by Joe ... Ward
    AIR app will not run on Win XP
      I craeted an AIR app for my company's sales team. I've passed it around and it works fine on most machines (mostly Dell laptops running Windows XP). I have one salesman who was able to run earlier versions of the app, but now opening the app does nothing. I can see it running in the background when I look at the Processes tab in Windows Task Manager. No one else has had this problem. I've tried uninstalling and reinstalling both the app and the AIR player (version Are there any Windows security settings he might have set that would prevent an AIR app from opening?
        • 1. Re: AIR app will not run on Win XP
          Joe ... Ward Level 4
          There are no particular settings that I know of that would prevent an AIR app from running. And if there were, I would expect that it would kill the app altogether and not leave the process running in the background. I assume that you have rebooted since the problem started.
          Does your app save data, use the EncyptedLocalStore class, or use a database and read it before opening a window? It is possible the new version is having a problem with data left behind by the previous version. When you uninstall or reinstall an AIR app, the app's data is not deleted. You might try deleting anything in:
          C:\Documents and Settings\user\Application Data\applicationID\Local Store
          (where user is the user name and applicationID is the id of your application).
          Another way to test this would be to create a temporary version of the app with a new application id, name, and file name in the app descriptor. Thus essentially creating a brand new app for this user.
          • 2. Re: AIR app will not run on Win XP
            jomelia Level 1
            I do have a SQLite database installed when the app is installed, and when I have a new version of the app I usually rename the db file that is created to avoid old data issues.
            But the interesting thing is that when I look on that user's pc in that directory, there is no listing for my app. It's there on other pcs where the app runs correctly, so perhaps the SQLite file is not being installed correctly. Any idea what would prevent that from happening?
            • 3. Re: AIR app will not run on Win XP
              It sounds like the installer isn't quite working. Try getting an installation log to see if anything fishy is reported: http://kb2.adobe.com/cps/403/kb403123.html
              • 4. Re: AIR app will not run on Win XP
                jomelia Level 1
                I ran the install log and I'm including the contents to see if you can make any sense of it
                . The only thing that sticks out is a line "Application not located", which I highlighted below. Otherwise it looks like it installed
                just fine. I appreciate your taking a look at this.
                Starting app install of file:///C:/Documents%20and%20Settings/Andrew.esposito/Desktop/ROI_CalculatorAir-060310.ai r
                UI SWF load is complete
                UI initialized
                Unpackaging to C:\Documents and Settings\Andrew.esposito\Local Settings\Temp\flaA2.tmp
                unpackaging is complete
                application is bound to side-by-side version 1.0
                application is bound to this version of the runtime
                app id ROI-CalculatorAir3
                pub id 579DB9134D64DA8D12906F2BE8761198D0983B68.1
                Waiting for user confirmation
                User confirmed action: install
                creating native installer in: C:\Documents and Settings\Andrew.esposito\Local Settings\Temp\flaA3.tmp
                native installer creation complete
                Starting install
                Destination for installed application is C:\Program Files
                Beginning install
                Installing C:\Documents and Settings\Andrew.esposito\Local Settings\Temp\flaA3.tmp\setup.msi
                Execution complete; beginning commit phase
                Commit complete
                Re-launching application from C:\Program Files\ROI_CalculatorAir3\ROI_CalculatorAir3.exe
                starting cleanup of temporary files
                application installer exiting
                • 5. Re: AIR app will not run on Win XP
                  That line simply means that the installer could not find an existing, installed version of this application. There doesn't appear to be any anything amiss in the install log. So after installing and before running the app, the database file that is part of your application is still missing?
                  Are you updating the database in place in the application directory? Or do you copy it to the application storage directory before using it? Not necessarily related to the core issue, but writing to the application directory is prohibited on some OS configurations.
                  • 6. Re: AIR app will not run on Win XP
                    jomelia Level 1
                    This app has been in the prototype stage for awhile and as such I make substantial changes to the database. Early on, I found that installing a new version of the app does not install a new version of the db, so I usually give the db a distinct name based on date, so for example, my latest code has this line in it:
                    var dbFile:File = File.applicationStorageDirectory.resolvePath("roiCalc060210.db");
                    This way I'm ensured a fresh version of the db is installed with all the latest changes.
                    My first thought was that it was an OS security setting somewhere preventing the install of the db but I don't know what kind of settings would prevent this, especially as it's only on a handful of machines. Any ideas where to look?
                    • 7. Re: AIR app will not run on Win XP
                      Are you copying a template database from the install, or recreating the database if it doesn't exist? Either way, it doesn't sound like your application ever finishes initializing, so it never copies or creates the database in the application storage. Possibly the absence of the database is a red herring.
                      Do you wait for some initialization complete before displaying your application window? Is there a way that you can verify whether this initialization code completes?
                      The application storage directory should always be writable, but I'm not that familiar with Windows security and permissions.
                      • 8. Re: AIR app will not run on Win XP
                        jomelia Level 1
                        I am recreating the db if it does not exist. The db initialization script is the first to run and everything else comes from it. If I could reproduce the error locally I clould use trace statements in debug mode to follow its course. Do you know of a way to write any debug error messages or trace statements to a file, the way we did for the install log?
                        • 9. Re: AIR app will not run on Win XP
                          You could open a text file and write to it.
                          If you have sufficient access to the problem machine, you can run an installed app via adl to view trace statements in the command window. Pass the installed application descriptor and the application root directory as parameters to ADL. (See http://help.adobe.com/en_US/air/build/WS5b3ccc516d4fbf351e63e3d118666ade46-7fd7.html for more info on ADL.)
