4 Replies Latest reply on Apr 9, 2012 11:16 AM by azeem878
    whiteSpaceCollapse not working on textFlow created from HTML
    Robert Reinhardt Level 2
      Is there a trick to getting whiteSpaceCollapse to work with imported HTML? Here's my current code, where value is HTML text (e.g. "<p>Blah</p>.."):
      textFlow = TextConverter.importToFlow( value, TextConverter.TEXT_FIELD_HTML_FORMAT);
      textFlow.whiteSpaceCollapse = WhiteSpaceCollapse.COLLAPSE;
      I've also set whiteSpaceCollapse on the RichEditableText to "collapse" but I'm still noticing vertical space differences if my external HTML has linebreaks between <p></p> nodes. Many thanks in advance for any suggestions.
      -Robert
        • 1. Re: whiteSpaceCollapse not working on textFlow created from HTML
          rdermer Adobe Employee
          WhiteSpaceCollapse is applied as part of the import.  After that changing it or modifying it has no effect.
          Richard
          • 2. Re: whiteSpaceCollapse not working on textFlow created from HTML
            aliman Level 1
            And so ? How do we set the TextConverter to avoid collapsing white spaces on import now ?
            I ve tried many ways but still no way to avoid a WEIRD behavior.
            If I set spaces and I want to collapse them, then I can do it with a simple search/replace, there are plenty
            of regex out there to do this.
            I don't need the framework to behave strangely right ? So why did the flex engineers spend time
            on putting together stuff that is totally weird ?
            Plus the TextConverter has a lot of tlf_internal methods, just to avoid us to overload its functionnalities...
            • 3. Re: whiteSpaceCollapse not working on textFlow created from HTML
              mjzhang
              Hi aliman,
              Did you set format string to TextConvertr.PLAIN_TEXT_FORMAT ? That will preserve your spaces I think.
              var textFlow:TextFlow = TextConverter.importToFlow(markup, TextConverter.PLAIN_TEXT_FORMAT);
              And for tlf_internal, i just find one tlf_internal function in TextConverter. Others are public.
              static tlf_internal function setFormatsToDefault():void
              • 4. Re: whiteSpaceCollapse not working on textFlow created from HTML
                azeem878 Level 1
                this is the way to solve this bug and no need for changing any xml settings , simple and it works
                exporting the textflow:
                var richTextXML:xml = new XML("<"+"richTextXML"+"/>");
                richTextXML.appendChild(getCdataXMl());
                private function getCdataXMl():xml{
                  var textFlowStr:String = TextConverter.export(textFlow,TextConverter.TEXT_FIELD_HTML_FORMAT
                , ConversionType.STRING_TYPE).toString();
                var textFlowXMl:xml = new XMl("<![CDATA["+textFlowStr+"]]>");
                return textFlowXMl;
                importing TextFlow from XMl :
                var htmlTextInStr:String = richTextXMl.text();
                var importtedTextFlow:TextFlow = TextConverter.importToFlow(htmlTextInStr,TextConverter.TEXT_FIELD_HTML_FORMAT);
                textArea.textFlow = importtedTextFlow;
