1 Reply Latest reply on Jun 3, 2010 10:24 AM by David_F57
    Flex 4 TileLayout confusion
    jsd99 Level 3
      I'm trying to make a TileLayout that makes every entry in a List as wide as possible, to fill up 100% of the parent container.  No luck.  Here's my example application:
                     xmlns:mx="library://ns.adobe.com/flex/mx" backgroundColor="#000000" width="520">
          <fx:Declarations>
              <s:ArrayCollection id="foo">
                  <fx:String>Miami</fx:String>
                  <fx:String>New York</fx:String>
                  <fx:String>London</fx:String>
                  <fx:String>Los Angeles</fx:String>
                  <fx:String>Kuala Lumpur</fx:String>
              </s:ArrayCollection>
          </fx:Declarations>
          <s:Group top="0" left="0" right="0" bottom="0">
              <s:List dataProvider="{foo}" width="100%">
                  <s:layout>
                      <s:TileLayout columnAlign="justifyUsingWidth" horizontalGap="0" horizontalAlign="justify" verticalAlign="middle"/>
                  </s:layout>
              </s:List>
          </s:Group>
      </s:Application>
      I've tried every permutation of columnAlign/horizontalAlign possible but no joy.  What I want is 520/5 equal sized columns with the city name centered horizontally and vertically within each tile.
        • 1. Re: Flex 4 TileLayout confusion
          David_F57 Level 5
          hi,
          if you set your column count each column will be width/column count pixels or slightly less with scrollbars, in your renderer just assign 100% to widths.
          <s:List width="500" height="400" itemRenderer="userlist">
          <s:layout>
          <s:TileLayout requestedColumnCount="5" columnAlign="justifyUsingWidth"/>
          </s:layout>
          <s:dataProvider>
          <s:XMLListCollection id="myData"/>
          </s:dataProvider>
          </s:List>
          from the earlier post - you can use 100% or left=0 right=0
          <s:ItemRenderer xmlns:fx="http://ns.adobe.com/mxml/2009"
          autoDrawBackground="false">
          <s:states>
          <s:State name="normal" />
          <s:State name="hovered" />
          <s:State name="selected" />
          </s:states>
          <s:Rect left="0" right="0" top="0" bottom="0">
          <s:fill>
          <s:SolidColor color="0x444444" alpha.normal="0" alpha.hovered="0.3" alpha.selected="0.7"/>
          </s:fill>
          </s:Rect>
          <s:VGroup width="100%" paddingTop="5" gap="5" paddingBottom="5" buttonMode="true">
          <s:Label text="{data.@username}" width="100%" textAlign="center" color="#000000" color.selected="#FF0000"/>
          <s:Label text="{data.@insession}" width="100%" textAlign="center"/>
          </s:VGroup>
          </s:ItemRenderer>
          David
